Old March 16th, 2024, 12:03 PM   #1
Ryan Small
Motorcycle(s): Ninja 250, KX 250f
2010 250r starting issues
Hey guys, I’m at a complete loss. I have a 2010 ninja 250r that had been sitting for a while. I installed brand new OEM pilot jets, new diaphragms, and cleaned everything. It has a full battery and cranks well. If it’s sitting for a bit it will fire right away when cranked then die out and not start again. The wired thing is it starts with fluid and stays running/runs amazing and I can ride it with no issues. I have cleaned the fuel filters. Changes the fresh gas and am out of ideas. If anyone has any ideas or can guide me in the right direction that would be awesome. Float height is set to 17mm, needles are shimmed since the snorkel is out and the fuel screws are set to 2.5 turns out on both carbs. Bike has 12000km
Thanks in advance!
Ryan Small is offline   Reply With Quote
Old March 16th, 2024, 12:49 PM   #2
Don't use starting fluid unless you want to replace the diaphragms again.
I'm wondering if something is wrong with the petcock, and it's not fully opening during cranking when vacuum is low. Then when you get it running with the starting fluid the petcock opens and stays open. Does anything change if you set the petcock to the "Prime" position?
Old March 16th, 2024, 01:34 PM   #3
Ryan Small
Hey thanks for the response. I’ve tried cranking with it on the prime unction but it didn’t change anythign. I’ve also tried letting it sit for 30 seconds on prime then switching it back to the in position and cranking with no success. Could there be a vacuum issue or would that cause it to not run at all?
Old March 16th, 2024, 01:39 PM   #4
"Prime" is supposed to bypass the vacuum part of the petcock and turn on the fuel flow. You can check that by putting the end of the hose that normally connects to the carburetors into a container and turning the petcock to "Prime". You should have good flow when you do that.
Old March 16th, 2024, 01:55 PM   #5
Ryan Small
It also doesn’t like to start with the choke fully open which seems weird to me since it seems to not be getting fuel since it doesn’t like to fire without starting fluid. I can get it running but with a large amount of hesitation and cranking
Old March 16th, 2024, 03:01 PM   #6
What's the history of valve adjustment? When the valves get out of spec these engines get very finicky to start and don't want to run right until they warm up.
Old March 16th, 2024, 03:04 PM   #7
Ryan Small
I am not sure! I bought the bike this past fall. Maybe I’ll reach out to the original owner. It has 12000km on it so I assumed that wasn’t the problem but that seems like it could be the issue
Old March 16th, 2024, 03:46 PM   #8
It's possible. You can do a compression test and find out. If the valves are not closing all the way, compression will be low.
'06 Ninja 250R - starting/stalling issues Thatgloverguy 1986 - 2007 Ninja 250R Tech Talk 15 May 2nd, 2019 10:59 PM
Starting issues, Ninja 2010 won't crank BlueDragon 2008 - 2012 Ninja 250R Tech Talk 6 March 12th, 2015 02:49 PM
Starting Issues FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 12 January 22nd, 2015 10:33 AM
Starting issues Gorilla25 2008 - 2012 Ninja 250R Tech Talk 14 September 22nd, 2011 09:20 PM
Starting Issues mikkel General Motorcycling Discussion 4 July 30th, 2009 01:40 PM
