April 26th, 2012, 01:16 PM | #1 |
Ms. Personality
eBay zowwie438 Brake Light Modulator DIY
I found this modulator on eBay for $14.99 and $5.00 shipping, so I got one for the 250 and one for the f4i. After purchase the seller immediately communicated that there was a supply issue, but promised to have it resolved quickly. Fine with me, the item arrived in less time with the "issue" than most products from eBay do without any problems. He was kind enough to throw in something extra for my wait. Overall I am very impressed with the seller and the modulator.
Very simple installation. I opted to solder the connections but I guess you could use splice or butt connectors. The modulator has 3 wires coming out of it. 2 on one side, one on the other side. The 2 wires on side "A" are red and black. The black wire goes to ground. I chose to ground the wire to the existing ground wires, though one could ground it to chassis if so desired. The red wire goes to the blue wire closest to the connector. The third wire comes out of side "B" and is red. It should be connected to the blue wire furthest away from the connector. The idea is for the modulator to intercept the transmission coming through the blue wire and pulse it. Ninja 250 trunk Tail light connector The black wire is ground and the blue wire carries the signal when the brake lever is pulled back. The brake light modulator Install the modulator between the cut made in the blue wire. Make sure the side with 2 wires is closest to the connector and the side with 1 wire is furthest away from the connector. Black wire from modulator spliced to black wire on Ninja. Back in place! I wrapped all of the wires in tape to make sure they were tidy and tucked everything back in place. Modulator in action. Last futzed with by TnNinjaGirl; April 26th, 2012 at 06:40 PM. |
April 30th, 2012, 12:45 AM | #2 |
Nice!
April 30th, 2012, 12:48 AM | #3 |
/linked from main diy
April 30th, 2012, 05:15 AM | #4 |
Join Date: Mar 2012 Motorcycle(s): 09 Blue 250 Posts: 16
Maybe I didn't read carefully but the auction you pointed to says LED lights only. Did you convert your taillight to a LED bulb?
April 30th, 2012, 06:24 AM | #5 |
Ms. Personality
Yes, only use LED lights. I changed my bulb to a 1157 LED bulb.
July 18th, 2012, 10:47 PM | #6 |
Join Date: Jul 2012 Motorcycle(s): VStar, VS1400 Posts: 9
Write up - group discount
All,
Due to the amazing write up on the modulators I sell on ebay... I am going to offer a 2 for 1 for the next 5 orders that use the promo code of "Ninjas Rock!". Act fast because this offer will go quick!!!! Simply place your order as you normally would... Then send me a message on ebay with the promocode right after your order, and I will send you two for the price of one! It's may way of saying THANKS for this amazing write up on the modulator TnNinjaGirl!!!! http://www.ebay.com/itm/Motorcycle-B...e31b3e&vxp=mtr If my new registration here prevents links from being posted... Simply go to ebay and enter zowwie438 and you should be able to find the modulator for sale. And if YOU order some and do another write up as cool as this one or better and send me the link to the forum... I just may run this offer again. Do a good video and post it in a MC forum and I may extend the offer or do something else crazy. BE SAFE OUT THERE FOLKS! The new anti-texting laws are going to make it scary on the road!!! Cuz folks are still texting... It's just now they hold it down on their lap. And btw... Don't forget to give TnNinjaGirl mass props for posting this write up! If it wasn't for her hard work and amazing photgraphy skills, this offer wouldn't be available for others. ++Todd |
July 21st, 2012, 07:31 PM | #7 |
With two 250s, I just may do this. Thanks!
HOW-TO: Install Brake Light Modulator | Rekognize | 2013 - 2017 Ninja 300 Farkles | 26 | June 10th, 2015 07:11 PM |
Brake light modulator | ai4px | General Motorcycling Discussion | 4 | July 15th, 2012 08:23 PM |
New type of Brake light Modulator | CThunder-blue | Motorcycle-related | 0 | May 6th, 2012 10:14 PM |
Brake light modulator with LED light? | pilotgeorge747 | 2008 - 2012 Ninja 250R Farkles | 5 | January 20th, 2012 07:25 AM |
Brake Light Modulator Help | noche_caliente | 2008 - 2012 Ninja 250R Tech Talk | 21 | May 4th, 2010 06:37 PM |
