#1 |
Join Date: Nov 2009 Motorcycle(s): 08 ninja 250 Posts: 48
testing pulse coil
can anyone tell me how to properly test the pulse coil?
#2 |
no, YOU are wrong.
Join Date: Sep 2009 Motorcycle(s): 2x ex250, 1x cr250, 1x fzr 600, 6x 50cc customs Posts: Too much.
resistence check on the multimeter. i forget what good reading is, i think its like 30ohms. if it reads 0ohms or open, its bad.
orly? |
#3 |
yikes
i am getting 113.8 on the bad one(i think its bad) and almost 119 on the known good part
#4 |
Join Date: Jun 2011 Motorcycle(s): EX250, C10 Concours Posts: 75
manual resistance readings
The manual (p15-19) says the pickup coil resistance should be between 100 and 150 ohms.
#6 |
coil
no fire at all from either coil
i have swapped the handle switch, side stand switch, i am going to swap the coils(but doubt that), swapped the cdi. everything seems to be hooked up right |
#7 |
no, YOU are wrong.
did you test the main coils? if they look ok in terms of resistance, check the voltage coming from the cdi into the coils. if theres no voltage there check the power for the CDI. maybe a bad regulator? its cranking so all your kill switches should be ok. im assuming your battery is in good shape?
orly? |
#8 |
Dirt Ninja
Join Date: Aug 2011 Motorcycle(s): 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
I just stick a finger in the plug lead and run the bike, and if it hurts, it's working.
Posted via Mobile Device |
#9 |
i checked the coils, they are good, reg is good. i have a another ex sitting here. all the components will work on another bike...the one thing i cant swap that easy is the pulse coil....that should be the problem...but was wanting to be certain before i pulled it
#10 |
no, YOU are wrong.
better if you have an oscilloscope but, hook the multimeter up to it on voltage and crank it. see if you get voltage readings from the pulser coil while it cranks.
you tested the coils how? just ohms check? did you check for voltage going into the coils? if you are getting power to the coils, check the engine ground toward the back near the starter motor. if the case isnt grounded properly it obviously wont spark
orly? |
#11 |
check
i have a few complete electrical systems for the ninja 250...all are known good. I did not check the power going into the coil yet, but i know i have good components(except maybe the pulse coil) but i am not convinced the pulse coil is bad yet. I tested some of the other pulse coils and i have been getting readings as high as 121.8 and as low as 118.8 The pulser in this bike is reading much lower, but it sounds like it is still in range.
I will double check my grounds and i will cranks the bike and check the voltage. I will also do some of the other checks mention also |
#12 |
no, YOU are wrong.
its entirely possible you have all good components and its not working because of bad wiring or something. but until you know exactly where it stops working you'll be stuck playing guessing games. just work backwards from the problem. you know it doesn't spark so work backwards from there. is the coil getting power? is the cdi getting power? if the cdi is getting power, why isnt the cdi triggering? wrong voltage? is the pulser firing? maybe the pulser isn't aligned properly or the stator rotor is damaged? if the pulser fires and the cdi has good input voltage and none of the killswitches are stopping it and the cdi doesn't output to the coil then the cdi is definitely bad. maybe theres some kind of interference? if its wiring, ohms check from one end of the wire to the other should tell you right away. if you check the main coils and they aren't getting power, check them on the cdi side of the wiring harness as well. maybe the wiring is bad you know
orly? |
#13 |
parts
yeah alex...that is my next step. is there an online guide that can help me with the trouble shooting values? some of the numbers i know but others i dont.
#14 |
no, YOU are wrong.
i think the service manual has it. my brother is good with the wares so he has a copy that i had him print for me. maybe someone here has a copy they can give you. it has all the test values.
orly? |
#15 | |
i dont see the ground right off. from where to where should that be running? |
#16 |
no, YOU are wrong.
might be in a different location on the pregen. on the newgen it goes from the battery ground to the engine case on the starboard side behind the starter.
orly? |
#17 |
i found the ground,...,,it looks and feels fine and looks to be untampered
#18 | |
#19 |
whats the air gap on the pulse coil? actually...does anyone have any good recommendations for an online manual i can get right away?
#20 |
pulled the right cover off. the pulse coil is damaged, but still intact. oddly enough there is a nut floating around inside the cover. guessin thats my problem
#21 |
Join Date: Jun 2008 Motorcycle(s): '13 Ninja 300 (white, the fastest color!), '13 R1200RT Posts: Too much.
/moved to new-gen tech
Montgomery Street Motorcycle Club / cal24.com / ninjette.org ninjette.org Terms of Service, ninjette.org Member Map Shopping for motorcycle parts or equipment? Come here first. The friendliest Ninja 300 / 250R forum on the internet! |
#22 |
we are talking about a 05 model
#23 |
no, YOU are wrong.
well thars yer problem!
if the pulser coil isnt lined up right and gapped right the cdi wont fire correctly. i assume the nut was from the mount on the pulser coil? make sure to lock tight that little guy. i had one slip off while riding and it destroyed itself, the stator, and part of the wheel
orly? |
#24 |
L8APEX
Join Date: Nov 2011 Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org! Posts: 185
Just for reference, if you gound the Green with Black tracer that is coming out of the ECU, it will take all the saftey switches and realys out of the equation
www.joemillersmoderngarage.com www.starr-cycle.com ***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
| Thread | Thread Starter | Forum | Replies | Last Post |
| Zx coil over plugs | alex.s | Pictures | 11 | February 7th, 2013 12:46 PM |
| Coil wiring? | expat | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 26th, 2012 06:57 PM |
| Ground to coil? | nickadolph | 2008 - 2012 Ninja 250R Tech Talk | 15 | January 6th, 2012 04:03 PM |
| [superbikeplanet.com] - A Pulse At Suzuki | Ninjette Newsbot | Motorcycling News | 0 | July 18th, 2011 11:40 AM |
| [sportrider - latest stories] - Sudco Offers Mikuni MK Pulse Fuel Pumps for Custom an | Ninjette Newsbot | Motorcycling News | 0 | January 27th, 2011 04:00 PM |
| Thread Tools | |
