Old December 4th, 2008, 01:47 PM   #1
toku
toku's Avatar
Motorcycle(s): 08 Ninja 250
DIY- Full Yoshi Install
I see that kkim and VeX brought a lot of their DIY over so I figured I'd contribute what I have as well.
I know there is an Area P install thread I'm guessing this will be pretty similar just a different brand so if you don't feel this thread is needed feel free to delete it.
Anyway here we go:
Overall its really simple I just followed the instructions that came with the exhaust.
Everything included with the exhaust
From here I'm assuming you know how to get the stock exhaust off, if not I can post that up too. It's really simple.
Next I took off the gaskets from the stock headers put them on my headers and just hand tightened the nuts to the engine.
Now you have the headers mounted and you can slip on the midpipe and muffler, I found that the pieces mated really well and it wasn't any trouble to get them to come together.
The headers prior to attaching the midpipe and muffler
Next you want to slide the muffler clamp onto the muffler, pinch it with your hand so you can fit the stock bolt through the clamp and the passenger peg. At this point you want to take the stock washer that was previously on the outside of the peg and move it to the inside then I hand tightened the stock nut onto the bolt.
The stock washer moving to the inside of the peg
Now using the spring puller you want to attach the springs holding the header and the midpipe together.
Attaching the springs
At this point what I did was to make sure that everything lined up properly and that there was good clearance everywhere. Then I proceeded to torque everything down. I torqued the headers down to 10 ft-lbs and the bolt going through the passenger peg to 18 ft-lbs.
The final step is then to put on the heatshield
The easy part of installing your full system is now over. After this you need to pull the carbs and rejet but this is covered in other tutorials so I won't go into it here.
File Type: pdf DIY- Full Yoshi Install - ninjette.org.pdf (1.84 MB, 91 views)
Yoshimura CF Full System, Dynojet Jet Kit, Kleen Air System Removed, Woodcraft Clip-Ons, Sato Rear Sets, Galfer SS Brake Lines, 15/44 Sprocket Combo, Home Made Fender Eliminator
toku is offline   Reply With Quote
Old December 4th, 2008, 02:06 PM   #2
lol... don't you love it when the exhausts are so shiny and new before you use them?
Thanks for adding yours... I'm sure more DIYs are better than not enough, plus you added things that others left out.
good job.
Old December 4th, 2008, 04:37 PM   #3
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
Nice! It's nice to see the naughty bits of other exhausts. Yeah the yoshi is a clean looking setup with the heat-shield and all.
... And you DON'T have to pull the carbs to re-jet. In fact it's probably easier not to pull them
You can drain and drop the fuel bowls easily enough with the Milwaukee Offset Screwdriver and the jets are easy to get to:
VeX is offline   Reply With Quote
Old February 20th, 2010, 06:45 PM   #4
Zomb1eFaceKilla
Zomb1eFaceKilla's Avatar
Motorcycle(s): 2009 Kawasaki 250r (Blue)
I really love the look and sound of this exhaust. Anyone know how it compares to other exhaust as far as HP gain/weight etc...Also the pros and cons of a slip on versus full? I would love to know since this is my next item of purchase.
Zomb1eFaceKilla is offline   Reply With Quote
Old February 20th, 2010, 07:05 PM   #5
Keenan84
Keenan84's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r Special Edition
this how to is way better than the others, thanks!
Keenan84 is offline   Reply With Quote
Old April 19th, 2010, 12:50 PM   #6
Preachaman
Motorcycle(s): 2009 Ninja 250 SE
I should have looked this up when I did my yoshi install last thursday. Very good tho!
Preachaman is offline   Reply With Quote
Old April 21st, 2010, 12:52 AM   #7
Haider87
Learning by doing
Haider87's Avatar
Motorcycle(s): '08 Ninja 250R
If I could add one thing, it would be a tip to make sure you wear clean latex gloves, or have thoroughly washed hands when installing so to not get any oil on the pipe, and to wipe the headers down reaalllllly well before the first ride, because when the oil burns on a hot pipe is how blemishes will appear and stain. It's all about that first ride.
Haider87 is offline   Reply With Quote
Old November 5th, 2010, 03:44 PM   #8
Ninja13oy
Motorcycle(s): kawasaki 2009 brand new ninja 250r
k question, When installing the yoshimura exhaust system, is there anything else you need to do? Like rejet or something? I want to just slap on the system and see how it goes. Is that a good ideal?
Ninja13oy is offline   Reply With Quote
Old November 5th, 2010, 06:23 PM   #9
No.
Old November 5th, 2010, 07:20 PM   #10
edwinmcq
edwinmcq's Avatar
Toku, that is a very fine presentation! Thanks.
Alex, I'm assuming your "no" is "no that is not a good idea."
www.edmcqueen.com
edwinmcq is offline   Reply With Quote
Old November 5th, 2010, 09:04 PM   #11
Yes.
Old April 20th, 2011, 01:28 AM   #12
egutierrez90
Eddie
egutierrez90's Avatar
Motorcycle(s): None.
So, how is your ninja running with the f/s yoshi?
does it pull good? no surging and all that other whack stuff? what size pilot jet/main jets are you using?
Your answers are appreciated.
egutierrez90 is offline   Reply With Quote
Old August 23rd, 2011, 09:06 AM   #13
frankie930
Motorcycle(s): 250r
My Fuel Injection light comes on when i start the engine after installing the full yoshi system. I presume its because i no longer have the cable attached from the cat on the original pipe, is there a way around it?
thanks
frankie930 is offline   Reply With Quote
Old August 23rd, 2011, 10:18 AM   #14
PM gregular, I think he had a Yoshi on a FI ninjette a few years back, and may have dealt with the same issue.
Old August 23rd, 2011, 03:58 PM   #15
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
thanks
You need an O2 sensor, and probably a retune
Felipe the Ant is offline   Reply With Quote
Old August 23rd, 2011, 04:00 PM   #16
frankie930
Motorcycle(s): 250r
Thankyou
Old August 25th, 2011, 08:12 PM   #17
AeroXtasy
New 2-Wheel Addict
AeroXtasy's Avatar
Motorcycle(s): Blue 2009 250r Kawasaki Ninja
Is there a noticeable performance difference?
I've decided I'll be going with Yoshi when I get a new exhaust over Two Bros.
Still undecided about an Area P though.
AeroXtasy is offline   Reply With Quote
Old August 25th, 2011, 09:41 PM   #18
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Yoshi
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old October 13th, 2011, 08:35 AM   #19
Maniac0908
Motorcycle(s): 11 ninja 250r
Besides rejetting and raising needles wat do i meed to do? I read somethif about a flapper? Also how do i kno if mine is fuel injected? I have a 11 250
Maniac0908 is offline   Reply With Quote
Old October 13th, 2011, 09:00 AM   #20
Cuongism
Cuongism's Avatar
US doesn't have FI models yet if your location is Maryland. Not sure where you read about intake flappers, but pretty sure the ninja 250 does not have one.
Old October 13th, 2011, 09:42 AM   #21
Maniac0908
Ok. Maybe i was reading about a diffrent bike. One more question. If im just looking to make it sound like a bike and not a scooter should i jut o with a slip on so i dont need to do all this? Imnot really looking for a performance boost.
Old October 13th, 2011, 09:51 AM   #22
Maniac0908
O and how soon do i need to rejet after doing this? I also want to get a air filter. Will my bike get messed up i i dont rejet right away? Sorry... Im a noob...
Old October 13th, 2011, 10:28 AM   #23
Gorilla25
Dakine...
Gorilla25's Avatar
Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon)
Originally Posted by Maniac0908 View Post
Im not really looking for a performance boost.
then get a slip on, and just shim the needles and be fine......but full systems are nice too
Gorilla25 is offline   Reply With Quote
Old October 14th, 2011, 09:32 AM   #24
Maniac0908
Will a full system give me a deeper sound?
DIY- Woodcraft Clipon Install kkim 2008 - 2012 Ninja 250R Tech Talk 503 October 9th, 2013 08:46 AM
How to install yoshi slip on for 2012 250r iSpeed 2008 - 2012 Ninja 250R Tech Talk 7 July 11th, 2012 07:52 AM
Yoshi full exhaust or slip on?? Help!! Maniac0908 2008 - 2012 Ninja 250R Tech Talk 2 October 13th, 2011 08:20 AM
DIY ZG DB install ? chef 2008 - 2012 Ninja 250R Farkles 5 October 13th, 2011 04:44 AM
Yoshi CF Full exhaust for 08-09 Jiu Jitsu Player Items Wanted 0 April 12th, 2009 11:12 PM
