#1 |
Join Date: May 2012 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 46
Snorkel removal questions
So I've been reading alot about removing the snorkel from the airbox and it seems like it is a good mod to do, my question is, do I have to have a jet kit to do this or is it something i can do and get away without using one, I have a stock exhaust for right now. I plan on getting a jet kit down the road. but for right now can i run without a snorkel without a jet kit.
#2 |
Join Date: Jul 2011 Motorcycle(s): 2010 250r ninja Posts: 112
im no wiz at jetting, but if you removin the snokle you should at least shim the neeedles cause you will be running very lean and could damage the engine.
#3 |
#4 |
yes, tho someone correct me if im wrong. I would use the search tool and look around to be sure, cuase there are hundreds of posts about shimming and exhaust stuff.
Cuase im no expert |
#5 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
You may not need to shim at all. I shimmed with 2 washers when I installed my slip-on & removed the Clean Air System (got an assortment pack at Radioshack & just used the smallest ones that would fit). After i removed the snorkel, my bike was running rich, so I just removed one washer and it rides better, I haven't tested it back with 0 washers.
Four more years of high unemployment, high taxes, high gas prices, military reduction, and socialist agenda. Way to go America
#6 | |
#7 |
Join Date: Jun 2011 Motorcycle(s): 2013 Yamaha FZ6R Posts: 904
I tried the removing snorkel w/o shimming ..bike seem to run fine, but it was running a bit lean. Ended up just putting the snorkel back in.
In reality, removing it gives no extra bonus to do it without shimming! |
#8 |
So if I remove it, I should either jet it or shim it. correct?
#9 |
Removing snorkel w/ stock exhaust = shim
removing snorkel AND replace can w aftermarket = shim removing snorkel AND replace full exhaust = jetkit |
#10 |
So Would i be able to run a jet kit if i just remove snorkel and install a slip on, or is it just shimming and a better choice since it is cheaper to do. or can u only run a jet kit with a full exhaust?
#11 |
You can do a full jetkit anytime.. just no real need for it, for anything less than a full exhaust change including header pipes.
#12 | |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Snorkel Removal on EFI Ninja 250R? | hackeron | 2008 - 2012 Ninja 250R Tech Talk | 16 | February 2nd, 2012 09:43 AM |
| Shimmed/Removed Snorkel, bike feels weaker? A few questions. | 1LoneWolf | 2008 - 2012 Ninja 250R Tech Talk | 31 | September 11th, 2011 10:50 AM |
| snorkel removal | 4x4kayak2112 | 1986 - 2007 Ninja 250R Tech Talk | 14 | March 9th, 2011 03:28 PM |
| Quick Question About Snorkel Removal | LegB4Wicket | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 11th, 2010 09:49 AM |
| inconsistent throttle/rpm after shimming and snorkel removal | Hokie11 | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 23rd, 2009 03:17 PM |
| Thread Tools | |
