Old July 30th, 2012, 08:50 PM   #1
krolinked
Mo-TARD
Motorcycle(s): SE White Kawasaki Ninja 250, 2012 Yamaha YZF-R6 White/Black/Red Scheme
47 Tooth Rear
I just switched out my chain and popped in a 47 Tooth in the rear while I was at it. Also removed snorkel and shimmed the needles. And wow, this thing is a beast now. It roars to life and with the bigger sprocket it takes off like a mofo!
I've been riding like a hooligan ever since!
Old July 30th, 2012, 09:36 PM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
You need a 13 in the front
Send your tasteful nudes to Jiggles@ninjetteporn.com
Supersports are for n00bs
Old July 30th, 2012, 10:24 PM   #3
krolinked
Mo-TARD
I ordered one way back but they called and said they dont actually carry said sprocket so i opted for the 15 instead. It's still sitting in my room lol.
Old July 30th, 2012, 10:25 PM   #4
Jiggles
Jiggles's Avatar
Get a 13! It makes it a wheelie machine!!!
Old July 31st, 2012, 04:19 AM   #5
King off-topic poster
choneofakind's Avatar
Motorcycle(s): Green/purple 1999 EFI Ninja 250, 2011 Giant Yukon FX, 2007 Dawes 1000
47T rear is fun! but you do know that 15/47 is nearly identical to the stock 14/45 right?
Posted via Mobile Device
Old July 31st, 2012, 01:26 PM   #6
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
If I were to change one sprocket, should I do 15t front or 47 rear?
Old Lemon is offline   Reply With Quote
Old July 31st, 2012, 01:27 PM   #7
Jiggles
Jiggles's Avatar
Do you want to go faster or slower?
Old July 31st, 2012, 01:31 PM   #8
Old Lemon
Lays er down
Old Lemon's Avatar
Faster
Old July 31st, 2012, 01:33 PM   #9
krolinked
Mo-TARD
Take off, or Top Speed?
Old July 31st, 2012, 01:36 PM   #10
Old Lemon
Lays er down
Old Lemon's Avatar
Take off
Old July 31st, 2012, 01:44 PM   #11
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
Front down and rear up = better acceleration but lower top speed (and higher cruising RPM)
Front up and rear down = less acceleration but lower cruising RPM
My Mods | My Bike's Ninjette Thread
saxnbass is offline   Reply With Quote
Old July 31st, 2012, 02:17 PM   #12
Old Lemon
Lays er down
Old Lemon's Avatar
Ok cool, sounds like I wanna change the rear sprocket as well
Old July 31st, 2012, 02:26 PM   #13
saxnbass
saxnbass's Avatar
Another note, up 3 in the rear is roughly equivalent to down 1 in the front (and all the vice versas of that)
Old July 31st, 2012, 03:16 PM   #14
no, YOU are wrong.
Motorcycle(s): 2x ex250, 1x cr250, 1x fzr 600, 6x 50cc customs
uh. isnt stock front 15t?
orly?
Old August 1st, 2012, 09:46 PM   #15
Motorcycle(s): '13 Ninja 300 (white, the fastest color!), '13 R1200RT
14t is stock
Montgomery Street Motorcycle Club / cal24.com / ninjette.org
ninjette.org Terms of Service, ninjette.org Member Map
The friendliest Ninja 300 / 250R forum on the internet!
Old August 2nd, 2012, 04:35 AM   #16
2. Not 3. 13/45 is equivalent roughly to 14/47
Old August 2nd, 2012, 04:55 AM   #17
saxnbass
saxnbass's Avatar
Guess it's different for the 250 than on bigger bikes then, my bad.
Old August 2nd, 2012, 04:57 AM   #18
No, they should act the same. Check gearing commander for both your cbr and a 250. I have known to be wrong with numbers before...
JT Sprocket 42 tooth Rear Sprocket lolibater Motorcycle-related 36 February 25th, 2013 11:30 AM
going to 16 tooth countershaft sprocket? thomason2wheels 2008 - 2012 Ninja 250R Tech Talk 3 September 17th, 2012 11:02 AM
15 tooth sprocket help. wild-bill 2008 - 2012 Ninja 250R Tech Talk 3 November 10th, 2010 08:39 AM
15 Tooth Front Sprocket FerociousNINJA 2008 - 2012 Ninja 250R Tech Talk 5 September 14th, 2010 05:21 AM
15 tooth cs sprocket mxnello 2008 - 2012 Ninja 250R Tech Talk 12 April 4th, 2009 02:25 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Except where otherwise noted, all site contents are © Copyright 2013 ninjette.org, All rights reserved.
