October 10th, 2012, 09:39 AM | #1 |
Join Date: Sep 2012 Motorcycle(s): 2005 ZX6R, 2011 Sprint GT Posts: A lot.
Planning out my fender elimination
I am thinking about combining this:
http://www.saylorspecialties.com/FenderEliminator.html with this: http://www.ebay.com/itm/180740014442...84.m1423.l2649 to make for some integrated turn signals in the right and left of the brake light, as well as the rear fender elimination itself. What kind of amber bulbs will I need for these? Does it matte that they appear to be 2 wire as opposed to 3 wire? Do I just run the wires currently going to the turn signals, up to the brake light housing for the new turn signal locations?
"The enemy is fear. We think it is hate, but it is fear." - Gandhi |
October 10th, 2012, 10:28 AM | #2 |
Join Date: Aug 2012 Motorcycle(s): 03 ninja 250 Posts: 201
I simply pulled the bulbs out of my rear turns and placed them in the spots next to the brake lights via hot glue... Uses te same connectors as factory since its the same socket and bulb.
Then I just bought 2 L brackets an made a license plate holder But you may have to convert to a electronic flasher relay as I tried different bulb sockets that I purchased from advance auto and they flashed too quickly with the stock turn signal flasher. |
October 10th, 2012, 10:37 AM | #3 |
I told you bro
Join Date: Jun 2012 Motorcycle(s): 1996 Ninja 250r Posts: 680
I wonder if there are measurements to make a similar "fender eliminator". I've been running my bike with that plastic (previous owner removed it) and I could use that storage space. 60 dollars is a pretty ridiculous asking price.
October 10th, 2012, 10:40 AM | #4 |
Wow $60 I didn't even look at the price. I did the same thing, I took my dremel and cut out the excess of the rear fender so it looks identical to that and keeps the storage. Maybe I should charge for instructions on how to do this!
October 10th, 2012, 11:07 AM | #5 |
I just choose not to go the DIY route on this one. I always find myself cutting corners on obvious aesthetically related parts, and always manage to mess it up. 60$ didn't seem too bad compared to the other ~$100 kits I saw.
If I glue the sockets from the pod flashers to the brake light housing, how would I go about changing the bulbs should they go out?
October 10th, 2012, 11:08 AM | #6 |
You're fixing the sockets in not the bulbs, the bulbs are a standard twist and pull. But the sockets stay in place.
October 10th, 2012, 11:10 AM | #7 |
Gotcha. Sounds like it should be relatively easy then. Do they have 2 or 3 wires running to them?
October 10th, 2012, 11:16 AM | #8 |
2 wires, it's the factory turns so they're made to plug in back there. Only thing that required a little force was getting the socket out of the stock turn signals, once you loosen the screw and yellow lense comes off the turn signal you'll see you have to cut it out of there. A dremel took 10 seconds to do and it lifts out.
Other thing with this mod is to make sure you check local laws, my local law for Delaware states of turn signals are red and brake lights are red the turn signal must be 9 inches away from each other. I highly doubt anyone gets pulled over for it but just a heads up. |
October 10th, 2012, 11:21 AM | #9 |
I ride like a granny
Join Date: Jun 2012 Motorcycle(s): 2003 Ninja 250R - EX250F Posts: 521
One thing that's been keeping me from installing a fender elimination kit is the fact that I want to keep my turn signals. I have no desire to integrate them into the pods - in fact, these pods are wired to act as extra brake lights.
I thought about pulling out the dremel and removing the excess, but keeping the tabs where the turn signals go but I'm afraid it'll look like **** Tips? Advice?
WANTED for 88-07 Ninja 250: Corbin Gunfighter & Lady seat |
October 10th, 2012, 11:25 AM | #10 |
Edit.. Just looked at your eBay link and those smoked pods with the yellow bulbs are perfect, I actually think I may pick up a set wish I cod get just the lenses though as I do not need the socket/bulbs.
And I tried cutting out the excess and leaving the turns there but though it looked funky so I went away with it all together. Just my opinion though I was skeptical about the turn integrated there too but they're brighter red than the brake light and flash so once I tried it out it's still quite noticeable and once they're yellow it'll be plain as day. IMO |
October 10th, 2012, 11:26 AM | #11 |
Yeah it will be legal since I will get different color lenses for the signal part. I'll make sure to drab a new dremel bit.
October 10th, 2012, 11:33 AM | #12 |
You could always try the socket and bulbs that come with eBay lenses and see if they'll work, the ones I picked up from advance required a too powerful bulb so it got the relay too hot and caused them to flash too fast. Only hook up 2 wires and leave the other taped off. My front flush mounts have 3 wires, only used 2 and they work like oem.
October 10th, 2012, 11:39 AM | #13 |
That FE is great! I have it. $60 is nothing, considering it's better than the other kits, is cheaper, and looks better than DIY methods. It's also hand laid fiberglass and bolts right up to where your fender came off of. It's literally perfect.
It's either pay 100+, DIY with varying results, or pay $60 for something that is right. |
October 10th, 2012, 11:41 AM | #14 | |
October 10th, 2012, 11:46 AM | #15 | |
October 10th, 2012, 11:51 AM | #16 |
yep! go creep on my photo albums if you want
October 10th, 2012, 12:26 PM | #17 |
Chris, come to MN and help me mod my pregen
October 10th, 2012, 03:28 PM | #18 |
October 10th, 2012, 03:46 PM | #19 |
Dang, alright
October 10th, 2012, 03:50 PM | #20 |
in the mean time, drooooool over my bike
October 10th, 2012, 04:20 PM | #21 |
I need to get rid of my fugly cans already.
October 16th, 2012, 06:58 PM | #22 |
just ordered the saylor kit, a 3x flash then steady center brake light, and 2 amber leds for the rear signals. I can't wait to see this complete!
October 22nd, 2012, 06:46 PM | #23 |
October 22nd, 2012, 07:57 PM | #24 |
also just ordered the new flasher relay so my blinkers don't go crazy.
October 22nd, 2012, 08:58 PM | #25 |
Looking good Loli!! How'd that Saylor kit go for you? Mine was simple and bolted right up.
October 22nd, 2012, 09:01 PM | #26 |
One of the bolts was kinda hard to get in, but nothing I couldn't handle.
October 22nd, 2012, 09:03 PM | #27 |
I got them all started in the threads with my fingers, and then wiggled it a bit so that all the holes were lined up, and then tightened them down. Never given me problems, and I've had it off a couple times.
Glad it worked out for ya. It looks great! Now it just needs to be green |
January 19th, 2013, 05:41 AM | #28 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
January 26th, 2013, 04:05 PM | #29 |
Daily Jap rider
Join Date: Dec 2012 Motorcycle(s): 2012 Ninja 250r Posts: A lot.
just ordered my fender eliminator and brake light modulator, wish the no cuts were still in business
February 6th, 2013, 12:23 AM | #30 |
Heh, I just did this mod today. Dremel, hot glue, etc. I reused the original turn signal housing (with lots of cutting) so I could easily change the bulbs out when needed. Well, until I do an LED mod.
Fender Elimination in Oklahoma | Daniel_Malloy | 2008 - 2012 Ninja 250R Farkles | 2 | May 16th, 2012 04:49 PM |
Fender Elimination | akshay11 | General Motorcycling Discussion | 3 | March 3rd, 2012 11:40 PM |
Which fender elimination kit do you recommend? | Ninja_Noob | General Motorcycling Discussion | 10 | May 12th, 2011 12:47 PM |
Fender Elimination help? | kevlarorc | 2008 - 2012 Ninja 250R Tech Talk | 13 | January 4th, 2010 06:52 AM |
DIY - $0 Fender elimination | Buffalony | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 2nd, 2009 12:50 PM |
