January 25th, 2013, 05:30 AM | #1 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
stumbling bike
Yesterday I was doing wheelies and after a couple my bike started acting like the carbs were fouled. At times I was only running 1 cylinder when in the low-band (under 5k) and even after getting up to speed it would stutter a lot. I pulled the carbs and did the best I could to clean them but they seemed fine and not clogged up or anything. I still can't pull the pilot jets... I rode it around for a little with the choke set to let the bike idle at 2k and it seemed to run like it would normally. Any ideas? After work I'm gonna check the fuel level in the bowls and possibly re clean the carbs. The floats and plungers( forgot the name) seem to be fine...
January 25th, 2013, 05:56 AM | #2 |
I'm no a wheelie guy, but I recall hearing that too vertical on wheelie can cause fuel starvation.
January 25th, 2013, 07:33 AM | #3 |
restraining myself from commenting on the wheelies.
How many miles on the spark plugs? |
January 25th, 2013, 07:50 AM | #4 |
January 25th, 2013, 07:52 AM | #5 |
Jar something loose when setting it down? Carb boot? Vac line?
January 25th, 2013, 07:55 AM | #6 |
January 25th, 2013, 09:57 AM | #7 |
Have you run it since it started acting funny? Is it still acting up?
January 25th, 2013, 11:47 AM | #8 |
Yeah I ran it and it acted the same. pretty sure there is something lodged inside my pilot jet(s). How can I get those damn things out if they are being stubborn? I just sprayed wd40 in the passage where the screwdriver would go now I am waiting.....
January 25th, 2013, 12:22 PM | #9 |
Ok got one out. You're not supposed to see light thru the center shaft of them like the main jets are you? They seem fine I really hope this isn't a timing issue
January 25th, 2013, 12:50 PM | #10 |
YES! All the jets should allow free flow of gas through them.
January 25th, 2013, 01:11 PM | #11 |
Saw a teeny tiny hole after I ran some guitar string through the one pilot jet I managed to remove. Bike still acts the same! I have to go full choke to start it and if I take the choke off it it will just die even after warm-up.... I hope my tensioner didn't come loose...and I hope I didn't blow a head gasket
January 25th, 2013, 01:49 PM | #12 |
If it's dying after choke, it's carb related. Just pull the carbs and clean all the jets and passages. Just cleaning the jets might or might not get everything.
January 25th, 2013, 03:11 PM | #13 |
January 25th, 2013, 03:17 PM | #14 |
Are any of your vacuum hoses leaking?
Does this video sound familiar at all? This is rojoracing53's video in response to another user btw. http://www.ninjette.org/forums/showp...9&postcount=45 |
January 25th, 2013, 03:42 PM | #15 | |
The video seemed to be pretty similar to what I am experiencing. |
January 25th, 2013, 04:30 PM | #16 |
Wrap the slit in electrical tape really well to try and get it to seal a bit better. Does your condition get better?
If so, that's causing a leak and you need to replace that little piece of hose. I think your wheelies and your bike issue are not related and the timing is purely coincidental. |
January 25th, 2013, 04:44 PM | #17 |
Sounds like he pinched the line setting it down most likely.
January 25th, 2013, 04:44 PM | #18 | |
January 25th, 2013, 04:46 PM | #19 |
January 25th, 2013, 04:49 PM | #20 |
Yes sir, Tampa.
January 25th, 2013, 04:51 PM | #21 |
January 25th, 2013, 04:57 PM | #22 |
I loved Tampa. I visited last year and wow, so much growth. I couldn't live there again. I would have to go farther south where it's no so crowded.
January 25th, 2013, 04:59 PM | #23 |
I'll try the electrical tape test tomorrow and report back. I'll be pretty happy if its just a vacuum line. I'll do a mean wheelie just for chone.
January 26th, 2013, 07:59 AM | #24 |
Wrapped with tape, problem persists. Recorded video, gonna post on Utube when I can. Did I mention when going wot the bike really drops and almost dies before catching up and running normal/close to normal acceleration
January 26th, 2013, 08:15 AM | #25 |
Anybody real good with this bikes' carbs that can tell me which vacuum line I would need to look at if the choke runs fine? Could it be a pilot jet still even though I ran guitar string through them and sprayed plenty of cleaner and canned air?
January 26th, 2013, 08:19 AM | #26 | |
Typical Lean Conditions: - Poor acceleration; the engine feels flat. - The engine won't respond when the throttle is snapped open, but it picks up speed as the throttle is closed. (A too-large main jet also mimics this symptom.) - The engine runs hot, knocks, pings and overheats. - The engine surges or hunts when cruising at part-throttle. - Popping or spitting through the carb occurs when the throttle is opened. Or popping and spitting occurs through the pipe on deceleration with a closed throttle. - The engine runs better in warm weather, worse in cool. - Performance gets worse when the air filter is removed. Typical Rich Conditions - Engine acceleration is flat and uneven and loses that "crisp" feel. - The engine "eight-strokes" as it loads up and skips combustion cycles. - The engine idle is rough or lumpy, and the engine won't return to idle without "blipping" the throttle. - The throttle needs to be open continuously to maintain acceleration. - Black, sooty plugs, a sooty exhaust pipe and black smoke from the tailpipe that stinks of unburned fuel. - Poor fuel economy. - The engine works better when cold. Performance falls off as it warms up or the ambient temperature rises. - Engine performance improves when the air cleaner is removed. |
January 26th, 2013, 09:12 AM | #27 |
Meh the first of the lean conditions fit but other than that not really
January 26th, 2013, 09:31 AM | #28 |
If I'm driving it and I want to stop the bike I just go wide open throttle and the engine speed falls quickly and if I hold it long enough the bike will die.
January 26th, 2013, 09:42 AM | #29 |
Is it possible this is a spark(plug)issue?
January 26th, 2013, 10:11 AM | #30 |
Just grounded both plugs against the engine. This time without shocking myself. They're both fine.
January 26th, 2013, 10:20 AM | #31 |
I don't think this is a jetting issue if it just started happening randomly. Since you said you have spark, it's not the coils.
But some things to check:
January 26th, 2013, 10:29 AM | #32 | |
The intake boots seem solid they're so thick I couldn't imagine them being torn. |
January 26th, 2013, 10:33 AM | #33 |
Are your battery connections solid? That causes funny things to happen if they're not.
Spray something at parts of the intake boots. If the idle races, you've found a leak. |
January 26th, 2013, 10:36 AM | #34 |
I'm really considering buying an extra carburetor for when situations like these arise. The value of being able to troubleshoot better would be worth it alone
January 26th, 2013, 10:39 AM | #35 |
January 26th, 2013, 10:42 AM | #36 |
Any idea what the symptoms of a skipped chain are?
January 26th, 2013, 11:27 AM | #37 |
How does the air filter look? Too much oil on an air filter can choke air flow.
If you are referring to the cam chain, skipped teeth could affect your timing. Think your timing is off? Also how is your fuel flow? Have any inline filters installed? |
January 26th, 2013, 11:41 AM | #38 | |
It's definitely a possibility my timing is off. I don't think there is anything else I can do to the carbs except to replace the hoses which are fine in my opinion. |
January 26th, 2013, 11:43 AM | #39 |
Link to original page on YouTube. |
January 26th, 2013, 11:45 AM | #40 |
As for the air filter being clogged. I noticed the crankcase vent hose wasnt attached to the airbox today so it couldn't have been on when the issue started (and yes I re attached it).
08 stumbling and not moving hard | scorch | 2008 - 2012 Ninja 250R Tech Talk | 28 | December 29th, 2014 09:02 PM |
Hesitation/Stumbling 6K to 8K - Looking for Source - Ideas? | eif | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 23rd, 2014 05:40 PM |
Newly acquired 2003 w/ Muzzy - stumbling on off/on throttle and gas smell. | fierostetz | 1986 - 2007 Ninja 250R Tech Talk | 11 | August 23rd, 2012 04:00 PM |
[crash.net - MotoGP] - Singapore race plans hit stumbling block | Ninjette Newsbot | Motorcycling News | 0 | February 15th, 2010 03:30 AM |
[roadracingworld.com] - Harley-Davidson Bringing 70-Bike Demo Fleet To Daytona Bike W | Ninjette Newsbot | Motorcycling News | 0 | February 9th, 2010 01:00 PM |
