Old February 8th, 2009, 07:12 PM   #1
Snake
Snake's Avatar
Chopped fender & Installed lights in pods
Today I chopped my fender and put extra brake lights in empty pods. I also relocated the turn signals further back as part of the fender chop. It looks so good I wish I had done it sooner.
Old February 8th, 2009, 07:18 PM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Ahem - :
But I'll bet it looks great
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old February 8th, 2009, 07:20 PM   #3
Snake
Snake's Avatar
I will try and update with pictures as soon as I can.
Old March 28th, 2009, 08:34 PM   #4
tapdiggy
Humble Observer
tapdiggy's Avatar
Motorcycle(s): 2009 Yamaha XT250
I just made my '00 250 a real streetfighter. No modified/replacement headlights and such. Stock nakedness. It was too dark for pics when I was done. I'll post them soon.
tapdiggy is offline   Reply With Quote
Old March 29th, 2009, 09:06 AM   #5
jonb08
jonb08's Avatar
Motorcycle(s): 2007 EX250
Check out my chop, turn signal integration, clear lenses and flush mounts on my 07 that I did back in Oct. 2008. I made the bracket myself. After chopping the fender, I resprayed it to eliminate any scuff marks from the chop and file. I made the bracket using the directions from this site>> License Plate Bracket
Can't forget the Asian Cycle Flush Mounts
jonb08 is offline   Reply With Quote
Old March 29th, 2009, 06:36 PM   #6
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
hey that turned out well! like the pipes too.
i got the same tail light integration but need to get the amber or clear turn signal lenses.
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old March 29th, 2009, 06:44 PM   #7
sometimesido
sometimesido's Avatar
Motorcycle(s): 2006 250R
wheeeee. homemade ftw.
my flickr™
sometimesido is offline   Reply With Quote
Old March 29th, 2009, 06:46 PM   #8
M-Oorb
M-Oorb's Avatar
Motorcycle(s): 2008 250r (Fastest Color)
Wow that looks so clean. I have the newer model but I still love the way the old one's look...especially the super clean ones.
M-Oorb is offline   Reply With Quote
Old March 29th, 2009, 07:29 PM   #9
jonb08
jonb08's Avatar
Thanks! I took extra care in making sure that everything was done neatly. After chopping the fender, I filed where I cut with the hacksaw. The fender/wheel-well looked gritty after taking the hacksaw to it. After filing, I sanded the whole piece down and resprayed it black.
I also replaced the dark plastic piece in the brake light pod so that the license plate gets illuminated by the brake light.
Old March 29th, 2009, 07:35 PM   #10
sometimesido
Nice, that's about what I did.
Remember to put piece of tape on the hole on the wheel well right behind the tail light.
Helps to seal when you get caught in the rain.
my flickr™
Old March 30th, 2009, 02:04 AM   #11
jonb08
jonb08's Avatar
DAMNIT!!!! LOL. Thanks for the reminder.
Old March 30th, 2009, 04:40 PM   #12
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
My comp werkes fender elim does basically the same thing, but it's stainless steel and it's bolt-on. Comes with a stainless bracket and signal mounts if you don't want to pull the integration. And it comes with a clear plastic lense to replace the other one. The lense already has adhesive on it, so all you have to do is peel the tape and stick. And I think it looks pretty good. Same level of seal as the original, but with a little extra trunk space. It was probably more expensive than your alternatives though...
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old March 30th, 2009, 06:11 PM   #13
Snake
Snake's Avatar
How do you like the Two Brothers exhaust? Is it realy as loud as people say it is.
Old March 31st, 2009, 03:02 AM   #14
jonb08
jonb08's Avatar
It's loud for sure. Definitely not for people with sensitive ears. I need to get ear plugs because they might be damaging LOL. Thanks for the reminder.
Old April 14th, 2009, 06:44 AM   #15
cjkirch
cjkirch's Avatar
Motorcycle(s): 2009 Ninja 250R,comp werks fender chop, area p 18''(edited thanks to g21-30!!!) full exhuast, jetted
Comp werks elem.
I paid the 80 bucks for a comp werks eleminator kit, Does anyone know how to connect/wire the license plate light?
cjkirch is offline   Reply With Quote
Old April 14th, 2009, 07:18 PM   #16
Strange
Motorcycle(s): 2009 ZX-6R Monster Edition
I do believe thats why the bottom of the rear brake light has a clear lens on it. so it can be used as a plate light.
Strange is offline   Reply With Quote
Old April 15th, 2009, 04:11 AM   #17
jonb08
jonb08's Avatar
Yeah but it doesn't have a clear lens on it stock. You have to remove the solid lens and put your own clear lens on it.
Old April 15th, 2009, 11:50 PM   #18
Verus Cidere
Looks to me like you have a new gen bike. The ones we're talking about here are pregens. As to the lighting question, you might try something else?
Old May 5th, 2009, 05:47 PM   #19
ninjammin
Motorcycle(s): 2003 Ninja 250
That's definately not an 08+ if that's what you mean.
ninjammin is offline   Reply With Quote
Old January 18th, 2010, 06:57 AM   #20
Shano22
Shano22's Avatar
Motorcycle(s): 2005 Kawi Ninja 250, 2004 Honda CBR600 F4I, 1999 Yamaha TTR225(dirtbike)
take the little plastic cover out of the bottom of the tail light and then replace it with a piece of a clear CD case. Than since you have a running taillight, it will double as a plate light. Thats what i did at least
Shano22 is offline   Reply With Quote
Old January 18th, 2010, 07:49 AM   #21
sktrs_kpr
sktrs_kpr's Avatar
Motorcycle(s): 1990 Ninjette 250
Question for you pre-gen folks with the chop... I really like the way it looks, but I live back 1/4 mile of gravel and ride everyday - even in the rain pretty frequently. How much more crap do you get sprayed up on you after doing the chop? Does the tail light get dirt fast etc? I'm mostly worried about getting my backpack covered in mud/water since I keep my computer in there. Of course, if its raining I usually put a trash bag on it...
I like the chop, just not sure if it would be worth it for me.
Nate
'90 Ninja 250, 12k miles
sktrs_kpr is offline   Reply With Quote
Old January 18th, 2010, 08:46 AM   #22
Snake
Snake's Avatar
My license plate acts like a fender and keeps rain and other things from being kicked up. The chop has been worth it to me.
Old January 19th, 2010, 12:48 AM   #23
tapdiggy
Humble Observer
tapdiggy's Avatar
+1 on the license plate
Everything I post is "IN MY HONEST OPINION".
Why is "Parking Lot Enduro" not a thing?
[motorcycle-usa.com] - Harley Sportster Chopped Rear Fender Install Ninjette Newsbot Motorcycling News 0 April 10th, 2015 05:50 AM
Extra Brake Lights in pods = all other lights dimming CalvinAmI 1986 - 2007 Ninja 250R Tech Talk 23 October 16th, 2012 10:21 AM
Added lights to the rear pods - now having issue iplante 1986 - 2007 Ninja 250R Farkles 5 July 24th, 2012 12:47 PM
Jetting for K&N Pods 1994Ninja250F 1986 - 2007 Ninja 250R Tech Talk 10 January 25th, 2011 11:44 AM
k&n drop in vs pods Digiadaamore 2008 - 2012 Ninja 250R Tech Talk 24 October 1st, 2009 08:09 PM
