May 18th, 2013, 09:13 AM | #1 |
Promocycle: Some old but good studies on braking
http://www.promocycle.com/etudes-eng.html
"RISKS ARISING FROM A LOCKED FRONT WHEEL Locking of the front wheel must be avoided at all costs during hard braking because it leads almost automati- cally to a loss of directional control and a sideways crash if it persists longer than a tenth of a second. Fear engendered by this physical reality means that the majority of motorcyclists under-utilize the capacity of their front brake, especially at the start of braking. Thus it is of paramount importance to become proficient at the start of braking because the distance traveled is relatively greater than at the end of braking. ......... EFFECTS OF DECELERATION FORCE The mean deceleration for the group of 298 passes braking from 100 km/h to zero wa -0.898 g in a mean time of 3.18 seconds. During these more than 3 seconds, the rider had to manage his braking while subjected to a con- siderable deceleration force against his arms and hands which must in large measure support his upper body. A simulator designed to recreate this force would have to incline the motorcycle on its front wheel at an angle of 64 degrees. THE EQUILIBRIUM STAGE Each emergency braking maneuver is preceded by a stage of stabilizing the motorcycle. Although it may be very short, it is no less important despite the fact that it is little covered in the literature. Even when the motor- cycle gives the impression of rolling in a straight line, the rider makes constant adjustments to maintain equilibri- um among different forces and the chosen trajectory. At the moment of emergency braking, this equilibrium must be perfect and be maintained for the length of the braking maneuver. PRISONER OF POSTURE Once the emergency braking procedure is started, because of the forces engendered by deceleration on the arms and hands, the rider is a prisoner of his choice of the number of fingers employed on the front brake lever. During the course of intensive braking he must not modify the position of his fingers. DISTANCE VERSUS TIME Although there is a correlation between braking distance and time, it is not absolute. Thus the quickest stop from 100 km/h recorded during these tests lasted only 2.70 seconds but covered 37.68 meters. The shortest stopping distance recorded was 36.95 meters in an elapsed time of 2.75 sec- onds. This slight difference highlights the importance of an effective start to the braking procedure at the moment when the distances traveled are greatest. USE OF THE CLUTCH Downshifting: Should one downshift during emergency braking? Some observers maintain that it is preferable to downshift during hard braking in order to be in a position to accelerate again if the situation demands it. Others claim that during an emergency stop the rider must concen- trate exclusively on braking and that downshifting can only increase braking distances. We devoted an entire day (June 20, 2003) to this variable during which we recorded 77 tests with two differ- ent riders on the same motorcycle. The mean stopping distance for 31 tests during which the riders were instructed to downshift was 43.17 meters compared with the general average of 41.71 meters for the group of 298 tests. IDEAL SEQUENCE These figures indicate that the ideal sequence for the most effective emergency braking possible is to succes- sively close the throttle, apply the rear brake, apply the front brake and de-clutch completely."
September 29th, 2013, 08:41 PM | #2 |
September 29th, 2013, 10:05 PM | #3 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Good stuff Herman, thanks.
May 25th, 2014, 11:31 AM | #4 |
January 27th, 2015, 04:49 PM | #5 |
January 27th, 2015, 07:29 PM | #6 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Liked it just as much the 2nd time I read it.
Well worth the read!
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
January 31st, 2015, 09:03 AM | #7 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Braking can def get hairy when done at the limits so far so good
[crash.net - MotoGP] - Crutchlow: Motegi hard braking good for me | Ninjette Newsbot | Motorcycling News | 0 | October 7th, 2014 08:40 PM |
[motorcycledaily.com] - MD Project: Building a Better SV650 Part II: Braking Good (Bi | Ninjette Newsbot | Motorcycling News | 0 | August 30th, 2013 06:10 PM |
[sportrider - latest stories] - Late Braking: Two Different Motorcycle Crash Studies | Ninjette Newsbot | Motorcycling News | 0 | November 12th, 2010 06:21 PM |
Engine braking...good or bad? | ChaosFromAbove | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 28th, 2010 07:54 AM |
[webbikeworld.com] - New Motorcycle Safety Studies Released | Ninjette Newsbot | Motorcycling News | 0 | April 7th, 2010 01:50 PM |
