September 18th, 2013, 06:49 AM | #1 | |
Old Guy, New Bike
Join Date: Jun 2011 Motorcycle(s): 2011 Blue Ninja 250R, Yamaha SRV250 Posts: 133
DIY: Dynojet Autotune How-To with PCV
This is going to be a multi-part How-To for using the Autotune for your Power Commander V (PCV) that is adapted from an old post on the Yamaha Road Star Raider Motorcycle Forum by Capt_Zoom.
One thing I want to clear up before I begin is the idea that the Autotune will change your bike's performance on the fly. I've read this here and there on the Web, and the Dynojet site even seems to suggest it to be so, but this is just not the case. What the Autotune does is sample your exhaust gases and record recommended changes in the Air-Fuel Ratio to achieve the desired ratio as set in the Target AFR Table. The bike is running off the base map you have set and until you accept the changes recommended by the Autotune, there will be no change in how your bike runs. From Capt_Zoom: Quote:
Important links:
Some really important tips and notes to consider while reading this tutorial: a. Whenever possible, ride for a sufficient time to get a good map. This means ideally changes of less than 5% in your trim table. If you have more than a couple of cells that aren't less then 5% then it's possible you either have more riding to do or your base map was quite different from your actual system. Capt_Zoom claimed to have had 5 cells total that were over 5% and 3 of those were due to air reversion. He totaled 300 miles before trimming. I am not usually able to map for such distances or get better results the longer I ride, so I only map under controlled circumstances. (Since I have a switch on my Autotune, I turn it off before I begin to decelerate. I also don't usually map in normal traffic, only when I know I will be running at a given throttle position and RPM.)
Gaijinagain.com Mods: Tyga Stainless Exhaust, PC V, Auto-tune, Front/Rear Beet Hard Suspension Springs, Battlax S20-R's 110 front & 140 rear, BKMoto HID Projectors, Steel brake lines |
September 18th, 2013, 07:09 AM | #2 |
Old Guy, New Bike
Setting Up a Switch for Autotune
This should allow you to set-up a switch with which to turn your Autotune on and off. I use one and find it very convenient for controlling when I am mapping. Any kind of regular automotive switch will do. I believe the instructions for installing the switch on your Autotune are included in the basic installation instructions.
Before starting make sure your mechanical switch is off. Open power commander V then go to power commander tools select configure select Autotune when your in take check out of auto tune enabled put a check in the box for enable hardware switch click ok. Go back to power commander tools again and select configure, select map switch, put a check in the box and click ok. Open your base map on the main screen lower left side by clicking open map file then select send map. There should be a pop up on the lower left side that says select a position. Click position one then open another map and the same pop up will appear this time click position two. Now it will show both maps. Map one & two can be the same map. Now go back to power commander tools, select configure, select map switch. Take the check out of the box. Go back into power commander tools and select configure, select Autotune and put a check back in the box to enable Autotune, then click ok. Position one auto-tunes & position two does not. (Meaning position two is your base map.) Good luck! This, is not set in stone so if someone finds a better way to do it, please let me know.
September 18th, 2013, 08:10 AM | #3 |
Old Guy, New Bike
How to set up & use your Autotune with the PCV
Once you've installed the PCV and the Autotune, install the PCV software on your PC-based computer. Obviously a laptop is more convenient for this. Unfortunately, it is not available for Macs and I have yet to find a way to get it to work on my MacBook Air, so you'll have to use Windows for now. Go to Dynojet's website and download the all map pack. (See the link above) Make sure you are using the right maps for the PCV you have. I know there are two available units for the EX250, and I am using the newer M17-035 so I downloaded the M17-035-all.exe file. 1. You may need the numbers to find your starting map. (Although the Map desription section in the PC software includes the following information.) The current numbers are: For the 250: 17-035-000 Zero Map 17-035-501 European model Stock exhaust Stock air filter 17-035-502 European model Yoshimura full exhaust with baffle Stock air filter 17-035-503 European model Yoshimura full exhaust with baffle removed Stock air filter 17-035-all All Maps For the 300: 17-046-001 Stock exhaust, Stock or aftermarket air filter 17-046-002 Two Brothers slip-on, Stock or aftermarket air filter 17-046-003 Two Brothers full exhaust, Stock or aftermarket air filter 17-046-004 LeoVince slip-on exhaust, Stock or aftermarket air filter 17-046-005 M4 full exhaust, Stock or aftermarket air filter 17-046-006 Yoshimura R-77 full exhaust system Stock or aftermarket air filter 17-046-All All Maps 2. Place these maps in a folder on your PC (call it something easy to find, but I'm pretty sure that the PCV software saves them in the C://program file/power commander 5/maps folder). You might need to unzip these maps if they are in a zip file. You can also set up the Power Commander software to save them wherever you like. 3. Start up the software and open the base map you plan to use. You'll want a map that was made for your intake and exhaust setup, or as close as you can find. You can now create your spreadsheet and copy the name, date and cell values from the AFR, the Target AFR, and Trim tables into different sheets. 4. Plug your PCV into your computer via USB and turn the bike's key to the on position while running the Power Commander V program. 5. Double check your configuration. Some riders have had dealers do the install and never configured it properly. Make sure your Autotune is enabled and configured properly. See the manual to do this. 6. Select Open Map and select the map you want if it isn't already open. For my Japanese edition 250R with a Tyga full exhaust, no baffle, and an aftermarket air filter, I chose the Yoshimura with the baffle removed (Map 17-035-503). 7. Send this map to the PCV using the Send Map button. 8. Next fire the bike up and see if everything is still running well. You should be able to see your RPM and throttle position on the right of your laptop screen. A few words of warning here. You may not see your Autotune as being installed. In the settings you can set it up to wait a given amount of time before being activated. You can also set it to wait for a given temperature if you have the temp sensor wires installed. I think the default is one minute. So let your bike warm-up for a minute or so. You may still not see any changes. This is likely because the Target AFR or Trim table is set to 0 for the zero throttle position – which instructs the Autotune not to try to map at idle. If you want to see whether the Autotune is activating, set some numbers in the 0 TP range from 1500 RPM to about 3000 then send the map to your PCV. You should see that the Autotune light comes on. (Don't forget to undo the changes before you finish.) 9. If everything is good, close the Power Commander Software and unplug the laptop. 10. Take the bike for a ride. If you want to map, remember not to engine brake. If you installed a switch, then find a nice long stretch with few cars and try some mapping. I generally get the bike in 3rd or 4th gear at relatively low RPM's, flip the switch on, then hold the throttle at one position while the bike slowly accelerates to red-line. (RPM not MPH!!) I use a long straight uphill run to make sure I'm keeping torque on the back tire like a Dyno would. You can slowly increase throttle if you want, just don't decelerate. When you get to the end of your run, just flip the switch off before decelerating. Take your time and make as many runs as you can. You can try concentrating various runs on different throttle position/RPM combinations. (Cell location on the Power Commander software can be identified using throttle position and rpm.) 11. The OP for this how-to put 300-400 miles on the bike before messing with the trims. Dynojet assured him that this should enable a solid map to be made. While riding, try to not engine/gear brake by pulling in the clutch and using your brakes to slow down. This reduces air reversion which the PCV will read as an overly rich condition and will thus lean the maps cells for that throttle position and rpm. 12. Once you've ridden enough, connect your laptop again and check out your trim table. Most of your cells should say 5% or less. If you have a few that are more, it isn't a problem since we can fix these manually. 13. Copy the recommended trims into your spreadsheet. Examine your oddball cells (greater than 5% and random jumps or slumps in the vertical columns in adjacent cells.) Check the trim table and look at the coordinates (rpm by throttle position) of any cell that seems out of place. The OP had 4 cells in a line horizontally around 1200 and then another 3 vertically from 2500-3000 rpm. All of these except one (-11) showed up as 20's. This suggests he was getting reversion in these coordinates. After noting these coordinates, he went to the AFR table and entered zero into each of these cells. Entering zero makes the cell inactive to trim table changes...and will therefore use the original base AFR. He completed this for each of the suspect cells. An alternative is to make these cells the average of the cells around them but if you accept trim changes later it will change them. I always go over every cell in the spreadsheet, looking for odd changes when compared to adjacent cells. I then usually average them out. 14. You can add 2 or 3% into the zero throttle position in areas where you are getting popping on quick deceleration. Doing this should reduced the popping when you completely let off the throttle quickly. (I think mine are even a little higher.) I also added a bit in the 5% throttle position column to reduce backfiring when coming back on the gas at mid-range RPM's. 15. I usually copy and paste the cells directly from the spreadsheet to the Power Commander software, without simply clicking on the Accept Trims option in the Autotune settings. Then I make sure to click the clear Trims option so I can see how the new map performs. (A perfect map should have zero recommended changes, right?) 16. Send your new map to the bike after making the changes and save it with a name that includes the date – for easy reference. Save your spreadsheet as well. (Make sure that you don't overwrite your changes on the spreadsheet. It's good to be able to look at every step you take along your Mapping journey. Just make a new sheet labelled with the date so you can compare to all that have come before.) 17. Test ride your new map. If you like it then keep it. If not ride another 300 miles trying to prevent air reversion and repeat the above process carefully scrutinizing your trim tables cells. IMPORTANT NOTE: the Autotune is default set up to allow trim changes of up to 20%. If you don't scrutinize your cells and willy-nilly accept trim changes what happens is it will keep adjusting your AFR by up to 20% for each accepted trim. If you accept your trim 5 times you could end up with a 120% trim change from the base map you started from. If this happens you will likely run extremely rich, symptoms of which include killing, black smoke from exhaust like a diesel truck, and sputtering. If you get to this point get rid of your map and start over! The original steps in this How-to were given to the OP during a face to face conversation with a power commander rep. They talked about it for about an hour. Following these steps resulted in a map for his bike that was near perfect with great power, reasonable mileage, and very little popping. My mapping has also successfully gotten my bike to perform very nicely both on the street and the track. I still have a little popping, but am working on that little-by-little. I found that the maps available for the EX250 were not close to my set up, requiring more changes in the fuel mapping than usual. It has taken a while, but I believe that I am at somewhere around 80% in my mapping journey. Lastly, I have not experimented with making maps for both cylinders, making maps by gear, or changing the ignition timing. Power Commanders reps have stated that making a map for each cylinder isn't very beneficial since the jugs are less than 5% different so one map is sufficient for both. If someone has experimented with these please make a how to.
September 18th, 2013, 10:21 AM | #4 |
Good info.
/linked
September 20th, 2013, 02:03 PM | #5 |
Join Date: Apr 2013 Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150 Posts: 68
I have a problem with the autotune,where the trims only shows for the first gear. After that i make a connection from the PCV to the wire from the ECU. (Ninja 250R FI). Still did not shows gear change to 2,3 and so on.
What should i do? I do have a direct access to a dyno that i can use when i wanted to. |
September 20th, 2013, 11:29 PM | #6 | ||
Old Guy, New Bike
I think you have to create a fuel table for each gear when you want to do that. Since I don't map for each gear, I'm not sure. I would check the settings in the Power Commander software though, it sure sounds like your problem is with the configuration. Quote:
Did you use the PCV before you installed the Autotune? If so, did it perform okay?
September 21st, 2013, 11:17 AM | #7 |
thank you for the fast reply.
Sounds like maybe you set it up to map for each gear, but don't have the gear input set correctly. Or, you may have the gear input set, but haven't set target AFR's for each gear which means the Autotune wouldn't try to map anything except 1st gear. I think you have to create a fuel table for each gear when you want to do that. Since I don't map for each gear, I'm not sure. I would check the settings in the Power Commander software though, it sure sounds like your problem is with the configuration. - Yes, you are correct. i think everyone using it should map for each gear, as i dont think its good to have perfect map for gear 6th but the rest is not. I did the speed input by connecting the speed signal (IIRC the 5th wire on the ECU) to the PC V. Did your setup is different than mine? i will tinker with the software again as per suggested. Sorry, I'm not sure what you mean. The Autotune has to be connected to the PCV in order to map. The PCV also should be installed correctly and working properly to use the Autotune. Did you use the PCV before you installed the Autotune? If so, did it perform okay? Yup, the autotune is connected.The PCV is installed by a friend,and was straight connected to the Autotune. I might check on that again as my friend might screw up on that! |
DIY Dynojet o2 eliminator | PeaceSold13r | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 14th, 2015 09:07 AM |
Power Commander PCV $220 | Rekognize | Motorcycle-related | 4 | September 21st, 2013 11:42 AM |
300 Autotune | flurbadurba | 2013 - 2017 Ninja 300 Tech Talk | 9 | September 19th, 2013 04:18 AM |
PowerCommander V (PCV) | Guinss | 2008 - 2012 Ninja 250R Tech Talk | 16 | July 9th, 2010 09:11 AM |
