Old September 24th, 2013, 07:00 PM   #1
cuong-nutz
cuong-nutz's Avatar
The Guts of the Ninja 250 gas cap lock
I'll do a write up eventually. I'll let the pictures speak for themselves for now.
HalfFast Racing Team
Last futzed with by cuong-nutz; September 25th, 2013 at 08:26 PM.
Old September 24th, 2013, 07:44 PM   #2
Panda
not an actual panda
I think @Skippii did a write up on the gas cap as well.
Old September 24th, 2013, 07:47 PM   #3
IF13
WOT WOT WOT
Motorcycle(s): '12 Ninja 250R
Those float screws almost screwed me over while I was doing the vinegar rust treatment.
Didn't realize they don't actually screw into the tank but on the elevated square platform.
May your roads stay clear....
IF13 is offline   Reply With Quote
Old September 25th, 2013, 08:36 PM   #4
cuong-nutz
cuong-nutz's Avatar
Yep he made one:
http://www.ninjette.org/forums/showthread.php?t=102020
I went as far as removing the whole key tumbler which needed a whole lot of cleaning due to someone drilling it out. Lubing up the tumbler helps a lot too.
I only had a gallon of vinegar to use and my petcock is still leaking which I need to trace down as to why.
Old September 26th, 2013, 06:53 PM   #5
IF13
WOT WOT WOT
Originally Posted by cuong-nutz View Post
Yep he made one:
How do you have it capped off?
I used a rubber sheet with two screw holes then screwed it down with the petcock (w/ filter removed of coursed) to distribute pressure against the middle hole. Works like a charm. Tank still leaks but from the overflow hole, I have a rag soaked in vinegar at the top so I guess at nights, condensation collects and runs down the overflow hole.
EDIT: Does saying your petcock's leaking imply that you have vinegar in there while the actual petcock assembly is still attached? Isn't that an aluminum composed device? That's not exactly a good thing to have bathed in an acid albeit minor one.
Old September 26th, 2013, 07:43 PM   #6
cuong-nutz
cuong-nutz's Avatar
Petcock still attached. I didn't have anything available to seal it and think anything of it. I guess that's not a good idea now lol. I'm thinking the gasket or rubber seals are bad. It was leaking before the vinegar treatment.
Last futzed with by cuong-nutz; September 27th, 2013 at 03:30 AM.
Old September 26th, 2013, 08:37 PM   #7
cuong-nutz
cuong-nutz's Avatar
Looks like the vinegar cleared out the blockage or gummed parts in the petcock. The diaphragm seems to be operating as it should visually. Only one way to find out for sure.
Old September 27th, 2013, 12:40 AM   #8
IF13
WOT WOT WOT
I suppose its okay for a quick bath unlike mine.
It's been soaking since.....I think Monday.
Old December 30th, 2013, 04:32 PM   #9
tyrone393
Motorcycle(s): '12 ninja 250r SV650N
Thanks for the pics but how in the world do you get to the check valves? I have all the screws out and it seems like the lock is holding it together. Any help would be great!
tyrone393 is offline   Reply With Quote
Old December 30th, 2013, 05:02 PM   #10
cuong-nutz
cuong-nutz's Avatar
You should be able to pull it off. It may be just stuck together. You could push the key cylinder out but be super super careful because the brass tumblers can come out flying g with the springs.
Old December 30th, 2013, 05:18 PM   #11
stubshaft
Rode with the Dinosaurs..
stubshaft's Avatar
Motorcycle(s): '08 Ninja 250
Subscribed!
Fortune favors the brave!
stubshaft is offline   Reply With Quote
Old December 30th, 2013, 05:40 PM   #12
tyrone393
i have tried to pry twist push tap and even bent the pot metal cover a little ( i hop not to much). it is new and looks clean but is building up alot of vacuum and i think the valves are dirty. any more suggestions?
Old December 30th, 2013, 05:54 PM   #13
cuong-nutz
cuong-nutz's Avatar
Ah... you might need a to get a pick or a thin flat head to depress a tumbler from the bottom to get it to come out towards the gas cap opening.
here's something similar:
http://chriskraftphotography.smugmug...7590&k=f7HXQWB
Old December 31st, 2013, 06:44 AM   #14
tyrone393
thanks that was it!
