March 28th, 2009, 08:39 PM | #1 |
DIY: Installing Pazzo Adjustable Levers
We've had pictures of the levers online, but no DIY that I could find, so I thought I'd post one up for everyone. This is for the installation of the long levers. I debated about getting the shorties, but after hearing how short they really were, I decided to go with these.
First part is to gather the tools that you'll need. You need both an 8 mm socket for the nut on the bottom of the pivot bolt for the clutch lever, and a 10 mm socket for the top of the pivot bolt on both levers, and for the lock nut on the bottom side of the brake lever. You will also need some silicone grease, a torque wrench, and of course the levers! I started with the brake side. First remove the lock nut from the bottom and then loosen and remove the pivot bolt. The lever will slide right out and you can slip the new lever in its place. You will then slip in the pivot bolt and nut and tighten it to 52 inch-pounds of torque. That's what it looks like when it's put together , just imagine that it's actually in the holder for the full effect The clutch side is a little more complicated with the clutch cable installed. First remove the nut from the bottom of the pivot bolt using the 8 mm socket. Then you should loosen the knurled locknut (larger clutch nut) by turning it towards the rear cowling. You want to screw in the adjuster towards the lever to give it as much play as possible. Once it is all the way in, align the slots in the knurled locknut and the adjuster nut with the slot in the backside of the lever. I found that it was easier to lift the lever off and flip it over, then do this. Slide the end of the cable into the opening on the pazzo lever, and then slide the lever into place and replace the pivot bolt. This pivot nut does not have a torque spec. Here is a comparison on the clutch side so you can see the difference in stock and the #6 position on the pazzos. I didn't think to do a comparison on the brake side, so there's just the after pic. And the brake side: There are more pics available here: http://picasaweb.google.com/nochecal...eat=directlink And lastly, here are some pics of the levers installed (I'm not sure why the top of my windscreen looks blue - it's not, really!) |
March 28th, 2009, 08:45 PM | #2 |
Since you'll have the end of the clutch cable off anyway, this is the perfect time to clean and lube the clutch cable!
http://www.ninjette.org/forums/showthread.php?t=10016 |
March 28th, 2009, 08:54 PM | #3 |
cool DIY...
so, how do they feel in comparison to the stock levers? |
March 28th, 2009, 09:30 PM | #4 |
Great DIY! Added to the DIY index thread...
March 28th, 2009, 09:32 PM | #5 |
Curiosity is a Killer
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250 Posts: 102
Yes, how do they feel??
March 29th, 2009, 02:14 AM | #6 |
Join Date: Oct 2008 Motorcycle(s): 08 250 R Posts: A lot.
Thanks for the write up!! I am looking to get the shorties but saw some today on a 1400 and yikes they are short.
"Don't let adverse facts stand in the way of a good decision" Colin Powell |
March 29th, 2009, 08:36 AM | #7 |
They are amazing from what I can tell so far - I just put them on Friday night and it's been raining here, so I haven't had a chance to take her out yet - I will update when I get to ride more- but as you can hopefully tell fro the pics, it's a world of difference in terms of how much of my hand I can get around the lever - it doesn't seem quite as painful or difficult for me to securely grab on- especially on the clutch side - 2 thumbs up!
March 29th, 2009, 11:11 AM | #8 |
it was painful for you to grab the stock lever?
March 29th, 2009, 12:45 PM | #9 |
after I rode I would have the ligaments in my thumb flaring up - I have issues with them called gamekeepers thumb - basically it was straining the ligaments in my thumb when I was reaching out that far and trying to keep a hold on the handlebar as well
The first time I rode, I couldn't write the next day because of it... this seems to be a very large improvement so far |
March 30th, 2009, 02:43 PM | #10 |
IC2(SW)
March 30th, 2009, 02:46 PM | #11 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Nice DIY Kim - not sure I'll ever change mine but if I do and now know how to do it.
Thanks
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
March 30th, 2009, 08:21 PM | #12 |
Join Date: Jan 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 83
Damn it! another mod I want to do. lol very nice looking levers and thanks for the DIY. question, is #6 the lowest setting on these or can they go lower?
March 30th, 2009, 10:04 PM | #13 | |
Join Date: Dec 2008 Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150 Posts: 223
I put on a set and like them a lot, but would not recommend going below #3 for the brake lever. If you shorten the throw too much, you don't have enough distance to fully engage the brake because you will squeeze the lever into the grip before the brake is fully engaged as in a full on emergency stop. I also found myself squashing my fingers at #2 because I brake with two fingers rather than all of them. Just a warning that closer is not necessarily better. Last futzed with by Ichiro; May 16th, 2009 at 02:20 PM. |
March 31st, 2009, 09:29 PM | #14 |
Some weird Canuck!
Join Date: Dec 2008 Motorcycle(s): '92 CBR250RR "Babyblade", 2008 Ninja 250R, 2001 CBR600F4i Posts: 209
I have had Pazzo's on my last 3 motorcycles. Pazzo Shorty's. I LOVE them and will continue to put them on every bike I own. CRG makes a nice lever too. The levers feel great, look great and everyone notices them when they get up close to the bike. Its a touch of class with some functionality in it. Great mod!
May 16th, 2009, 01:38 PM | #15 |
Join Date: Mar 2009 Motorcycle(s): 2009 BLACK Kawasaki Ninja 250R Posts: 164
I just got these installed! Great DIY! Thank you!
May 16th, 2009, 01:45 PM | #16 |
Join Date: Apr 2009 Motorcycle(s): 08 Ninja 250r Posts: 156
I'm considering the Cycle Control ones which are due out in a couple of weeks - they look pretty similar... (Anyone have experince of their levers on other bikes??)
After riding to work and back (lots of slow speed stuff in traffic) with the stock clutch I get sore thunb ligaments too... I've got quite small hands and it really looks as though these will help! Nice DIY Kim
Bristol, UK - R&G Tail Tidy, Exhaust Hanger, Bar ends & Crash Protectors, Skidmarx Hugger & Double Bubble, SW motech mirror extenders, Scorpion Exhaust, Cycle Control levers & Rearset Adjusters |
May 16th, 2009, 04:53 PM | #17 |
Thanks guys- glad it can help
May 28th, 2009, 07:07 AM | #18 | |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
A change to Galfer braided lines, with no flex, and #3 is not only comfortable, but offers more brake force than #4 and rubber lines. For the clutch, on my bike, #3 is the most comfortable to me. I found that position 1 and 2 for the clutch was not enough travel to ensure that the clutch was fully disengaged.
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
May 28th, 2009, 10:13 AM | #19 |
Psychic war veteran
June 5th, 2009, 01:24 PM | #20 | |
June 6th, 2009, 06:00 AM | #21 | |
Psychic war veteran
In any case, even then with the clutch, using #1 position the clutch is still grabbing just a little bit with the lever against the grip. #3 just feels, to me, like I'm sure the clutch is fully disengaged. As for the brake, for me, anything lower than #3 and it hits the grip before it feels like 100% brake, and in traffic like I have, I like a little more confidence than 'lever at the grip' for my own peace of mind. #2 and 100% is at the grip with nothing extra, and #1 just never felt like the same authority on the brakes as #2 or above. Several other guys in my area have Pazzos on their 250s, too. It must be a guy thing. We all seem to have settled on #3.
June 6th, 2009, 07:05 AM | #22 |
self wrencher
Anyone know where's the cheapest place to get the Pazzo?
June 6th, 2009, 07:43 AM | #23 |
Psychic war veteran
Click here for where I got mine I think Pazzo has a MAP (Minimum Advertised Price), and that seems to be universally $179 for any combination you want.
June 6th, 2009, 07:57 AM | #24 | |
June 6th, 2009, 12:17 PM | #25 |
IC2(SW)
^ We have the same pro-grips. Setting #1 on the brake doesnt hit the grip, doesnt even come close. We run it on #2, it will just hit our small fingers in there if we pull real hard.
The clutch we run on #2 also. Althou we had to file the tip of the clutch switch, so it would start in gear with it on setting #1 or 2 |
June 7th, 2009, 07:22 AM | #26 |
Psychic war veteran
OK, I went back and actually LOOKED at it and you're right. Even on #1 it doesn't touch the grips. It FEELS like it touches the grips with my hands, but looking at it, it does not touch. I guess that's what I get for having long, thin fingers and palms!
June 15th, 2009, 01:26 PM | #27 |
Join Date: Mar 2009 Motorcycle(s): 08 Ninja 250 Posts: 67
just have to come on here and say that I !@#$kin LOVE these!!! i got the green shorties and they are perfect! i can grab the clutch and breaks with full hands even with the shorts...lol.
i have both clutch and break on setting 1. on clutch i thought 1 would be too tight so i was using 2, then i realize it was just a matter of getting used to it. i can now actually signal right when the clutch is engaged. still can't do a left but oh well! better than nothing. |
August 23rd, 2009, 09:24 PM | #28 |
Join Date: Jul 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 410
Installed my Pazzo levers this evening and they feel so good! So far position five is just right.
Had something weird happening when installing the clutch lever I thought I'd post here if anyone has any ideas... I lubed the clutch cable and put the lever in the perch and re-installed the pivot bolt. When I pulled the clutch lever for the first time I heard a pop from the other side of the bike and when I looked, the end of the clutch cable had come off of the arm that it anchors to. It seemed like I didn't have any cable slack at all, so having already backed out the adjuster at the lever end, I backed out the adjuster at the other end to get the cable back into the arm, reset the adjusters at both ends and then re-tensioned the clutch cable successfully. The three weird things: 1. The clutch cable popping out, where did the slack go? 2. When I was manipulating the arm it was pretty easy to slide it almost all the way out of the clutch case, is that normal or did I break something inside? 3. Is it normal for the cable to pop out at the engine-end like this if there isn't enough slack? Again, after a ride everything feels and works fine and I triple-checked everywhere to make sure I didn't miss anything, gonna bring this up with the dealer when I go in for the 1000km service. |
August 24th, 2009, 02:01 PM | #29 | |
Only difference in installation I found was that you have to remove the electrical housing on the to get the CC clutch lever to fit. Getting that thing back together with the choke cable can be a bitch.
Black 08 250r: Koso dash, yoshi cf slip-on, bikemonkey led, puig windscreen, cc rearset adjusters and shorty levers, shimmed, de-snorkel'd, de-kleen'd , 14/39 gearing, x-ring chain... |
August 25th, 2009, 04:58 AM | #30 |
IC2(SW)
August 25th, 2009, 09:20 AM | #31 |
August 29th, 2009, 12:36 AM | #32 |
I thought it would be easier than moving the lever mount but when I loosened the two screws the thing blew up on me! Lots of little parts to align.
September 8th, 2009, 02:58 PM | #33 |
Join Date: Feb 2009 Motorcycle(s): '95 BMW K75 Posts: 188
Make sure you're applying pressure to the nut and not the bolt (which is only rated to 9 in/lb). Have your torque wrench on the bolt as you tighten and it'll break well before 52 in/lb... Doh!
September 8th, 2009, 03:22 PM | #34 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250R Posts: 89
Got any pictures of the installed Cycle Control levers?
October 2nd, 2009, 09:21 PM | #35 |
Join Date: Sep 2009 Motorcycle(s): 08 ninja 250r modded, 73 honda cl200, 74 kawasaki 400 triple Posts: 255
i looooove these levers....i originally ordered the long ones too because i cover the clutch while riding and i am used to resting all 4 fingers on the clutch lever...when i got them in i changed my mind and sent them back for the shorties...sooooo glad i did...i love being able to use 1 finger...especially on the break....thanks for the diy!!!
October 2nd, 2009, 11:21 PM | #36 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
I just got some Cycle Control levers for my pregen, and it's very interesting... They look exactly like the pazzos, except they have 7 adjustment options instead of 6.... Wonder why? Oh, and just in case someone was wondering, I bought the Ninja 500 levers and a new clutch perch. They work great, but they're also A LOT closer to the bar than the new gen ones. Like closest is about an inch away! Completely pointless if you want to fit your hand through, but I generally ride covering the clutch anyway, so it doesn't make much difference on that side. It still disengages all the way, so what does it matter right?
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
October 6th, 2009, 05:50 AM | #37 |
Join Date: Dec 2008 Motorcycle(s): '09 ninja 250 (blue) Posts: 295
Question: Are you guys getting the Pazzo/Cycle Control levers because you have small hands and they're more comfortable or for aesthetics? Or maybe a combination of the two? I ask b/c I love they way they look and am considering purchasing a set. I was just curious as to everyon'e reasoning behind their purchase. I am a slow purchaser - meaning I mull things over for a while before I make a decision. I JUST bought the no-cut brake modulator from Randall and installed it this weekend. (shame, I know) (LOVE it by the way).
A woman is like a teabag; you never know how strong she is until she's in hot water! |
October 6th, 2009, 06:39 AM | #38 | |
The shorty Cycle Control lever fixed that problem for me, so now I get through the friction zone with the force on the strong parts of my fingers, rather than trying to control the lever with just my fingertips. I also mounted the lever about 1/4" closer to the fork, so I can comfortably use only my index and middle fingers on the clutch and keep my ring and pinky on the bar. |
October 6th, 2009, 06:43 AM | #39 |
Hmmm.....thanks Steve. I'll have to take note of how my levers are working for me. I am tall so I don't have small hands. If nothing else though, I would like the Pazzos for the color match though.
October 6th, 2009, 10:06 AM | #40 |
IC2(SW)
Look good, Feel good, and are great for peeps with small hands.
Pazzo levers | SteveL | General Motorcycling Discussion | 1 | December 31st, 2012 09:10 AM |
Green adjustable shorty levers (pazzo replicas) | Shaol1n Monk | 2008 - 2012 Ninja 250R Farkles | 14 | July 23rd, 2011 12:18 PM |
DIY: Installing Halos | tlhamon | 2008 - 2012 Ninja 250R Tech Talk | 26 | October 27th, 2010 08:40 PM |
Int. Tail Light w/extras, Pazzo Levers, OEM levers, SSR hanger, Area P Exhaust | petiteninja | Motorcycle-related | 15 | October 5th, 2010 08:13 PM |
New Adjustable Pazzo Clutch Lever Installed - PICS | muffinman | 2008 - 2012 Ninja 250R Tech Talk | 42 | April 27th, 2009 06:18 PM |
