June 10th, 2009, 08:49 PM | #1 |
Spools That Actually Fit? Lets End The Confusion.
Ok, first off I did a search for spools and read almost all of the threads that I found so please dont flame me. I need to get a set of spools for my 08. I know that Kawasaki spools are 10mm but some of the spools that fit other Kawis wont fit on the 250. This is because the spool mounts on the swingarm are not flush and have a small gap. I got a set of STM Italy spools for a good deal. As usual, because of my never ending luck....they didnt fit properly. I thought they came with a spacer so they could fit snug against the swing arm mount but they didnt. So here is what I would like you guys to do. Please reply with which spools will fit on 08 and up 250s. Now when I say fit I dont mean that there is a small gap because the spools are not tapered. Post up the ones that sit FLUSH into the mount and fit PROPERLY. Pics would be great. I thinks this would clear up alot of confusion on which 10MM spools fit. I will edit as we go, maybe this can be a sticky? Thanks!
10MM STM Italy Spools DO NOT FIT. T-REX 10MM Spools FIT.(Might need to file them down to get them snug) Pit Bull Spools FIT with included spacer. Shogun Spools FIT. Vortex Spools FIT. OESaccessories.com 250R Spools FIT. Last futzed with by Brad Turner; June 11th, 2009 at 08:27 PM. |
June 10th, 2009, 09:08 PM | #2 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
T-Rex 10mm spools fit fine. I just had to file a flat spot on the spacer so it would be snug against the swingarm.
June 10th, 2009, 09:10 PM | #3 |
Sarcasm: Yea that'll work
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250R Posts: 330
I didn't do anything to my t-rex spools to make them fit....
'08 Blue - Seat Cowl - A-Tech CF Fender Elim - Zartan's Exhaust Hanger - Dynojet Kit - Drilled Slides - Snorkel Removed - K&N Drop In Air Filter - Tech Spec Grips - Sportisi Windscreen & VR Exhaust |
June 10th, 2009, 09:28 PM | #4 |
Pitbull spools work fine with their included spacer.
June 10th, 2009, 09:35 PM | #5 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
How about a washer or two?
welcome to the forum.
June 10th, 2009, 09:40 PM | #6 |
June 10th, 2009, 09:45 PM | #7 |
One 10mm washer on each side an any spool fits. ur gonna loc-tite them anyway right?
June 11th, 2009, 02:00 AM | #8 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
i have the shogun crash kit which includes the swingarm spools. they fit perfectly as far as i can remember.
June 11th, 2009, 02:39 AM | #9 |
old git
Join Date: Mar 2009 Motorcycle(s): BMW K1300S Posts: 479
The 10mm refers to the size of the bolt and has nothing to do with the spool’s diameter or length.
Steve
Some mistakes are too much fun to make only once. |
June 11th, 2009, 04:48 AM | #10 |
IC2(SW)
Vortex spools bolted right up
June 11th, 2009, 05:06 AM | #11 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r (Fastest Color) Posts: 914
+1 for vortex...yet my actually bolt inside the spool now has surface rust and looks not so cool
Posted via Mobile Device |
June 11th, 2009, 09:14 AM | #12 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 250r Posts: 69
I use vortex too but they wouldnt fit cuz of all the paint on the inside so I had to get a tap and clean the paint out.
"When I die I want mud on my jump boots, magazine empty, and barrel hot." |
June 11th, 2009, 09:39 AM | #13 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
Here is a left side view of the T-Rex spool installed. No filling for fit.
June 11th, 2009, 10:30 AM | #14 | |
And a 10mm washer fits over a 10mm bolt.
June 11th, 2009, 11:14 AM | #15 |
I'm going to take some pictures now to show you guys what I mean when I said I filed them.
Pics aren't that good, just found out the main camera's LCD screen is broke. Yay! - Hopefully you can see what I actually filed here. If I hadn't filed this it wouldn't have been flush against the area for spools, it was hitting the swingarm. |
June 11th, 2009, 01:00 PM | #16 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150 Posts: 223
T-Rex wouldn't fit at all. Vortex fit perfectly on my '08.
June 11th, 2009, 01:17 PM | #17 |
I got mine from an ebay seller, nothing fancy and they fit fine
June 11th, 2009, 01:56 PM | #18 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250R (sold) Posts: 356
June 11th, 2009, 01:59 PM | #19 | |
June 11th, 2009, 02:21 PM | #20 |
June 11th, 2009, 02:47 PM | #21 |
I already said that my T-rex 10mm spools fit without any problems or modifications, so did a few others. Therefore, they fit, lol.
June 11th, 2009, 02:49 PM | #22 |
June 11th, 2009, 08:08 PM | #23 |
No idea. It goes over my head.
The only thing I can think of is the aforementioned problem with the paint being laid on too thick in the threads. Some people have had to tap those threads, maybe he had the same problem? I had to give mine a little extra nudge on one side, but no issues.
June 11th, 2009, 08:28 PM | #24 |
Thanks for all the replies, lets keep 'em coming.
June 12th, 2009, 11:14 PM | #25 |
Could be that I was sent the wrong size because there was no way they would fit. It was not an issue of paint in the threads;they were just too big. If it was due to the paint, the Vortex spools wouldn't have fit, but since the 10mm Vortex spools fit perfectly, the only thing that makes sense is that the T-Rex's were the wrong size.
June 12th, 2009, 11:20 PM | #26 | |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
June 15th, 2009, 01:00 AM | #27 | |
old git
Steve
July 12th, 2009, 09:02 PM | #28 |
Does anyone know if any of the other Kawasaki bikes use the same spools, including the spacer? I want to pick up some spools and a stand in the next day or two, and all of the shops near me don't stock spools specifically for the 250. Looks like I can get any of these brands: Shogun, Vortex, STM, Woodcraft or Sato
July 13th, 2009, 09:04 AM | #29 |
Steel Horse (cycle gear carries 'em) spools wouldn't fit without some filing, similar to what k-os did. The picture at the cycle gear site doesn't show them, but these come with two conical aluminum spacers and these are what need filed in order to clear the swing arm. http://www.cyclegear.com/spgm.cfm?L1...em=STE_SP6MM_G
July 13th, 2009, 10:39 AM | #30 |
Join Date: Dec 2008 Motorcycle(s): '09 ninja 250 (blue) Posts: 295
A woman is like a teabag; you never know how strong she is until she's in hot water! |
July 13th, 2009, 02:28 PM | #31 |
Some weird Canuck!
Join Date: Dec 2008 Motorcycle(s): '92 CBR250RR "Babyblade", 2008 Ninja 250R, 2001 CBR600F4i Posts: 209
I have vortex here as well, but the vortex supplied bolts rusted badly.
I still like CBR's more Just kidding. |
June 19th, 2010, 10:04 AM | #32 |
Join Date: Jun 2010 Motorcycle(s): 2008 Kawasaki Ninja 250 Posts: 206
Need to Tap mine so they fit
I bought some rear spools so I can put my bike up on the rear stand and they are 10mm and don't fit. Where can I take my bike to get the paint cleaned out so they do fit?
June 19th, 2010, 10:11 AM | #33 |
Join Date: May 2010 Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color Posts: 285
I have the OES ones they fit fine... just came with CROME bolts not black looked really tacky but a rattle can fixed that.
"Well you know, for me, the action IS the juice" |
June 21st, 2010, 07:12 AM | #34 |
Got some from Harbor Freight for $5... Work perfect so far
http://www.harborfreight.com/motorcy...0mm-66926.html
July 28th, 2010, 01:31 PM | #35 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
anyone know if these will fit? they are 10mm, but don't come with spacers...i suppose i could use some washers, but nobody seems to have the pit bull spools in blue, in canada.
http://www.eurocorsa.com/cgi-bin/com...ey=50AFF10-BLU EDIT: Bought the PBR spools, fit with a couple M10 washers per side. I had to file the washers down a bit to keep them from hitting swing arm as well. Last futzed with by kamikaze; August 22nd, 2010 at 04:37 PM. |
July 28th, 2010, 05:40 PM | #36 |
Kevin 2009 Ninja 250R |
July 28th, 2010, 10:49 PM | #37 |
Join Date: Sep 2009 Motorcycle(s): 08 ninja 250r modded, 73 honda cl200, 74 kawasaki 400 triple Posts: 255
i have t-rex...perfectly snug
