October 12th, 2009, 05:10 PM | #1 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
DIY - What Electrical Items Can be Used and Not Overload the Battery?
Since I just ordered a Gerbing Heated Jacket Liner (GHJL), I decided to calculate what the potential load might be on the Ninja 250 charging system, before adding the GHJL to the bike.
I reviewed the '08 Service Manual Electrical Schematic and came up with the following: EDIT: See PDF thumbnail for details As you can see, if for some reason every warning light came on at the same time, while making a right or left hand turn, and blowing the horn, without the brakes on, the total wattage is 227.6 (Column labeled Watts). Doing the same thing, while applying the brakes, the total wattage is 243.6. Since the max wattage available is 266, the charging system is adequate for the Ninja 250 under this very unlikely load. Still using the factory headlights, let's look at what might be considered a NORMAL load, i.e. not making a turn and not blowing the horn, but applying the brake every now and then. This is depicted in the column labeled NORMAL. It's very unlikely that all the warning lamps would be on, so there is an additional 13.2 watts to play with, if you wish to do that exercise. This yields 70-88 watts. The GHJL needs 77 watts!!! This obviously works, since Alex (the moderator) runs one with factory lights. By converting to HID headlights, this exercise can be repeated and those results are depicted in the next 2 columns. Enjoy and please check my calculations! |
October 12th, 2009, 05:15 PM | #2 |
Nice work!
October 12th, 2009, 05:17 PM | #3 |
Thanks! I'm lazy and didn't want to break out my amp probe to measure the load on the battery!
October 13th, 2009, 06:20 AM | #4 |
Join Date: Nov 2008 Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold) Posts: A lot.
Thanks Sam. Great to see it all out there in black and white.
October 13th, 2009, 08:36 AM | #5 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Great work Sam. Facts always beat guessing.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
October 13th, 2009, 09:31 AM | #6 |
Nice summary Sam, thanks!!
October 14th, 2009, 08:46 PM | #7 |
Should handle your Viberider, no problem.
October 15th, 2009, 04:49 AM | #8 |
April 30th, 2010, 06:08 PM | #9 |
Join Date: Apr 2010 Motorcycle(s): 2010 Ninja 250r Posts: 20
thanks for the specs, I really needed that. Thanks again.
Mark
I never fail... I only succeed in finding out ways to do something that don't work out. |
August 29th, 2010, 08:46 PM | #10 |
So, HID lights use less than incandescent? Good to know. If I upgrade to LED lighting for all turn and brake lamps, would the savings be significant or would the load resistors cancel it out?
September 9th, 2010, 04:38 PM | #11 |
When it comes to electrical loads, the math is a little over my head, but based on what I have read, you would still get a savings with LEDs. Since everyone who has them needs to increase the load somewhat, I doubt your setup would add any more then theirs. Also, the tail light is the only potential LED light that will remain constantly on.... Bottom line is, I have yet to hear of someone running out of power for their accessories, although it is theoretically possible. Personally, if I went on a trip with my GPS, or with heated gear, they would be different types of trips.... so they wouldn't be used at the same time anyways. It is good to research first, but I think you are good.
September 11th, 2010, 09:32 AM | #12 | |
Join Date: May 2009 Motorcycle(s): 2007 EX250 (street), 1994 EX250 (Race), 2008 250R (Race), 2000 250 (project), 1991 EL250 (a cruiser!) Posts: 287
Turn signals are the only lights that you'd need load resistors for. If you do want to switch these to LEDs and you care about the increased efficiency I would recommend skipping the load resistors and getting an electronic flasher. |
September 27th, 2010, 05:44 AM | #13 |
Join Date: Apr 2010 Motorcycle(s): 09 Ninja 250 SE Lime Green/Diablo Black Posts: 126
So I'm looking to pick up the Gerbings jacket liner and the heated gloves liner. They come in at 77 W and 27 W for a total of 104 W. On a stock bike, I apparently only have 88 W to work with.
I commute for 40 minutes each way (90% highway, at 120 km/h/70mph/9k rpm), sometimes longer due to traffic. I understand that by running this gear, I risk draining my battery because the alternator won't be able to charge it. What are my options here? Should I get a battery tender to charge the bike overnight? Should I get the overpriced temperature controls, to limit the power draw? |
September 27th, 2010, 06:03 AM | #14 |
Yes. Without a temp controller, the jacket will be uncomfortable anyway.
September 27th, 2010, 07:54 AM | #15 |
Also, go to Gerbings discount outlet:
http://www.heatedclothingoutlet.com/index.shtml That's where I got my jacket liner and glove liners! I keep my bike on a battery tender pro year round, even during the riding season, when the bike is parked at home. |
September 27th, 2010, 09:41 AM | #16 |
If you are concerned about running out of power, you may want to get a gauge that reads your electrical output (you would have to mentally subtract what you are pulling from it, I think.... unless it reads what is left.
September 27th, 2010, 10:08 AM | #17 | |
DATEL Voltmeters are highly recommended for their accuracy and durability. |
September 27th, 2010, 11:43 AM | #18 |
^^^^ Or you can use one of the clamp-on amp meters and read what is being used realtime!
September 27th, 2010, 03:43 PM | #19 | |
Oh yeah.... I guess it is functional too |
January 5th, 2012, 07:38 AM | #20 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
I was wondering whether a gps would fit in, I've had no issues so far. I have a LED tail light and I removed the rear turn signals, so that helped a bit...I guess.
January 5th, 2012, 08:25 AM | #21 |
GPS draws very very very little, so you don't need to worry.
January 6th, 2012, 10:38 AM | #22 | |
My phone can do at least 2 hours of GPS duty from a 1600mAh battery; That's about 3.7Vx1.6Ah = ~6Wh. So if your GPS draws more than 3W, I'd be very surprised. --- Interesting thing I noticed between the EX250R-J8F and EX250R-K8F manuals' general specs. The K (mine) is a fuel injected with 23.0A/14.0V @ 5000r/min, the J is listed as Carbureted with 19A/14V @ 5000r/min. So the J is 19x14V max = 266W. The K is 23x14V max = 322W. One thing the original poster did not list, is that the engine itself actually needs power for the ignition spark. I assume that extra 4A was considered neccesary for the fuel injection. The K battery is also 12V 8Ah (96Wh) the J is 12V 6Ah (72Wh). |
June 11th, 2012, 06:20 PM | #23 | |
August 5th, 2012, 07:38 AM | #24 |
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 Posts: 3
Ignition Load on the Alternator
I noticed that the loads that were quoted from the service manual in this thread did not include the ignition circuit. I removed the ignition fuse on my 2010 and plugged my multimeter in and measured the current:
at idle ~1.5 amps => 21 watts at 14V rev'd up (no load) just under 2 amps => 28 watts at 14V The load may go up with the engine under load, but I doubt it and if so probably not very much. However, an extra 28 watts is a considerable load not included in the original post, so I thought I would add this. (I'm adding a radio and a 12v power plug so I've been checking into how much alternator overhead is available.) |
August 5th, 2012, 10:22 AM | #25 |
2A seems quite low. That would mean an 8A.h battery could run it for close to 4 hours?
August 7th, 2012, 07:36 PM | #26 |
August 7th, 2012, 11:51 PM | #27 | |
That's what I was referring to, and I consider 2A to be surprisingly little. You could then strip out the generating components from a race bike and just run it off battery for several hours, or run a smaller battery. |
August 8th, 2012, 02:53 AM | #28 |
If you got rid of all the lights and cooling fan, with the stock battery you should get about 4 hours with no alternator. I guy I met in college said he routinely removed alternators from race bikes to reduce the rotating mass.
As far as the 2 amp draw: I did not measure during actual engine load (i.e., bike accelerating), only reving the engine setting in the shop. It could go up with actual load, but I don't know why. It makes sense to go up with RPM since there are more sparks/second. |
August 8th, 2012, 03:31 AM | #29 | |
Fuel injection would have to work harder under load, but the actual ignition could use less power if the fuel reduces resistance in the spark gap. |
August 9th, 2012, 04:52 AM | #30 | |
If you want to be super accurate, you should use a clamp-on amp meter at the battery. Unless you're adding a short wave vacuum tube radio to the circuit, I don't think it's going to draw more than the heated vest and glove liners that I use all winter! |
July 25th, 2013, 08:18 AM | #31 | |
Freedom for Germany
Alternator Ninja 300 is 21.0A/14.0V @ 5000 r/min = 294W. |
battery/electrical issue | MagicMike | 2008 - 2012 Ninja 250R Tech Talk | 9 | May 14th, 2014 07:52 PM |
DIY Listing for "300" specific items | Alex | 2013 - 2017 Ninja 300 Tech Talk | 0 | September 30th, 2012 01:41 PM |
Electrical Issues (IMO battery related) | nikreinert | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 14th, 2012 04:41 PM |
Electrical Issue - Dead Battery? | k24_cm7 | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 17th, 2012 12:25 AM |
