December 9th, 2009, 01:12 PM | #1 |
self wrencher
Throttlemeister installed
Got it installed...expensive as hell...but works good for long distances. Prob need to get it powdercoated though.
A pic of Daytona and steering damper Rear end showing BM taillight side shot showing new Akra Ti/CF tip, CF rear hugger, monster decals Front and finally..."Is it a 600?" |
December 9th, 2009, 01:19 PM | #2 |
self wrencher
while i'm at it...a couple shot of the throttle "ziptie" mod...i use pcv instead..currently installed is a thinner (filed down) pcv) but I think I can squeeze by with full size one since I removed the "push" cable...so here it is..bought a new tube off ebay and give it a try
December 9th, 2009, 01:36 PM | #3 |
What did it cost, if I may ask? I opted for the vista universal throttle lock which was $30 and a breeze to install. Nice looking bike btw. BLK FTW
December 9th, 2009, 01:44 PM | #4 | |
self wrencher
btw, if you look at the first pic, you can see the "vista throttle lock" still on there..I need to get rid of it...good catch |
December 9th, 2009, 02:25 PM | #5 |
IC2(SW)
Bike is looking pretty sweet
Nice Motomummy sock thingy. Is that aluminum foil down in your air box area |
December 9th, 2009, 04:27 PM | #6 | |
self wrencher
Aluminum foil is actually the sunshade cut out behind the underseat side panel cover. that area gets hot without the airbox and my thigh is on fire doing the summer. Kinda like reflective insulation. That takes care of the heat issue |
December 9th, 2009, 04:32 PM | #7 |
self wrencher
oh btw, the PCV thing is KKim idea...or at least that's where I copied the idea from...so gotta give credit where credit is due Thanks.
December 9th, 2009, 05:47 PM | #8 |
Looking slick!
Interesting front blinkers; looks like the lens goes all the way around for rear visibility/more side vis? Also, I gotta ask, what's the off/on switch on the left bar for?
December 9th, 2009, 06:07 PM | #9 |
no joy
Join Date: Nov 2009 Motorcycle(s): Ninja 2006 636 Posts: 408
Random -Very swag-
that a stock rear tire? if not what size? did you change your gear upfront? and did you need a longer chain... rear hugger? |
December 9th, 2009, 06:32 PM | #10 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
John, your bike looks smokin'! Something about a BLACK bike!
December 10th, 2009, 10:56 AM | #11 |
sweet looking ride for sure
December 11th, 2009, 12:41 AM | #12 |
Join Date: Jun 2009 Motorcycle(s): Kawasaki Ninja 250R Posts: 50
wow!!! Nice bike dude...
www.anekaban.com Chemonk Modified Authorized Dealer in Bali The Best Body Kit Quality in Indonesia |
December 11th, 2009, 11:41 AM | #13 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
John... I love the bike and the mods you've done. Understated yet definately an eye catcher..... love it love it.. I may be gleaning some of those upgrades to finish out mine... yessssss
December 11th, 2009, 11:51 AM | #14 |
+1 Very nice looking bike.
December 11th, 2009, 12:00 PM | #15 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Does anyone have the hyperpro damper. Im thinking of ordering one, its active adjustable and a bolt on with no welding. Pretty much identical to the Ohlins dampers.
December 11th, 2009, 12:27 PM | #16 |
Join Date: Nov 2008 Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold) Posts: A lot.
December 11th, 2009, 03:19 PM | #17 |
self wrencher
Thanks for the compliment guys. I'm trying to not mod this bike anymore. But I've been modding the 600 a lot...need to stop
the little switch (yellow) up front is switching map for the BRT TIS (CDI) I got from ztrack157. Off is map 2 (aggressive) and On is map #1 (conserv). Gear is changed...15 up front and 42 rear. Tires are stock Dunlop 501. Chain is stock. Rear hugger is bought off Ebay from Scotts. It's the new style CF one. Daytona gauge does have the clock in it but it only switch to clock when bike is off. You can manually press the button for it to switch to clock but kinda hard to do with glove on. I have an extra small clock so I can see both time/temperature at the same time. Regarding HyperPro damper...i recommend you to only go with Scotts or Ohlins. HyperPro and some other lower end tends to "leak" after some use. Pricewise, if you look, they are close to Ohlins/Scotts (just a tad cheaper). I would shell out a few more dollars. You really don't need a steering damper for this little 250 but for track or aggressive driving, it's nice to have "just in case". If you have a headshake before, you will get a damper cuz you'll never want to experience it again...yes I did $hit in my pant |
December 11th, 2009, 05:07 PM | #18 | |
December 11th, 2009, 05:50 PM | #19 |
eegad! look at the size of the bar ends
December 11th, 2009, 06:02 PM | #20 |
no joy
LOL @ Rock
made my day. Hey serious my buds got a cbr and askes me do they make steering damper for that im like i don't know *shrug* he's like yeah i do 130+ and the bikes stable - i'm like yo I barley make it to 105 lmao- |
December 11th, 2009, 08:49 PM | #21 |
self wrencher
250fan: no, map one is when the thing is closed loop which same as "on". I tested with voltmeter.
Sixer: no damper for 07 600rr or later since it has hesd already. However I've seen racer mod the pre07 bracket to mount ohlins or scotts there (with HESD taken out) Posted via Mobile Device |
December 11th, 2009, 09:34 PM | #22 | |
Everyone makes them for the CBR's
December 11th, 2009, 10:39 PM | #23 | |
December 13th, 2009, 04:12 PM | #24 |
Awesome! I am considering a Throttlemeister as well. Did you get the light or heavy one, and are you happy with your choice?
Since you ditched the vista, may I presume you were not happy with it? |
December 13th, 2009, 07:32 PM | #25 |
self wrencher
Yeah the TM serves as heavy bar ends to elim vibration and cruise control. The vista takes up grip space and the cruise control doesn't work as well (it slips)
December 13th, 2009, 08:17 PM | #26 | |
You are sleeping
I was only doing 90mph when It happened to me on a gsxr. I don't see why it can't happen on the 250.. Nice bike man! |
December 16th, 2009, 11:21 PM | #27 |
John.... the marker lights front/rear who is the manufacturer and are they DOT stamped? Have been lookin at all those in stock around Dallas accessory stores and none are stamped DOT... would like to mod mine to a more arrowed and led type.
December 16th, 2009, 11:36 PM | #28 |
no joy
no i mean he asked me about one for my 250.
December 16th, 2009, 11:58 PM | #29 |
I love Triumph....
(the bikes are nice too) |
December 28th, 2009, 01:01 AM | #30 | |
Still liking the TM?
December 28th, 2009, 09:27 AM | #31 |
self wrencher
Yup.
December 31st, 2009, 09:01 PM | #32 |
Join Date: Dec 2009 Motorcycle(s): 08 ninja 250r Posts: 25
I have a set of these also on my 08 ninja I installed about a year and a half ago they work awesome as long as you shim and adjust them properly. They have longs and shorts I got the longs and the good thing about them is this one night at bike night at a local place I came out to find that someone had knocked their bike over and caused about 5 bikes to fall. The throttlemeister long with my steering wheel locked and falling to the right hand side was long enough that it held the entire bike up off the ground.The only scuff I had was on the end of the bar weight and a small scuff on the muffler heat shield part between the can and fairing. There was also a piece of bubble gum on the bar end from the ground =P. It actually hit so hard it bent the handle bar to where the throttle tube would not turn. Also mine are polished and I have never waxed them or anything and they still look new. So if you get them I recommend the longer ones for bike protection and also less handle bar vibration(it's also easier to engage them and disengage them with the longer ones).
December 31st, 2009, 11:47 PM | #33 |
Join Date: Dec 2009 Motorcycle(s): Ninja 250R Posts: 432
I want to get the exact same Corbin seat you have. Where did you buy it?
January 2nd, 2010, 03:03 PM | #34 |
self wrencher
got it from jc motors a year or so ago...best price i found at the time.
April 16th, 2010, 10:48 AM | #35 |
I'm thinking about finally ordering that throttlemeister for my birthday next week. Since you have had yours on your bike for a while now, do you still love it?
There are other things I could get instead that have been on my wish list, but if it is all good the throttlemeister is at the top of my list right now. |
April 16th, 2010, 04:53 PM | #36 |
self wrencher
yup...it's nice. It serves as heavy bar end to calm down the vibration and on long trip (highway) just set it and enjoy the ride. It's really nice to be able to hold the throttle and give your right hand a break.
April 16th, 2010, 04:57 PM | #37 |
Cool. I know you aren't in CA, so I don't know if you split lanes at all, but if you do, do you feel any less secure due to the length they add?
April 17th, 2010, 05:24 PM | #38 |
self wrencher
They're prob an inch longer than stock so it's not a problem
April 20th, 2010, 03:45 PM | #39 |
I faxed my order in yesterday, and haven't received confirmation yet. How long did it take you to receive yours when you ordered it?
Edit: NM, it was in my mailbox ALREADY! In 48hrs, they received my order, shipped it, and it got from WI to CA that fast.... impressive. Last futzed with by headshrink; April 21st, 2010 at 09:47 PM. |
April 22nd, 2010, 01:03 AM | #40 |
Tagged!
New Upgrades Installed! | iHeartDawnKeyes | Pictures | 4 | August 19th, 2012 10:11 AM |
Installed some parts | Tiane | 2008 - 2012 Ninja 250R Tech Talk | 13 | October 15th, 2011 11:03 PM |
Rearset installed! | chitor | Pictures | 24 | June 14th, 2011 01:47 AM |
Throttlemeister and aftermarket clipon | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 0 | July 16th, 2010 08:14 AM |
