March 28th, 2010, 02:59 PM | #1 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
DIY - How to Replace Your Chain
This is an external link, but it is very detailed with excellent pictures.
http://www.floridasportbikers.com/sh...ad.php?t=47667 |
March 28th, 2010, 04:32 PM | #2 |
I just replaced my chain and it turned out to be alot easier than I thought. I saved $50 by doing it myself.
March 29th, 2010, 02:23 AM | #3 |
December 30th, 2011, 11:05 PM | #4 |
Join Date: Nov 2009 Motorcycle(s): 300, WeeStrom Posts: A lot.
12.30.11 link appears to have expired
May 23rd, 2012, 06:14 PM | #5 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
Any threads that show how to do this?
May 23rd, 2012, 09:14 PM | #6 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
link gone
July 14th, 2012, 05:46 PM | #7 |
July 19th, 2012, 04:32 PM | #8 |
I used the video link as guide to replace both my chain and sprocket. I cheated and used a grinder with a cutting wheel to cut the chain off.
August 22nd, 2013, 06:12 PM | #9 | |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
CVMA #531 |
August 22nd, 2013, 06:47 PM | #10 | |
triple check your counts before you cut
August 22nd, 2013, 08:44 PM | #11 |
It is my opinion that the counter-sprocket nut (as well as clutch basket nut for that mater) should be removed with an impact wrench, and not a breaker-bar. Although it's not ideal to have those little impacts reverberate into your transmission, neither is the linear force placed on your output (input if doing clutch work) shaft/bearings from a breaker-bar.
The method mentioned by others is the most commonly used, BUT this is where I'm breaking from convention. Other than the two nuts I mentioned, I would say an impact wrench has no business being around a motorcycle. Source = Engine on the floor of my garage.
August 22nd, 2013, 08:49 PM | #12 |
I didn't have my impact with me so I used what I had available but the Impact makes a world of wonder.
August 26th, 2013, 12:40 PM | #13 |
Join Date: Aug 2013 Motorcycle(s): 2010 Kawsaki Ninja 250 Posts: 7
No need to remove front sprocket guard if you dont want to, cut your old chain with a grinder or bolt cutters, use your new chains master link to join new chain with old chain, gently pull old chain towards rear of bike and you will pull your new chain onto the sprocket. saves some time if you dont want to bother with all the muck up front.
August 26th, 2013, 07:18 PM | #14 | |
August 18th, 2014, 06:11 PM | #15 |
New Rider
Join Date: Oct 2012 Motorcycle(s): 2009 Ninja 250r Posts: 40
Hey, sorry to revive a thread, but I was using the instructions here, and used a D.I.D. x ring chain with 51 plates plus the master link, and it's way too short. As a matter of fact, I think it would've been really tight anyways. My sprocket sizes are 14 in the front, and 45 in the rear. Can you tell me what I'm doing wrong? Any help would be appreciated!
"The only thing worse than the actions of evil men, is the inaction of good men." |
August 18th, 2014, 07:21 PM | #16 | |
August 18th, 2014, 08:38 PM | #17 |
Bad Cuong!
August 19th, 2014, 07:03 AM | #18 | |
New Rider
Does anyone have any advice? The rear wheel is pushed all the way forward, I'm using JT front and rear sprockets at 14/45, and the chain is brand new. I ordered a new chain just in case... with 108 links just to be sure.
August 19th, 2014, 08:07 AM | #19 |
I feel really Josh.
Is the chain taught when you pull on it? 520 pitch chain and sprockets right? You can attach the old chain with the new to string it through and give you something extra to pull on.
August 19th, 2014, 08:28 AM | #20 | |
New Rider
I have all 520 size parts for the drive; JT sprockets front and rear, and a DID X-ring chain with 106 links. I think I could force it to fit, but there would be no slack. My long term concern is that if I use the 108 link chain, when the chain stretches down the road will I run out of swingarm to properly give the chain tension?
August 19th, 2014, 09:51 AM | #21 |
Are the adjusters all the way forward? Pictures of it?
August 19th, 2014, 10:38 AM | #22 |
New Rider
The pictures will have to wait until I get home, but as far as the adjustment, it's placed all the way forward. I made sure that the rear brake and rotor/sprocket on each side is aligned and seated properly. I will double check upon return.
August 20th, 2014, 08:43 AM | #23 |
New Rider
Fixed it! turns out there was some greasy gunk hidden just on the inside of the swing arm. It was an extremely small couple of bits, but just clearing that allowed the wheel to move forward a couple millimeters and the chain works fine.
Thanks for your help!
August 20th, 2014, 09:23 AM | #24 |
That's good! Glad I could kind of help lol.
DIY: How To Change/Replace Your Coolant w/ Pictures | gilmorec61 | 2008 - 2012 Ninja 250R Tech Talk | 38 | March 31st, 2015 01:34 PM |
DIY chain and sprockets | quadcrazy | 2013 - 2017 Ninja 300 Tech Talk | 12 | January 28th, 2014 10:08 AM |
Time to replace stock chain? | Lurkable | 1986 - 2007 Ninja 250R Tech Talk | 19 | March 18th, 2011 11:05 PM |
DIY chain oiler | Ntotot | Pictures | 4 | December 21st, 2010 10:30 AM |
DIY- Clean and Adjust Chain | islanderman7 | 2008 - 2012 Ninja 250R Tech Talk | 25 | April 2nd, 2010 10:42 PM |
