Old April 12th, 2010, 04:20 PM   #1
caliente103
caliente103's Avatar
Motorcycle(s): Red 08 250r
15/41 sprocket set up
What are your opinions on the 15/41 sprocket set up?
caliente103 is offline   Reply With Quote
Old April 13th, 2010, 01:14 PM   #2
motor32
motor32's Avatar
Motorcycle(s): 1987 Kawasaki Concours --- 2008 Kawasaki Ninja 250R
I've had this for the past two years and really like it. 76 MPG and first gear is good for more than just getting going. Before I changed it I kept trying to shift into seventh gear.
5000 RPM = 50 MPH
6000 RPM = 60 MPH
7000 RPM = 70 MPH
motor32 is offline   Reply With Quote
Old April 13th, 2010, 01:16 PM   #3
caliente103
Im always looking for 7th gear
Old April 13th, 2010, 02:17 PM   #4
caliente103
I think Im to go with the 15 sprocket and see how that feels.
Old April 21st, 2010, 08:23 PM   #5
Running itmyself but the dealer did something and my fuel economy actually went DOWN. I usually got 48-50 MPG and now it 46-47... yeah, it's a small amount but it would probably have been drastic without the gearing change. I really need this looked at.
Old April 9th, 2011, 12:16 PM   #6
Fly'in Ninja
Motorcycle(s): C-250R-ST
Hmmm...just wondering, what type of service work was done at the dealer??
Fly'in Ninja is offline   Reply With Quote
Old April 9th, 2011, 06:41 PM   #7
Chain, sprockets, and tires, oil change, and I asked 'em to diagnose a previous running condition (runs rich; smells gassy). They said "no abnormal running conditions found" even though there clearly was one and it got much worse.
Old October 12th, 2012, 09:58 PM   #8
Dragonracer76
Dragonracer76's Avatar
Wait, you guys don't have a 7th gear??
Beards make everything better. ATGATT
Dragonracer76 is offline   Reply With Quote
Old October 12th, 2012, 10:24 PM   #9
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
aussie gets 14 - 43 standard
and i want 15 - 43 would be perfect for the 250cc and the 110 - 120kph highway speed
ninja250r81 is offline   Reply With Quote
Old October 12th, 2012, 11:41 PM   #10
Bassman
Bassman's Avatar
Motorcycle(s): 1986 Goldwing, 1996 CR500, 2011 Ninja 250, 2009 Harley Heritage Softail, 1941 Suzuki Gerbil 250
I just finished installing a 15T/41T setup. So far I really like it. Shifting feels "right" to me now. I wanted to drop 1k RPM so I could get a bit more speed and stay between 5k and 6k (best MPG range) on my commute. This gearing gets me 55 at 5.5k RPM which is perfect for me. The guys that are into hypermiling the 250 recommend this gearing as well. I'll be going on a 100mile ride tomorrow and see what kind of mileage I get. I was getting high 60's/low 70's with original 14T/45T gearing.
I know there's a 7th gear here somewhere...
Changing to 15T/41T, now I'll get that 7th gear, lol.
Bassman is offline   Reply With Quote
Old October 13th, 2012, 07:15 PM   #11
thomason2wheels
thomason2wheels's Avatar
Motorcycle(s): dl650
I too am running 15 41 setup and have just barely squeeked into the 70mpg category. I did that riding in the mountains easing along at anywhere from 45 to 60 mph with temps in the high 50s. I was hoping for the kind of results u are getting.....harumph! :-)
I was with Alex.S and Jiggles last night and they had sex....the video is on utube. :-)
thomason2wheels is offline   Reply With Quote
Old October 13th, 2012, 08:36 PM   #12
tehcarguy
tehcarguy's Avatar
Motorcycle(s): Ninja 250R
How much would a 15/41 setup affect going uphill?
tehcarguy is offline   Reply With Quote
Old October 13th, 2012, 09:00 PM   #13
thomason2wheels
I cruised about 50 miles of the blue ridge parkway both directions yesterday, and found that to accelerate uphill at 5 grand in 6th gear was mediocre, but a downshift put me just enough higher in revs to accelerate reasonably well. If you are using it as a street bike, and fuel economy matters, you'll be happy with the result. It is still quite possible even with the taller gearing and a rider my size 250 lbs to ease along at 25 to 30 mph in 6th gear on flat land or very gentle up slopes. In my mind this is the gearing it should have come with from the factory. At 55 to 60 mph it pulls well enough to hold speed on most grades in this area, havent tested it on the interstate yet to see how it will fare there, but i have no reason to believe it will be disapppointing there either. Hope that helps. Try it youll like it!
Old October 14th, 2012, 11:37 AM   #14
I run 15/42 and your review is nearly spot on. I can add the freeway part. It does fine for the most part. I have only had issues going up grades against the wind, you simply have to downshift to accelerate or keep speed.
Old October 14th, 2012, 06:38 PM   #15
thomason2wheels
Thanks for the kind words Chris. I am pretty happy with the gearing, now to get the carb issues resolved, especially for cold weather.
Old October 14th, 2012, 10:15 PM   #16
Bassman
Bassman's Avatar
Well I took the new 15T/41T gearing out for a good 130ish mile spin to check any MPG improvement. I got kind of pissed the last half because of a strong head wind that I figured would really mess up my mileage. Well my best MPG on original 14T/45T was 72.6. That was running 100% surface streets @ 40-50 MPH. The 15T/41T allowed me a bit faster MPH at same RPM. The first 1/2 of the ride was around 45 MPH and the last 1/2 was around 60 MPH. Even with the head wind on the last 1/2 I got an amazing 80.2 MPG! So I'm very happy with the new gearing
Old October 24th, 2012, 02:29 PM   #17
thomason2wheels
I gotta ask...how much do u weigh?
Old October 24th, 2012, 04:02 PM   #18
Bassman
Bassman's Avatar
230... but I'm work'n on it
Old October 24th, 2012, 06:22 PM   #19
thomason2wheels
Well i am totally amazed at the fe numbers your getting. I am about 250 with gear and feel like i should be getting better than i am based on your experience. The best i have gotten is 70.6. Riding at 60 to 65 nets me about 63. Grrrr i am jealous. :-)
Old October 24th, 2012, 07:10 PM   #20
Ramen
Frak It
Ramen's Avatar
I've had the 15T front sprocket on my ninjette since way back. This thread just convinced me to order a 41T rear. I do mostly 50-60 mph commutes and this sounds about perfect.
Also, having to shift into 2nd while in my parking garage is pretty lame.
Ramen is offline   Reply With Quote
Old October 24th, 2012, 08:22 PM   #21
thomason2wheels
I know what you mean sean. Being in 3rd or 4th by the time you clear an intersection after a red light is pretty lame too, but thats better than it was stock.
Old October 25th, 2012, 02:54 PM   #22
Hitman
Hitman's Avatar
Motorcycle(s): 2010 Ninja 250r Special Edition (Red/Black) / 2008 Suzuki GSXR 600 (Silver/White) / Ducati Diavel Carbon Red
5000 RPM = 50 MPH
6000 RPM = 60 MPH
7000 RPM = 70 MPH
I get the same exact readings on my 15T/41T setup. A full Yosh exhaust and Jet Kit helps its responsiveness alot too.
2010 Ninja 250r Special Edition Blk/Red, Pazzo controls, Lowering kit, Roaring Boyz Toyz risers, Corbin seat, Shogun frame sliders, Yoshimura Full Exhaust 2008 Suzuki GSXR 600 Silver/White
Hitman is offline   Reply With Quote
Old October 27th, 2012, 02:52 PM   #23
Ramen
Frak It
Ramen's Avatar
Just got done with a ride after throwing on the 41T rear sprocket.
Damn. I love it!
First actually feels useful now. Pulled into a parking lot and I didn't have to shift into the second to ride around. Buzziness is down across the board at the same speeds as before. I was still trying to shift to the last gear - but this time I actually found it: 6th. Surprised myself a few times, but it was part of getting used to it. Only took a few minutes and I adapted just fine.
On paper, you do lose some acceleration, but I actually prefer WOT from 0-60 mph this way as I'm less focused on constantly shifting.
But overall, everything is smooth smooth smooth. Acceleration feels smoother. Cruising feels smoother, and blipping the throttle while downshifting during engine braking is definitely smoother. I've been missing out!
JT Sprocket 42 tooth Rear Sprocket lolibater Motorcycle-related 36 February 25th, 2013 12:30 PM
14tooth, 49tooth sprocket set. krolinked Motorcycle-related 3 October 12th, 2012 06:58 PM
Sprocket set up? NHrider19 2008 - 2012 Ninja 250R Tech Talk 1 June 28th, 2012 03:20 PM
ninja-250r-415gp-sprocket set assripp3r Items Wanted 13 July 20th, 2011 10:35 AM
DIY - Install a 520 Conversion Chain and Sprocket set g21-30 2008 - 2012 Ninja 250R Tech Talk 6 March 7th, 2010 02:34 PM
