Old April 19th, 2010, 09:38 AM   #1
FerociousNINJA
Motorcycle(s): 2008 Ninja TwoFiddy
DIY: Hotbodies Racing Undertail Install (Ninja 250R)
Installation guide for Hotbodies Racing (HBR) Ninja 250R Undertail. Note this is how I installed the undertail and should be as an aid with the instructions provided by HBR. You may opt to proceed a different route. I am not responsible for any damage to your motorcycle or yourself. It's your own your responsibility to use the appropriate tools and safety gear.
Whats included in the kit:
• Undertail w/ all LED Lights (2 amber turn signals & 1 license plate LED)
• License plate mounting kit (2 "L" brackets & bolts) never received this.
• All mounting hardware (blue wire connectors & plastic rivets)
• Installation instructions with photos (black & white. Website has a color PDF version)
CLICK ON PHOTOS FOR LARGER VIEW.
OEM rear fender and undertail.
1.- REMOVE/UNPLUG:
>Tail section panels
>Seats
>Foot pegs
>Disconnect Turn signals, License plate light and Tail light
>Mud flap
>Remove the rear Brake Reservoir (keep reservoir upright to avoid leaks).
2.- RESERVOIR BRACKET
>Place a cloth or several layers of masking tape over reservoir bracket to prevent scratching of undertail during installation.
>Also covered the foot peg nuts with several layers of masking tape to avoid scratch the undertail.
>OPTIONAL: I had a hard time with the reservoir bracket in the way so I bended slightly outwards. Not something normally done.
3.-CUTTING
> Mask the battery box area with 1" blue painters masking tape as a guide for cutting.
>Secure the battery box area with garbage ties to avoid movement when cutting and double check that all wires out of the way.
>Use a dremel, saw, scissors. I used a dremel. Use gloves and goggles due to the hot melted plastic as a result of the cutting. After cutting wait a few minutes for the melted plastic to cool off and remove the excess by hand.
4.-SECURE
>Secure the battery box using two bolts or four tie wraps. I used tie wraps.
5.-MOUNT
>Mount the HBR undertail. Make sure the bottom tail panel bolts line up on each side.
6.- OLD TAIL SECTION
>Carefully separate the highlighted green and remove the tail light.
>Insert the tail light. Noticed this does not use any bolts to keep it in place. Sandwiched between the Kawi battery box and the HBR undertail.
>Mount the top taillight cover.
>Re-install all tail pieces properly aligned, seats and bolts.
7.- SAGGING
> WTF!... A gap between my passenger seat! I did read about this issue on another thread. I did contact HBR customer service and stated "As long as you trimmed the glove box (battery box) it shouldn't sag." IMO seem like lack of support bolts/screws.
>For a solution you can use foam pipe insulation between the frame and the tail panels to push it up. I'd look for the thickest one you can find. I used from two to three layers half since I could not wrap it around. I did locate an area on the HBR undertail that can be screwed to the frame (will need to drill a hole) and covered up by the tail panels without interfering.
EDIT:
I just realized why the sag. HBR supplies two metal "L" brackets and bolts to secure the license plate (which I never received). These mount approximate under the area marked in the photo below. Once these bolts are secured (if possible to the frame) I bet it solves the sagging/passenger seat gap issue.
8.- ALMOST COMPLETE
9.- ELECTRICAL
> For the LED turn signals to work properly (they just stays ON) you need to add a 8 ohm resistor to each LED turn signal according to HBR. It is easier to replace the stock flasher (Mitsuba FR22-091) with a Tridon LL552 Long Life Electronic Flasher for aprox USD $6.50 from a local auto parts store. It now blinks and at a normal speed. Read more about flasher upgrade here.
>I spliced the old Kawi OEM turn signals wire harness connector and soldered the wires to the HBR LED turn signals ones. I'm also wiring the SHINTO LED tail light turn signals.
>Secured the HBR LED turn signals with clear silicone on the inner part of the undertail.
More DIY info to come....
NOTE:
You may need a wheel hugger to protect the undertail's paint job.
This undertail is not painted. I left it white for this write up.
Manufactures product link, reviews and install guide:
http://www.hotbodiesracing.com/en/pr...-10_ninja_250r
Last futzed with by FerociousNINJA; April 23rd, 2010 at 04:32 PM.
FerociousNINJA is offline   Reply With Quote
Old April 19th, 2010, 10:46 AM   #2
M-Oorb
M-Oorb's Avatar
Motorcycle(s): 2008 250r (Fastest Color)
I must say I really like that design detail on the bottom of the tail light, the little part that comes up. Reflects the styling of the headlight
Pictures of my ninjette plus...
M-Oorb is offline   Reply With Quote
Old April 19th, 2010, 12:33 PM   #3
draco413
draco413's Avatar
Motorcycle(s): Blue 09 Ninja 250
nice write up Dave and good idea for the gap......any particular size foam insulation piping u used? did u cut it in half or wrapped it around the frame?
Im So Cereal
draco413 is offline   Reply With Quote
Old April 19th, 2010, 02:23 PM   #4
headshrink
headshrink's Avatar
Very nice. You will have to tell us how visible the turn signals are. I don't know if there is technically enough separation between them to be legal, but I'm not real sure about the ins and outs of all that.
Old April 19th, 2010, 02:27 PM   #5
draco413
draco413's Avatar
the blinkers are visible and bright enough.....cop was behind me and didnt pull me over so i guess they are legal
Im So Cereal
Old April 19th, 2010, 02:41 PM   #6
headshrink
headshrink's Avatar
Originally Posted by draco413 View Post
the blinkers are visible and bright enough.....cop was behind me and didn't pull me over so i guess they are legal
I wouldn't take that as a legal OK.... I think he a) didn't notice, b) didn't care, or c) didn't know. I really don't hear a ton of people having problems with LEOs and their upgrades on the 250r, so even if it weren't technically legal, you are likely going to get away with it for a long time, if not indefinitely.
I vaguely remember from a thread from a year or two ago about the differences between DOT approved equipment and what is/isn't "legal." So it isn't always super straight forward.
Old April 19th, 2010, 04:17 PM   #7
welcome2thedawn
welcome2thedawn's Avatar
Motorcycle(s): 08 ninja 250r modded, 73 honda cl200, 74 kawasaki 400 triple
i never had issues with sagging...i wonder if it's because i have a bike monkey tail light?
welcome2thedawn is offline   Reply With Quote
Old April 19th, 2010, 04:31 PM   #8
draco413
draco413's Avatar
i have a bike bitez tail light so idk
Im So Cereal
Old April 19th, 2010, 04:35 PM   #9
FerociousNINJA
7.- SAGGING
EDIT:
Attachment 6723
Old April 19th, 2010, 05:01 PM   #10
draco413
draco413's Avatar
is that is true why dont they mention that in the install?
Im So Cereal
Old April 19th, 2010, 11:01 PM   #11
Waldo
Awesome DIY! I was looking all over for a DIY of the undertail to see the work involved before buying one, didn't expect something this good though. Great work!
Waldo is offline   Reply With Quote
Old April 20th, 2010, 08:52 AM   #12
deezyellownutz
deezyellownutz's Avatar
Motorcycle(s): 2007 Zx10R 2009 250R
Nice! You beat me to to DIY. I was in progress and the sagging tail light just made me quit. I figured out the light was pressing up against the black plastic too much forcing the tail to sag. I have since, decided to replace the original under tray and use a R&G tail. Great work! Anyone looking for the exact same undertail as above PM me!
2007 Kawasaki ZX10R Red
2009 Kawasaki EX250R Special Edition
deezyellownutz is offline   Reply With Quote
Old April 22nd, 2010, 08:38 AM   #13
glenjamin1982
I just got this undertail and am almost finished installing it. I did all the wiring to test out the lights but the turn signals don't blink. Left side (front and back) stays lit when I signal left and right side (front and back) stays lit when I signal right.
I'm surprised the Hotbodies instructions didn't mention anything about this or any other trouble shooters for that matter... The whole thing is a real pain in the a@#.
Any ideas as to what he problem might be be?
glenjamin1982 is offline   Reply With Quote
Old April 22nd, 2010, 08:52 AM   #14
deezyellownutz
The problem is the the signals are LED so the OEM flasher doesn't see enough "resistance" to make the lights blink. What happens with the stock bulbs - Filament ones is as the light turn on, the filament heats up and creates a resistance on the circuit. Once it reaches a certain point, it trips the flasher relay and then the whole cycle starts over again. LEDs since, they draw little current do not create enough resistance.
I have the Hotbodies kit as well and I am 100% sure that somewhere in the documentation is states that you will need to add resisters to solve this issue.
Two ways to solve this issue.
1. Replace the flasher relay with an electronic flasher that can handle variable loads. This happened to me when I changed my ZX10 bulbs front and rear to LEDS. The light would turn on and stay on. I bought the flasher from Autozone for $8.
2. Add resisters in parallel to each light so when you do signal, it create enough resistance to trip the flasher. Search the forum for "led and resister" you will find a ton of threads relating to it.
IMO - I just bought the electronic flasher because it was less work. I don't like spaghetti wiring and splicing unless I have to. Replacing the flasher is backwards compatible if you want to switch back to none LED lights without further modification.
Old April 22nd, 2010, 09:16 AM   #15
glenjamin1982
Thanks deezyellownutz! I'm no electrician but I figured it was something due to the current for the new LED's as oppose to the stock bulbs.
There were some blue clips that came with the kit that are for splicing wires together. I assumed that's all they were for. HBR only calls them "blue clips". Could these possibly be the resistors?
Old April 22nd, 2010, 09:51 AM   #16
FerociousNINJA
I haven't installed the electrical yet but this is what I read:
"You’ll need to get a new 2 pole electronic flasher relay from any auto parts store. They’re about $4 or so at Autozone. You need the new relay because the undertail comes with LED turn signals. The LEDs don’t draw enough power to operate the stock mechanical relay so they won’t work without the electronic relay."
HBR FAQ
-Do Hotbodies Racing's LED flush mount blinkers work with my stock running lights?
No, our turn signals only have two wires. One for the ground and one for the turn signals, the extra wires from your wiring harness are for the running lights and this should be tied off to the side because it is not used.
-Do I need resistors or load equalizers?
We actually designed the LED's to blink faster, since they are smaller than stock, so they will draw more attention from drivers behind you. If you wish to slow them down, we recommend a 20-25 watt 8 ohm non-inductive resistor wired inline with the RED wires on our kits. You can check with Radio Shack or www.customled.com for pricing and availability.
http://www.hotbodiesracing.com/en/fa...kers_questions
Old April 22nd, 2010, 06:47 PM   #17
FerociousNINJA
9.- ELECTRICAL
Attachment 6782
Old April 27th, 2010, 10:19 AM   #18
FerociousNINJA
Received missing license plate plastic "L" brackets and bolts from HBR... Great customer service from Kevin
NOTE:
Realized you will need to drill holes in the frame and support the undertail with screws.
Attachment 6723
Old April 29th, 2010, 10:06 AM   #19
Spork
Spork's Avatar
Motorcycle(s): 08 CPB Ninja 250
So whats the general concensus on the sag? is there a way to tweak the install or be extra careful to have it fit properly?
"I am directly below... enemy scrotum"
-Agent Simmons
Spork is offline   Reply With Quote
Old July 2nd, 2010, 09:48 AM   #20
Another member has written up their install experiences here:
http://www.ninjette.org/forums/showthread.php?t=49212
Old May 2nd, 2011, 07:13 PM   #21
Snizzlers
Motorcycle(s): '10 250
thanks
Snizzlers is offline   Reply With Quote
Old July 13th, 2011, 07:23 PM   #22
opc
opc's Avatar
Hi Guys,
I just wanted to comment on the indicator (flasher) relay mentioned in the original post in this thread. For anyone out there looking to fix the non functioning LED indicator problem, DO NOT buy the LL552 flasher mentioned in the first post. I'm not sure why that part in particular is suggested, but it's the exact same type of relay that was originally on the bike, and does NOT work with LED indicators.
For that you need an EP34 or similar flasher, and you'll notice that it says "LED" right on the part. That type uses a relay and an electronic circuit to switch, so it doesn't require the resistance of the bulb to turn on and off. It also requires a ground termination that you'll have to connect yourself.
I wasted the better part of a day getting the LL552 installed only to find out it didn't do anything!
I've attached some pictures to help clarify the difference between these parts since it's otherwise pretty vague.
Cheers,
Owen
opc is offline   Reply With Quote
Old August 22nd, 2011, 02:53 PM   #23
Highalltheway
Highalltheway's Avatar
Motorcycle(s): 2011 ninja 250 special edition
Just got done with mine. Tips : no need to cut oem undertai. Used EL12 relay flasher. You should notch the tail light and add the bolts threw the under tail.
Highalltheway is offline   Reply With Quote
Old October 8th, 2011, 12:52 PM   #24
Maniac0908
Motorcycle(s): 11 ninja 250r
Your really dont have to cut the undertail?
Maniac0908 is offline   Reply With Quote
Old October 8th, 2011, 07:18 PM   #25
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
i just did mine the other day.. i cut mine just because it said too, but i think without cutting it would be a really tight fit snapping into the side tail fairings. might even possibly buldge out some .
#1
greatwhiteninja is offline   Reply With Quote
Old October 8th, 2011, 07:32 PM   #26
headshrink
headshrink's Avatar
greatwhiteninja: I'm interested in hearing about the picture in your avatar....
Old October 8th, 2011, 07:46 PM   #27
greatwhiteninja
Ridin Dirty
that is a pic of the front end of my bike with my led running lights
#1
Old October 8th, 2011, 09:16 PM   #28
headshrink
headshrink's Avatar
Do you have a write up on that?
Which lights did you use?
Old October 8th, 2011, 11:15 PM   #29
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
these look great does anyone in CA have one and where did you put your plate?
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old October 9th, 2011, 06:33 AM   #30
greatwhiteninja
Ridin Dirty
side mount tag, you can see it in the one pic i posted.
no writeup, do have a thread of when i did it showing more pics http://www.ninjette.org/forums/showt...highlight=leds its just 2 small 4" led strips mounted under the headlights.
#1
Old October 9th, 2011, 09:46 PM   #31
massacremasses
Avid Kitteh Poster
I dont think thats legal in California.
Old October 9th, 2011, 11:59 PM   #32
headshrink
headshrink's Avatar
Correct... it has to be oriented normally here.
Old October 10th, 2011, 06:17 AM   #33
greatwhiteninja
Ridin Dirty
it probably is the same here also.. but 1 out of 3 bikes on the road around here have a sidemount tag and ive been running one for a while now even before the hotbodies undertail with no issues. plus the bike is tagged for 5yrs so i got a long time before worrying about inspection again..loL!
#1
Old October 10th, 2011, 07:41 AM   #34
massacremasses
Avid Kitteh Poster
CHP is pulling over anyone they can... idk about chancing it.. lol
Old October 10th, 2011, 07:50 AM   #35
greatwhiteninja
Ridin Dirty
whats CHP? im not worried about, like i said ive went the whole summer like it is and never had a problem so probably in my area its either allowed or they dont stress it.
#1
Old October 10th, 2011, 08:00 AM   #36
massacremasses
Avid Kitteh Poster
California Highway Patrol.
Old October 10th, 2011, 09:26 AM   #37
greatwhiteninja
Ridin Dirty
oh..ok. the normal way to mount it is underneath , right in the middle of the 2 turn signals but down some. even has a small led there to light up the tag.
#1
Old October 10th, 2011, 09:37 AM   #38
greatwhiteninja
Ridin Dirty
also just a FYI , when running front led turns then adding this undertail.. the EL12 wouldnt work for me, the lights were very dim and just stayed lit solid.. swapped to a EP34 relay and now they are all fully lit up and all blink like hazards.. now diode kit is needed, and all should be working like normal.
#1
Old May 18th, 2012, 12:54 PM   #39
conor
Motorcycle(s): Ninja 250r
One comment
I'd just like to add some things to save someone else some heartache.
When you are running the cables up MAKE SURE that you run them back through the holes in the bike frame. I forgot about this and had to snip and reconnect them again. If you dont run them through the holes the undertail will not fit properly.
You dont need to do any cutting i.m.o. I have a 2011 ninja 250 and the undertail just slots on over the battery box plastic part.
Pain in the ass getting the lower bolts back in. I only managed to get one in.
Definitely screw out the reservoir cap screw as mentioned above, this will get in the way and scratch your undertail if you dont.
Make sure that you buy connectors aswell, you'll need about 10 or so.
Its handy to have someone to help you with installing for certain parts.
Getting the bolts removed from the tail light stock is a challenge without the right spanner, I would recommend getting one Im not sure of the size though, I used a vice grip but it wasnt straight forward.
Tools needed:
Pliers (very handy for electrical work as you can snip and also clamp down on the connectors to close them)
Set of allenkeys
Small flathead screwdriver and medium sized head flathead.
Drill with a size 8 steel bit.
Patience
conor is offline   Reply With Quote
Old May 25th, 2012, 06:13 PM   #40
Black-_-Ninja
Motorcycle(s): Kawasaki Ninja 250r
Does anyone know where exactly you're supposed to mount the license plate or is it just personal preferance?
Black-_-Ninja is offline   Reply With Quote
