Old May 2nd, 2010, 04:56 PM   #1
Scott1620
Scott1620's Avatar
Motorcycle(s): 2008 Ninja 250r(sold), 2007 650R (sold), 2013 Ninja 300
Thumbs up Sportisi fiberglass Undertail Review/DIY
I just finished up the installation of my Sportisi Undertail and rear hugger. I had a shinto fender eliminator on my bike, but Matt (ztrack157) gave me a sweet deal (because of a paint crack) on the undertail that I couldn't resist.
You can get directions for the hugger, so I wont go into that installation in too much detail. One tip though that I dont remember being in the directions is you need to rotate your rear brake fluid tube where it mounts on the rearset outwards a little to clear the hugger when the suspension is compressed. Mine hit the hugger and scratched it a little...
On to the undertail, there are no directions for this one. It is fiberglass, so there is no sagging issue here (as has been reported with other undertails). It fits very nicely as well, the tail light fits great too.
First I stripped my bike down to this: (tips: You have to take the passenger peg brackets off to get to the last screws that hold the stock undertail on, also to get the battery tray out there are two screws in the bottom of that under the foam pad)
To fix the paint crack, I sanded the finish on the undertail down a little (1500-2000 grit), and sprayed it with krylon fusion clearcoat. This covers it up pretty well. And it turned out so good that I ended up spraying my hugger the same way to get the paint extra glossy.
Once the bike is stripped down, be very careful when installing the undertail, I scratched mine a little from screws that protrude inward.
Onto the biggest problem that I faced, the license plate and the rear blinkers. It doesnt come with any licence plate brackets, and the two holes in it are to secure the tail light. I used those two points to mount my license plate and blinkers. Here are some pics of the bracket I made out of galvanized sheet metal:
I painted that bracket flat black. To light the plate, I used led license plate bolts, those are not too fun to work with... Heres how everything looks mounted on the bike (without rear blinkers):
To wire the licence plate leds (and later the blinkers), I drilled a hole directly behind and in the center of where my bracket mounts. As you can see, the license plate blocks the integrated blinkers on the undertail from directly behind, you can see them off to the side though.
Now onto the blinkers, I did not use the stock blinkers because I think they would be too heavy for where I wanted to mount my blinkers. I ordered led blinkers from amazon.com (to work in conjunction with the blinkers in my integrated tail light and the blinkers in the undertail). To get the all led blinker setup to work you need either a resistor on each side or a new flasher, I went with resistors. I found that with 8 Ohm 20w resistors the blinkers flashed sufficiently, the resistors that came with my shinto tail light (5 Ohm 20w) seemed to flash the blinker too fast for my liking. To mount these universal led blinkers, I made a bracket that mounts onto the rear of the licence plate bolts. This is the finished product, if you want close ups of the blinker bracket, or have any questions or comments let me know... I am pretty happy with this setup, it finishes the rear of the bike nicely...
Scott1620 is offline   Reply With Quote
Old May 2nd, 2010, 10:14 PM   #2
tjb0012
Motorcycle(s): 2009 SE Ninja250r
That looks really clean. And thanks for answering all of my questions!
tjb0012 is offline   Reply With Quote
Old May 3rd, 2010, 02:52 PM   #3
kirana
kirana's Avatar
Motorcycle(s): Ninja 250R 2008 Model
kirana is offline   Reply With Quote
Old May 3rd, 2010, 09:49 PM   #4
linked!
Old May 17th, 2010, 12:23 PM   #5
maglin
maglin's Avatar
Motorcycle(s): what else?
Very very nice Scott.
Please can you post some pictures with turn signals on?
-This signature rocks!!!
maglin is offline   Reply With Quote
Old May 18th, 2010, 05:45 AM   #6
Scott1620
Scott1620's Avatar
Thanks, I will post pics when it stops raining here
Old August 4th, 2010, 12:27 AM   #7
superlife
Ninjette Indian
superlife's Avatar
Originally Posted by kirana View Post
Hi
As you know I have just bought these, now am looking for DIY guide to install them can anybody please post up
superlife is offline   Reply With Quote
Old August 4th, 2010, 08:51 AM   #8
Very cool but, can we get a little more info, please?
What undertail piece is that that replaces the brake light? Does it somehow also replace your tail like the Ducati-style one because I don't see the rest of that "bulk" even though it seems to be painted over the brake light.
Old August 4th, 2010, 06:38 PM   #9
adri99an
adri99an's Avatar
Motorcycle(s): "Is that a Ninjer 1000?"
Nice
Very clean!
adri99an is offline   Reply With Quote
Old August 4th, 2010, 06:46 PM   #10
codebluetdi
Motorcycle(s): 09 Ninja 250R
I want that hugger so bad right now! where can i get it?
codebluetdi is offline   Reply With Quote
Old August 4th, 2010, 07:37 PM   #11
Sportisi. Matt/zTrack is the US supplier of Sportisi goods.
Old August 4th, 2010, 08:38 PM   #12
ztrack157
The Sportisi Master
ztrack157's Avatar
GB in the market place boys
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old August 13th, 2010, 12:26 PM   #13
kirana
kirana's Avatar
hahaha " ztrack157 " will get all that for u.
Old October 24th, 2010, 10:14 AM   #14
hmingtea
hmingtea's Avatar
Motorcycle(s): 2010 ninja250r,2009 YZF Yamaha R15,YZF Yamaha R6
what is the price of the green undertail?can u ship it to india?
hmingtea is offline   Reply With Quote
Old November 5th, 2010, 09:52 AM   #15
hmingtea
hmingtea's Avatar
Old November 5th, 2010, 06:46 PM   #16
ztrack157
The Sportisi Master
ztrack157's Avatar
India is Sportisi HQ's region. I handle Europe, NA, and SA
Old November 8th, 2010, 01:26 PM   #17
Sailariel
Sailariel's Avatar
The people with the Ninja EX250R must be having a great time with the Royal Enfields. I tried one out here, and it was painfully slow. Incidentally, nice job on your catalog.
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550
Old June 11th, 2011, 11:00 PM   #18
I noticed that it doesnt have the holes for the rubber well nuts that hold the stock undertail in. Because the bolt going in the right side also holds a piece that routes some of the cables along the right side of the frame, I figured I better ask: did you have to make alternative mounting/routing?
DIY: Hotbodies Racing Undertail Install (Ninja 250R) FerociousNINJA 2008 - 2012 Ninja 250R Farkles 65 June 5th, 2023 10:49 AM
Sportisi BRT TIS review randomwalk101 2008 - 2012 Ninja 250R Tech Talk 141 May 22nd, 2014 06:27 PM
Sportisi dual undertail exhaust DARAM1281 Motorcycle-related 16 December 9th, 2013 03:01 PM
WTB Sportisi undertail Live2ride Items Wanted 8 May 7th, 2011 08:42 AM
Sportisi Undertail tjb0012 2008 - 2012 Ninja 250R Farkles 2 May 3rd, 2010 10:17 AM
