May 8th, 2010, 01:15 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): 1987 Kawasaki Concours --- 2008 Kawasaki Ninja 250R Posts: 59
--- My Mirror Solution ---
This is what I have been using on my bikes for a couple of years. Works great with no blind spots at all. Cost under $20 dollars and easy to do.
Picked up these mirrors at Autozone. You'll need two of each. (Make sure to use the correct 360 rotating kind, there are some that just pivot but they don't work as well since they move when you hit bumps.) Picture 071.jpg Got these shims at Home Depot. Get the ones that are not wood. You will need only the fat ends of two, a little over 1/4 of a inch. Also you will need some good double sided tape and some Crazy-glue. (The tape in this is just to show the size of the shims and is not used.) Picture 005.jpg Cut a 1 inch square and attach to the narrow side of the 360 mirror. (As seen on the left of picture.) Cut 1/4 inch off of the shims with a razor-knife wrap three sides with the double sided tape. This now goes on the thick side of the 360 mirror. Peal the backing off the big mirror and attach as shown. Now attach the whole thing to the inside of the bikes mirror. Picture 002.jpg For extra measure I put some Crazy-glue on the tape area and the mirror just to be sure it doesn't come off. Blue painters tape to hold it in place overnight. Picture 007.jpg View of my bike in between my cars. My rear tire is touching the line between the concrete and the asphalt of my driveway. (Use this as a reference for the next photos.) Picture 072.jpg The right side mirror. I use the bikes mirror to see behind me and my blind spot mirror to see whats on my side. (In the picture you can see to my porch.) Picture 073.jpg The left side mirror now I can also see behind me and whats on my side. (In the picture you can see past my garage into my yard.) Picture 074.jpg I hope I made this clear to understand. It works great. |
May 8th, 2010, 01:55 PM | #2 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
An option but I'll stick with my SW tech mirror extenders... the appearance of this glueon and huge circular mirror just doesn't do it for me...uh uh.
May 8th, 2010, 04:10 PM | #3 |
Join Date: Nov 2009 Motorcycle(s): 300, WeeStrom Posts: A lot.
Mo 32....nice inexpensive solution. And really...knowing the prob exists...what would it cost Kawa to mold a covex bubble into the glass?
May 8th, 2010, 04:21 PM | #4 | |
May 8th, 2010, 07:08 PM | #5 | |
Join Date: Mar 2010 Motorcycle(s): black 2010 ninja250 Posts: 224
I'm sick of moving my arms every time i need to check behind me... it's really unnerving! |
May 9th, 2010, 03:50 PM | #6 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
someone posted an excellent diy on those sw-motech mirrors.
they really did help. i didn't have to tuck my arms in as often to see behind me. http://www.ninjette.org/forums/showt...ghlight=mirror |
May 9th, 2010, 03:53 PM | #7 | |
May 9th, 2010, 04:14 PM | #8 |
IIRC, someone already pointed you to this link.
http://www.ninjette.org/forums/showthread.php?t=41246 |
May 9th, 2010, 04:15 PM | #9 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
I don't use my mirrors much. I always just look over my shoulder.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
May 9th, 2010, 04:25 PM | #10 |
Ramen Rider
lol... when you said you just look over your shoulder, it reminded me of this:
Link to original page on YouTube. |
May 9th, 2010, 04:34 PM | #11 | |
May 9th, 2010, 04:45 PM | #12 |
May 9th, 2010, 04:48 PM | #13 |
Join Date: Jul 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 410
Me too. I find it gives both a better view for me and for others around me since they have a better chance of noticing me looking back at them instead of glancing in the 75% of my mirror that isn't occupied by my elbow or my ass.
May 9th, 2010, 05:06 PM | #14 |
May 10th, 2010, 08:17 PM | #15 | |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
May 11th, 2010, 07:46 AM | #16 |
May 18th, 2010, 04:30 AM | #17 |
I still look over my shoulder before I change lanes. This allows me to see whats going on behind me when i'm just going along. It's also is nice when you are stopped at a light and you can see what's on both sides of you and behind you.
May 18th, 2010, 08:40 AM | #18 |
Join Date: Apr 2010 Motorcycle(s): 2010 Ninja 250R (Metallic Island Blue) Posts: 262
+1 on looking over the shoulder, most the time I only use the mirrors to look behind me when I am at a light...gotta make sure those cagers are actually slowing down.
WTT for left stock mirror or mirror set | Aodrn | Motorcycle-related | 8 | September 28th, 2014 08:42 PM |
Another Mirror Solution - Pricey !! | g21-30 | 2008 - 2012 Ninja 250R Farkles | 9 | August 31st, 2010 02:07 PM |
Alternate "Mirror" Solution | g21-30 | Off-Topic | 11 | August 3rd, 2009 08:37 AM |
