Old May 29th, 2010, 05:52 PM   #1
ericdrum
ericdrum's Avatar
Motorcycle(s): 2010 Ninja 250R SE Green
Disconnected my idle control cable... how to fix.
Ah, I'm an idiot. My brand new bike was idling all crazy today. In messing around with the idle control cable that's on the left side of the engine, I completely unscrewed it. Where do I screw it back in? I have the fairings off and I think I know where it should go, but I'm not sure. Thanks in advance.
ericdrum is offline   Reply With Quote
Old May 29th, 2010, 06:56 PM   #2
one the right side of the carbs, below the throttle linkage cam.
Old May 29th, 2010, 10:45 PM   #3
ericdrum
ericdrum's Avatar
After staring at it for a few more minutes I figured it out for myself, but thanks so much as that would have really helped!
Should I replace the petcock if it leaks while disconnected? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 20 August 20th, 2022 01:57 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Throttle cable - high idle? austexjg 2008 - 2012 Ninja 250R Tech Talk 3 November 30th, 2010 09:41 AM
Help. Idle Adjustment Knob cable came off. RyanJames 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2010 11:22 AM
speedometer / odometer disconnected IlBLisSlI 1986 - 2007 Ninja 250R Tech Talk 8 June 16th, 2009 08:46 AM
