July 16th, 2010, 06:43 AM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2009 Ninja 250 SE Posts: 338
How To: Clean/Lube Chain
I strayed a bit from my usual riding videos and made a how-to last night. The setup had 2 cameras (Flip video, Point-n-shoot Samsung camera), a spot light (desk lamp) a gorilla mount and the Flip mounted on a broomstick with bungees.
2013 CRF250L 1985 GL1200 Interstate |
July 16th, 2010, 08:36 AM | #2 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
Good vid mate, heres some extra tips to make things a little easier. I just cleaned and lubed my chain today and found that removing the chain guard makes it easier to clean the chain and also theres usually a heaps of grease and grime under the guard so clean that out. I also removed the front sprocket cover to clean the front sprocket and all the crap inside there, and being that it was the first time cleaning the front sprocket in 8000kms there was heaps of grime and grease in there, so I'd suggest cleaning that once in a while.
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
July 16th, 2010, 09:33 AM | #3 |
That's a great idea Mike. I took a look inside the front sprocket cover and sure enough it looks like hell in there. Time for some additional WD-40
July 16th, 2010, 10:19 AM | #4 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
Must be nice to work outside with a light and have minimal bug attraction.
July 19th, 2010, 09:28 PM | #5 |
July 20th, 2010, 03:15 AM | #6 |
Join Date: Jun 2010 Motorcycle(s): 2008 ninja 250r Posts: 119
awesome vid nice job and will help others im sure!
July 20th, 2010, 06:58 AM | #7 |
Very cool. Glad it's useful to someone
July 20th, 2010, 07:42 AM | #8 |
Join Date: Jul 2010 Motorcycle(s): ninja 250, ninja zx6r and KLX140 Posts: 29
I actually took of my chain guard completely, I think it looks better and also easier to clean. I clean my chain differently though.
September 21st, 2010, 12:01 PM | #9 |
Join Date: May 2010 Motorcycle(s): Totaled 2010 Ninja 250r :( Posts: 77
after how many miles do you think this should be done?
September 21st, 2010, 12:03 PM | #10 |
September 21st, 2010, 12:10 PM | #11 |
Here ya go!
September 21st, 2010, 12:29 PM | #12 |
Cool.
September 21st, 2010, 12:41 PM | #13 |
Thanks, wow I better get on that then lol. I'm around 1,500 miles on the bike...My dealership did the 600 mi. service so I am assuming they lubed it then.
BTW I need a rear stand for the bike because the thought of lubing the chain w/out that seems like a pain. How much should one of these cost me? Any recommendations for online purchasing? |
September 21st, 2010, 01:07 PM | #14 |
MOTM - Mar '13, Jun '14
They make a brush that works well.
September 21st, 2010, 01:18 PM | #15 | |
Join Date: Jul 2010 Motorcycle(s): 2010 Ninja 250R Posts: 306
This? www.tirox.ca http://www.webbikeworld.com/r4/tirox...-chain-cleaner Thank you to the OP. |
September 21st, 2010, 01:34 PM | #16 | |
Join Date: Jun 2009 Motorcycle(s): CBR600RR Ninja 250R(sold) Posts: 144
September 21st, 2010, 03:09 PM | #17 |
I like the 3 sided brush with the long handle.
September 22nd, 2010, 03:54 PM | #18 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
I haven't watched this in a looong time but there is a much easier way to maintain your chain after you clean it.
And don't forget, WD-40 is OK for CLEANING, but not for LUBRICATION of a chain. It leaves a sticky residue and won't last very long. Thar stuff is better for loosening rusty bolts or stuck cables, then you have to lube with something else. Use Dupont Teflon spray lube, blue can, avail. at Walmart, Lowes, Home Dept, Ace Hardware, etc, etc. Spray it on the chain with the straw. Is is clean, no mess, does not attract dirt or have dirt stick to it, no greasy messy cleanup each time. A can is about $8-9, will last for a year or more if you spritz the chain once a month or so. I have been using it for a few years on two different bikes, many others on numerous other bike websites also recommend it, and all I can say is that it works great and is very clean and easy to apply and the chain lasts as long as any other greasy oily stuff you put on, maybe longer because there's no grit or dirt buildup in the grease that most people use on the chain. It makes your life a whole lot easier instead of into a difficult dirty chore that tends to get ignored. Try it, you'll like it. |
September 22nd, 2010, 05:15 PM | #19 |
September 22nd, 2010, 06:45 PM | #20 | |
http://www.webbikeworld.com/t2/motor...n-chain-saver/ http://www.lowes.com/pd_213197-39963...3FNtt%3Dteflon |
September 22nd, 2010, 07:02 PM | #21 |
DuPont Teflon Chain Saver is the stuff I got from walmart. Good stuff
September 23rd, 2010, 06:08 AM | #22 |
September 23rd, 2010, 06:34 AM | #23 | |
My bottle of Chain Wax is almost out, I'll try out the Teflon based one. It sounds like it's cheaper than the stuff I'm using anyways.
October 15th, 2010, 03:07 PM | #24 |
i use i think mazima, chain lube and wax, works fine for me. and i use a rag not paper towels or a fancy brush... if the brush were free i'd probably use it
October 17th, 2010, 08:55 AM | #25 |
You don't find your rag gets completely saturated with grease? I use paper towels because they can soak up a ton of crap.
August 20th, 2011, 04:24 PM | #26 |
Join Date: Jun 2011 Motorcycle(s): 2008 Ninja 250r Posts: 94
you dont want to dispose of those wrags like that. put it in a metal waste bin (every garage should have one). Wrapping up chemical/greasy/oily wrags can cause them to spontaneously combust, and no, I'm not making that up. I've seen it happen in my shop class, both a plastic trash can on fire and a metal waste bin smoking because of all the chemicals reacting inside of it. Do not wrap them in a grocery bag, for the love of god, trust me .
"Hey man, I'm not tryin' to start nothin'. But... i wouldn't take that" |
August 23rd, 2011, 02:14 PM | #27 |
here's a question, when you clean and lube your chain how much lube are you supposed to use? I have the dupont stuff and i like it a lot. i am just wondering if i am using too much of it.
'09 Ninja 250R SE TB Slip-On l Puig DB l Pazzos l Pro-Grips |
August 23rd, 2011, 02:34 PM | #28 |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
The brush someone was talking about earlier is The Grunge Brush
http://www.cyclegear.com/spgm.cfm?L1...e_Grunge_Brush Most motorcycle places have it in stock.
Life's better on the Mountain. |
August 25th, 2011, 12:15 AM | #29 |
Join Date: Jul 2011 Motorcycle(s): 09' 250r Thunder Blue Posts: 165
Thats my toothbrush
August 25th, 2011, 03:35 AM | #30 |
Join Date: Aug 2011 Motorcycle(s): 2011 SE Pearl/Ebony Ninja 250R Posts: 376
Great video! Very useful info!
August 25th, 2011, 04:57 AM | #31 | |
Perpetual Newb
Join Date: Mar 2011 Motorcycle(s): 2010 MIB Ninja 250R [sold]; 2006 CBR600RR [sold]; 2013 Triumph Street Triple R Posts: 782
I'd say I probably go a little overboard on my chain when lubing it. I use the DuPont stuff as well and I'll spray the top (outside-facing side) of the chain from the back of the bike where it rolls over the rear sprocket and then I'll spray the inside (inward-facing side) down where it goes under the rear swingarm by the kickstand. I spray enough that it soaks the chain then let it sit for 15-20 minutes or so before wiping off the excess and there's always little puddles underneath from where it's dripping off. |
September 10th, 2011, 04:11 PM | #32 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Thanks for this! just cleaned and lubed my chain for the first time, was pretty easy but working around the left side exhaust can was a PITA I want a 2-1 exhaust now.
September 10th, 2011, 04:40 PM | #33 |
The video shows a 2008+ model, they only have one exhaust
June 13th, 2012, 10:42 AM | #34 |
Guest
Posts: n/a
Thanks for the DIY vid. Gonna stock up on WD40 and the DuPont Teflon spray from Walmart and try cleaning my chain in a week or so.
June 13th, 2012, 10:43 AM | #35 |
I can't believe people still look at this thread. Awesome
June 13th, 2012, 10:46 AM | #36 |
Guest
Posts: n/a
June 13th, 2012, 01:06 PM | #37 | |
DuPont Teflon Chain Lube - Formulas have changed
June 13th, 2012, 01:14 PM | #38 | |
Guest
Posts: n/a
October 15th, 2012, 08:16 AM | #39 |
Are you sure about that?
Name: That's "Sir" to you!
Join Date: Sep 2012 Motorcycle(s): Ninja 250R-F16, Versys KLE650 CAF Posts: 418
I tried Wurth Chain and Brake Cleaner yesterday. I bought this because I was being lazy and I saw lots of really great reviews. My chain was looking grubby and the idea of spray, wipe and done was very attractive. So, I bought the combo cleaner, lube and cleaning brush.
I removed the chain guard, went for a fifteen minute ride to warm up the chain, stuck the bike on the stand and got spraying. Dirt was definitely coming off and I was pleased. I left it for about ten minutes and then sprayed the chain again and used the cleaning brush. More dirt came off. Great! I finished the job by spraying the last of the can onto a lint-free cloth as I wiped the chain. A little more dirt came off. 15-minutes after I started, I was done. The only problem was, the chain wasn't really clean. It looked "OK", but between the links and around the 'o' rings I could see dirt. After sighing heavily, I did what I should have done in the first place. I got a jar of paraffin/kerosene, an old toothbrush and (another) cloth and started cleaning the chain properly. This time it took me about 30-minutes, but at the end of it the chain really was clean. Summary; I think that the Wurth stuff is good for a 'quick' clean, but it really isn't good enough. Paraffin/kerosene is cheaper and better. It takes about two to three times as long to clean with paraffin, but if you load up a good album on your MP3 player, take a deep breath, and get focused on the job, it's actually quite good therapy. Also, if I hadn't waited 1,200 miles since the last time I cleaned it, it would have been easier still. |
October 16th, 2012, 11:48 AM | #40 | |
hates stupid people
My vlogging channel: Ma1iciousLogic |
How often should you clean/lube chain? | clintalmighty | 2008 - 2012 Ninja 250R Tech Talk | 11 | January 8th, 2011 03:22 PM |
Clean and lube chain Help! | BlueRaven | 2008 - 2012 Ninja 250R Tech Talk | 18 | June 20th, 2010 07:10 PM |
[visordown.com] - Free Silkolene chain clean and lube at Cadwell | Ninjette Newsbot | Motorcycling News | 0 | June 9th, 2010 11:40 AM |
Clean chain & lube interval | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 20th, 2009 10:18 PM |
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review | Ninjette Newsbot | Motorcycling News | 0 | May 18th, 2009 09:50 PM |
