Old August 5th, 2010, 09:48 PM   #1
bdavison
Wartown, USA
bdavison's Avatar
Oh yeah!!! Kawasaki Green LED's.....
I wanted a little bling on the bike. So I just finished installing 8 green LED clusters in the fairings. 4 on each side. The LED's are managed by a switch installed in one of the little round sidecovers. This way, if I need to turn them off, I can bump it with my shin while riding, and its discrete.
The LED's are on a seperate circuit, so I can run them during bike nights without the engine running. They draw less than one amp, so its no biggy.
Old August 5th, 2010, 10:41 PM   #2
jmgrande
YEAH! Custom name tag.
jmgrande's Avatar
Motorcycle(s): 2010 Ninja 250R SE- SOLD to maverick9611
I love it! I think it looks awesome! Write up for install??
jmgrande is offline   Reply With Quote
Old August 5th, 2010, 10:47 PM   #3
JBar215
JBar215's Avatar
Motorcycle(s): 2005 Ninja EX250, 2005 SV650S
This is an awesome mod. How did you wire it and where did you mount the LED's?
JBar215 is offline   Reply With Quote
Old August 6th, 2010, 08:13 AM   #4
bdavison
Wartown, USA
bdavison's Avatar
There are four LED clusters on each side for 8 total. They are mounted to the inside of the fairing, and have a plug similar to the turn signals so that I can disconnect them when I remove the fairings. I mounted them using industrial double sided 3M tape.
The wiring is run into the little round side cover, where it meets up with a push/pull switch. The switch is connected to a fuse, and then to the positive terminal of the battery. Of course the other end goes to ground.
Old August 6th, 2010, 08:19 AM   #5
bob706
bob706's Avatar
Looks really good
Old August 6th, 2010, 08:33 AM   #6
bdavison
Wartown, USA
bdavison's Avatar
Here is a wiring diagram
Here is the wiring diagram, showing how I wired it all up. Really simple easy.
The LED clusters and push/pull switch I got from a local autoparts store.
I spent most of my time, waterproofing everything with heatshrink. It took about 45min to install it all.
Old August 6th, 2010, 09:10 AM   #7
brian smith
brian smith's Avatar
Motorcycle(s): 2008 ninja 250r
Where did you get the LED's and how much? This is exactly what I want for mine.
Looking for a career in construction? Go to http://www.acp1.com/index.php
brian smith is offline   Reply With Quote
Old August 6th, 2010, 09:57 AM   #8
bdavison
Wartown, USA
bdavison's Avatar
I got em from advanced auto parts.
There are tons of these LED things out there. The SMD strips are really nice too, and much easier to install, its just a sticky backed strip of LEDs. Unfortunatly, my store here didnt have them in green....so I just got the cluster ones. Id recommend going with the strips if you can find them in the color you want. In my opinion, they are much brighter, and far easier to install.
Two things that might trip you up.
First...the LED placement. Dont just slap them on there anywhere, pick your positions really carefully. You want them to light up the internals, but you dont want to see them. Hide them well, and walk around the bike with them on to make sure there isnt any spot where you can see the LED itself.
Second, pick your switch carefully.
I had to do a lot of work to make the switch fit right into the side cover. I ended up having to modify the switch case because it was too big to fit in the frame hole. I wanted one of those pushbutton switches where you click it on or off, but I couldnt find one.
Third, make sure you clean and prep the area where you are sticking them. You dont want them coming loose during a ride. Toss the crap tape that the LED's come with, and go get some good high quality 3M automotive/industrial double-sided trim tape.
Fourth, USE A FREAKIN FUSE. This should be a no brainer, but people miss this all the time. It should be 1.5-2A tops for LED's. Just power up all the LED's and measure the current, then fuse it properly.
Fifth, heatshrink ALL the connections, and make everything as waterproof as possible.
The good thing is if you connect it on a seperate circuit, and not into the bikes wiring...if something goes wrong. It doesnt fry your bikes wiring harness. And you get the advantage of being able to light it up without the key in the ignition, or the engine running.
Old August 6th, 2010, 06:52 PM   #9
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
i just ordered some blue SMD strips from ebay and a waterproof switch. dunno how good the strips are going to be since they were hella cheap, but you never know. sometimes it's a pleasant surprise
kamikaze is offline   Reply With Quote
Old August 7th, 2010, 10:35 AM   #10
ricochet08
ricochet08's Avatar
Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D
looks amazing man, nice job
ricochet08 is offline   Reply With Quote
Old August 7th, 2010, 07:26 PM   #11
bdavison
Wartown, USA
bdavison's Avatar
I did a little more work tonight. I really wanted to get the windshield to glow.
It was a nightmare to get it right, since I had to disassemble the front end of the bike to get the LED's in there.... but I finally got it.
I used a green SMD light strip, carefully placed in the front of the fairing to get the windshield to glow green.
I think it looks WICKED cool with it all lit up. The pics dont do it justice, as they mess with the colors. The color is the exact same color as the bike...that nice kawasaki green.
Old August 7th, 2010, 07:41 PM   #12
bob706
bob706's Avatar
Windshield glow FTW! Looks awesome
Old August 7th, 2010, 09:33 PM   #13
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
That looks awesome I really like the windshield part
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old August 8th, 2010, 10:23 AM   #14
addy126
Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt
Great Job... I love it!
addy126 is offline   Reply With Quote
Old August 8th, 2010, 11:00 AM   #15
sixer
no joy
sixer's Avatar
Motorcycle(s): Ninja 2006 636
nice one on the windshield +1
sixer is offline   Reply With Quote
Old August 8th, 2010, 01:40 PM   #16
lets see the drive-by shot!
Old August 8th, 2010, 02:19 PM   #17
bdavison
Wartown, USA
bdavison's Avatar
Ill see what I can do....Its hard being single, nobody to hold the camera.
Old August 8th, 2010, 07:13 PM   #18
bdavison
Wartown, USA
bdavison's Avatar
Ok, I tried three times to set up the camera on auto shutter, and couldnt get a shot....so in the meantime.....photoshop!
Old August 8th, 2010, 07:32 PM   #19
Old August 11th, 2010, 03:36 PM   #20
tjkamper
tjkamper's Avatar
I likey!!! LED Glow is awsome on bikes.
Old August 13th, 2010, 08:43 PM   #21
Cazper
ninjaholic
Cazper's Avatar
Nicely done! I might try something similar in the future... thanks for the idea!
09' SE Ninja 250R
$2,547.83
Old June 26th, 2011, 06:52 AM   #22
Outlander Systems
ninjette.org Tengu
Outlander Systems's Avatar
Motorcycle(s): Kawasaki Ninja ZX6R
Bryan, this mod is beyond awesome.
Outlander Systems is offline   Reply With Quote
Old June 26th, 2011, 05:32 PM   #23
Buffalony
Buffalony's Avatar
And I got crapped on for installing speakers!!
A chick around here has the same bike and her underglow installed by a local custom shop and it doesnt look anywhere as good as yours. I love the windshield too btw. nice touch.
Old July 6th, 2011, 12:38 AM   #24
DarkNinja52
DarkNinja52's Avatar
Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased)
I think I'm in love....
need.leds.now!
DarkNinja52 is offline   Reply With Quote
Old July 6th, 2011, 08:57 PM   #25
treehero6
treehero6's Avatar
Motorcycle(s): 2010 Ninja 250r ...red
Getting LEDs on my bike. I wanted to see how you guys solved the problem with the right side fairings or if the heat from the exhaust is even a problem for the LEDs. Placement pictures would be greatly appreciated.
LED I plan to use is from here.
http://www.superbrightleds.com/cgi-b...-flexible.html
treehero6 is offline   Reply With Quote
Old August 27th, 2011, 10:56 PM   #26
DarkNinja52
Any word on heat being an issue for the LED's??
Old August 28th, 2011, 02:41 AM   #27
treehero6
treehero6's Avatar
Sadly no, haven't heard anything. I ended up spending money on projector lights and retrofitting it to my head lights which I'm in the middle of doing. ... LEDs would have been easier lol.
Old August 30th, 2011, 02:06 PM   #28
Boomstick
Boomstick's Avatar
I found a set of LED stripes, kit comes with 6 stripes, tape and wiring and a remote to change the colors and sequences of the lights. I am wondering if you certain brand is better then another or if these things are all pretty much the same product just different companies??
Boomstick is offline   Reply With Quote
Old August 30th, 2011, 02:14 PM   #29
AeroXtasy
New 2-Wheel Addict
AeroXtasy's Avatar
Motorcycle(s): Blue 2009 250r Kawasaki Ninja
As far as I know, they're all pretty much the same as long as you buy from a well-established company.
But I am not 100% certain.
AeroXtasy is offline   Reply With Quote
Old August 30th, 2011, 02:20 PM   #30
Boomstick
Boomstick's Avatar
I found them on Amazon, and I have done alot of shopping through Amazon before and they have never let me down.
Old August 30th, 2011, 02:23 PM   #31
AeroXtasy
New 2-Wheel Addict
AeroXtasy's Avatar
Amazon offers returns too. If you're not satisfied with the brightness or quality, send them back!
Old August 30th, 2011, 02:24 PM   #32
Azhyen
ninjette.org Pirate
Azhyen's Avatar
Very nice OP! Well thought out!
"She said I can't get a bike, so I dumped her."
Azhyen is offline   Reply With Quote
Old August 30th, 2011, 02:47 PM   #33
Boomstick
Boomstick's Avatar
Yea buddy! I'm stoked, about to get a ton of work done on this big go cart
Old August 30th, 2011, 03:10 PM   #34
bdavison
Wartown, USA
bdavison's Avatar
Oh, and no, heat has not been a problem. Just make sure you route the wiring so that it does not rest on any hot parts. There is a good 2" between the engine and the fairings, so heat shouldnt be a problem.
Ive still got them running on mine. I did have one LED go out, but it wasnt heat related. I think I broke it while I had the fairings off doing the valve adjustment.
Ive been looking at the Kuryaken LED kits for motorcycles. A few of the guys here have them, and they are SUPER bright, you can even see them in daylight. I dont know if they make them in green though.
Old August 31st, 2011, 06:36 AM   #35
azimmer11
azimmer11's Avatar
i was debating on putting LEDs on my bike but questioned if i'd ever use them or not...considering they're illegal and you can only have them on when your bike is just sitting there
azimmer11 is offline   Reply With Quote
Old August 31st, 2011, 07:00 AM   #36
bdavison
Wartown, USA
bdavison's Avatar
It depends on where you live, and what kind of lights you choose.
RED and BLUE are big no-no's for many states or LE because...well...LE uses them. Some states ban them all.
Here where I live, I ride around at night with them on all the time, and cops couldnt care less, and surprisingly here, they dont even care if they are blue or red.
Old August 31st, 2011, 01:24 PM   #37
azimmer11
azimmer11's Avatar
yeah i know red and blue are a garaunteed no. i'm not sure if green are illegal here or not however.
Old August 31st, 2011, 02:46 PM   #38
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
to find out for sure you can e-mail your State Police, that's what I finally did here in Illinois (which here, all add-on lights are illegal while riding on the road)
kevheads is offline   Reply With Quote
Old September 21st, 2011, 05:45 AM   #39
kcaja1
kcaja1's Avatar
Motorcycle(s): '09 250R
Here's a good idea, put some white LEDs at or through the seat cowl and point them toward the rider. While you're at it add some at the front and also point to the rider. This will be an awesome visibility DIY.
--Power is nothing without control--
kcaja1 is offline   Reply With Quote
Old September 21st, 2011, 09:43 AM   #40
c717905
c717905's Avatar
Motorcycle(s): 2009 Black Ninja 250, 2009 Black ZX-6r
I'm not entirely sure what you mean by under the seat cowl and at the rider (the rear seat replacement cowl possibly?), but I believe I did something similar.
These look blue in the pics, but they are white strips, 16 of them total. I originally only had a few strips under the side fairings, but I decided to add a few more to the main fairings as well as some directly under the seat, behind the battery compartment, plus some underneath the cowl directly beneath the seat.
It isn't nearly as good as the OPs, but I rather like it.
Black '09 250R: Bridgestone BT-021s-Yoshi CF Slip-On-Fender Eliminator-Corbin Seat-Seat Cowl-Proton Flushmounts-BikeLiteZ Taillight-LED Glow-HIDs-Reflective Rimtape-Yoshi Rearsets-MRA DB Windscreen
c717905 is offline   Reply With Quote
Yeah, yeah...I know...Beer, Bacon and Boobies. Shoganai New Members 46 March 2nd, 2015 11:46 AM
