August 19th, 2010, 01:50 AM | #1 |
Lean in
Join Date: Jul 2010 Motorcycle(s): Pearl White 250r, Raven R6, Black 600RR, Silver Ninja 250 Posts: 111
Loss of power prior to stalling. Suggestions?
Hey guys. I'm having some trouble with my bike recently and I want to get your opinion on what might be wrong.
2008 Ninja 250r 3 #4 washers under each shim UNI air filter - Removed snorkle Full Area P replica exhaust Kleen air system plugged 3 times my bike stalled on me. This was after removing the Kleen air system, Putting washers in, and removing the gas tank for a paint job. I will be riding along and the usually smooth exhaust sound starts to burble. It goes from a smooth vrooooooommm to a vroomroomromroom and I start to lose power. I find myself putting more throttle just to stay at the same speed, and then in about 15 seconds after the loss of power starts my bike stalls completely. I pull over, try to start it and it doesn't budge. After about 10x of 5 seconds bursts of holding the starter, it finally starts. Rev it a few times and it seems normal. Burble is gone. Power has returned. Any Ideas of what could be wrong? - Debris getting into the fuel? - Bad shimming job? - Messed up removing the Kleen air system? Thank !! |
August 19th, 2010, 02:09 AM | #2 |
next time that happens, try popping the gas cap open and see if the bike starts after that. could be a blocked air vent for the fuel tank.
August 19th, 2010, 02:17 AM | #3 |
Lean in
Hmm that's a good idea. I spray painted my gas cap so I could have maybe clogged it up.
Kkim don't you ever sleep?? Thanks for the help again. |
August 19th, 2010, 03:58 AM | #4 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
sounds just like when I ran outa gas that one time, I would expect he's right
August 19th, 2010, 05:47 AM | #5 |
Take a look at these. I don't think a solution has been determined yet. Both my 08 & 09 do this occasionaly. I believe it has something to do with the tank venting.
http://www.ninjette.org/forums/showt...&highlight=cdi http://www.ninjette.org/forums/showt...&highlight=cdi
August 19th, 2010, 05:56 AM | #6 |
+1 for tank venting
August 19th, 2010, 03:52 PM | #7 |
Join Date: Jul 2010 Motorcycle(s): 2011 Suzuki GSXr 750 Posts: 60
Does it sit outside in HEAT? The gas turning to vapor from the sitting in the heat can cause your bike to do exactly that. Just my 2 cents.
I'm not short... I'm fun size. |
August 19th, 2010, 07:28 PM | #8 | |
Anyway, I have had this happen numerous times on a completely stock bike. Usually, it happens when I run it hard after a cooling event (rain or 8-20 minute cool down after full warm up). We've been discussing it in other threads, but no solid confirmation/diagnosis yet. dubojr1 just recently had it happen on his with an in-line fuel filter and confirmed that the engine gets no gas when this occurs, so now we are getting somewhere. Last futzed with by CZroe; August 20th, 2010 at 10:15 AM. |
August 20th, 2010, 05:52 AM | #9 |
Alex... Should we merge these?
August 20th, 2010, 06:03 AM | #10 |
I'm OK keeping these separate. If people are having problems with their bikes and there isn't a clear solution, it's not clear if the problems they are having are actually the same anyway. It might be linked to the other threads, but it may not as well.
I do think this one is related to tank venting, though...
August 20th, 2010, 07:56 AM | #11 |
Ok... I see your point and would have to agree.
August 20th, 2010, 09:59 AM | #12 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
The bike wouldn't roll after it stalled? If the rpms started to decrease even when applying more throttle. There is a chance your rear brake could have been dragging.
This is probably not the case but you never know.
Sportisimoto USA is born. |
August 20th, 2010, 10:18 AM | #13 | |
August 20th, 2010, 10:23 AM | #14 |
That is true. Which thread SHOULD we post updates to? It is not the CDI, I have a new BRT TIS.
August 20th, 2010, 01:21 PM | #15 | |
August 20th, 2010, 01:23 PM | #16 |
merge the threads for what???
we haven't even figured out what the problem is with his bike yet and you guys are assuming you know the answer even before it's even fixed? I agree with Alex, leave the thread alone so we can figure out what's wrong with the bike instead of confusing the issue with something that may not be his problem at all. |
August 20th, 2010, 01:32 PM | #17 | |
August 20th, 2010, 01:38 PM | #18 | |
August 20th, 2010, 01:43 PM | #19 | |
August 20th, 2010, 02:03 PM | #20 |
Small Bike Abuser
Join Date: Aug 2010 Motorcycle(s): 2010 Ninja 250R SE, GSX650FK8, DL650K5, CH80K2, AN400K7, SH150i Posts: 95
Don't forget about the small inline fuel filter at the inlet of the carb???
Part #49019 in this photo http://images.powersportsnetwork.com...1527_E1611.jpg |
August 20th, 2010, 08:22 PM | #21 |
Lean in
I'll give the gas cap thing a try. Is there any chance I could have clogged it up when I spray painted the cap black? I never had this problem before I removed the tank for the paint job and painted the cap at the same time.
It rolled fine, rear brake isn't an issue. |
August 20th, 2010, 08:25 PM | #22 | |
Lean in
August 20th, 2010, 08:26 PM | #23 |
Lean in
August 21st, 2010, 12:37 AM | #24 | |
It's not hijacking when it's relevant. Are we supposed to make ANOTHER thread in which to discuss this thread and compare it with the CDI one and any more that may pop up in the future? The ONLY difference in his description here is that it's not remotely stock and it doesn't seem to take as long for him to start it up again without opening the tank.
It seems that operational heat is all that is required. Cooler external temps may, in fact, be what trigger it (sudden cooling from rain or short cool down before running hard again). When it cools, I think that the tank develops a vacume faster than it can vent and, thus, fuel delivery stops until pressure nearly equalizes again. |
August 21st, 2010, 02:04 AM | #25 | ||
this... Quote:
My troubleshooting experience has led me to investigate the last thing that you did before a problem starts. Many times it's something that was done recently that causes the problem. Sending him off to investigate a possible CDI problem, when it is most likely not, is just a waste of time at this point. While there is a very slim chance of it being the problem, there are easier, more productive, conclusive options he should be looking at before concluding a faulty CDI as his problem... a problem that you guys can't even confirm/fix even after months of head scratching. If it does prove to be a CDI problem, then yes, I agree that a simple post in the other thread linking others here will help, but until it is proved to be a CDI problem, let the guy fix his bike. |
August 21st, 2010, 05:23 AM | #26 | |
We know now that it is NOT the CDI and are not trying to lead him in the wrong direction. The other thread is where the "trial and error" problem solving is happening with current updates. The 'Bad CDI" thread has developed itself into a fuel issue. The same fuel issue s2kenny is describing. Maybe the solution IS to start a completly new thread.
August 21st, 2010, 05:41 AM | #27 |
Settle down, kiddies. I edited the title of the other thread to "strange problem, bike losing power then stalling". Neither that thread nor this thread have a conclusive fix, and it's not clear that it's even the same problem, so they are fine on their own. Anyone searching for "stalling" will now find them both anyway.
If I search on CDI, there are a whole bunch of threads about it, as well as an entry in our wiki: http://www.ninjette.org/wiki/Ignitor_problem Largest CDI thread: http://www.ninjette.org/forums/showthread.php?t=21043
August 21st, 2010, 06:05 AM | #28 |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
It has been reported that some of the smaller magnetic tank bags that have a smooth rubber bottom are doing a great job of blocking the venting at the cap on a variety of carbed bikes. (Sportrider,Motorcyclist,Cycle World, not sure which in the tech question section, issues are at work so I don't have them here.)
I also had a problem when I did the carb work of pinching one of the vacuum lines from the carb to the pump/fuel tap. This reduced the amount of vacuum to work the diaphram enough that it would run out of enough fuel in the float bowls to keep the bike running.
2009 KLE650 LSL bars, Full Muzzy PC-V 1995 900SS/CR mildly modified |
August 21st, 2010, 06:49 AM | #29 | |
August 21st, 2010, 08:36 AM | #30 | ||||
Yes, you are right about proper troubleshooting technique, but the conclusion here is that it is likely a venting problem which his recently painted cap may have exascerbated. That doesn't make it a different issue, per se. Same as my 15,000 miles of dusty debris and a tank bag are exascerbating factors in mine. Quote:
August 21st, 2010, 08:47 PM | #31 |
Lean in
Thanks for everyone's responses.
I'm fairly certain it's a fuel related issue. Here is a pattern I just realized. Ride 1: 11pm at night. -Started our ride and went for about 40 minutes riding fairly hard. -Took a break for about 10 minutes at the end of a street and turned the bikes off. -Started the bikes up again just fine and headed down the highway. -5 minutes later the bike started bogging going uphill on the highway. -Stalled, and restarted. Ride 2: 12pm at night -Started for a ride and went for about an hour -Pulled over and took a break for 10 minutes -Started right up and turned around to head back -5 minutes later I started to bog -Stalled and then restarted -Rode for 30 minutes just fine -Pulled over and took another 10 minutes break -5 minutes later I started to bog -Stalled and restarted So it seems that whenever I go for a long ride, take a break, and start up again to push the engine. I get the stall condition. |
August 21st, 2010, 08:56 PM | #32 |
have you tried popping gas cap to see if that fixed the problem? take your extra key, ride with it inserted in the gas cap and when the bike starts to stall, pop open the cap and see if that stops the stalling.
August 22nd, 2010, 08:47 AM | #33 |
Join Date: Nov 2009 Motorcycle(s): 2009 Kawasaki 250R, 2008 Genuine Buddy 50 Posts: 121
I would like to add another data point in favor of a tank venting problem. This sounds identical to the problem I posted about two weeks ago and I believe I successfully narrowed it down to the rubber pad on my tank bag preventing the tank from venting which would cause me to stall out in the manner described in the original post after riding a while. Cracking the tank quickly got me back up and running, and periodically breaking the seal between the bag and the tank while riding also seemed to work, albeit with a bit more peril involved.
August 22nd, 2010, 03:00 PM | #34 |
Lean in
Haven't had the bike stall on me again yet. I'll leave the key in next time the conditions are setup again for a stall (Ride, break, ride)
August 22nd, 2010, 03:04 PM | #35 | |
Lean in
September 8th, 2010, 11:24 PM | #36 |
Lean in
So the verdict is... It's the GAS CAP!
I have taken a few more rides with situations setup for fuel starvation due to a vacuum in the fuel tank. And prior to riding I opened the gas cap to hear a rush of air suck into the tank. I haven't had a problem since I started opening the gas cap before riding. I think I'm going to try to thin out my cap with paint thinner or just replace it with a stock one. |
September 9th, 2010, 06:28 AM | #37 |
Remind me to never paint my gas cap, glad you found the answer though
September 9th, 2010, 06:46 AM | #38 |
My cap is not painted on either of my bikes. Problem still remains.
September 10th, 2010, 12:42 PM | #39 |
Lean in
Maybe you somehow have debris in the vent lines?
September 10th, 2010, 01:27 PM | #40 |
No power/Stalling | abszero7 | 2008 - 2012 Ninja 250R Tech Talk | 51 | September 13th, 2012 12:38 PM |
Loss of power? | oblivion007 | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 4th, 2011 08:07 PM |
Loss of power on highway (all the power) | aldenso | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 7th, 2011 10:27 PM |
Loss of power? | sudapuff | 1986 - 2007 Ninja 250R Tech Talk | 1 | October 19th, 2010 10:48 AM |
Strange Problem, bike losing power and then stalling. | empire00 | 2008 - 2012 Ninja 250R Tech Talk | 83 | August 20th, 2010 05:49 AM |
