September 23rd, 2010, 01:49 AM | #1 |
Fully Modified 250R with Gixxer Arms n forks.
Hi everyone, would like to share my mods to my 2010 250R..
gave it a massive surgery to the arms and suspension. will update more since i have lots to add on this Red Devil.. 1. front fork : a complete set of '08 GSXR 600 Radial 2. Swing Arm : 08 GSXR 600 3. Rims : ZX6R, Front 3,5-17 Rear 5,5-17 5. Tires : Bridgestone Battlax BT090, Front 120/60 Rear BT003 190/50 6. Brake cables : HEL 9. Windshield: Zero Gravity double bubble 10. Rear Huger : GSXR 600 11. Rear fender : Custom Cut 12. Brake Master Cylinder : Brembo 13. Handle : Brembo 15. Caliper : Front Double Tokico, Rear Nissin 16. Gear set : ZX6R 17. Chain : RK Type Gold O-Ring 18. Exhaust : Header Custom made, Silencer 2009 GSXR 1000 19. Head lamp : Ultra Bright Phillips operation begins done before and after ADDED VIDEO: Exhaust sounds (idle) http://www.youtube.com/watch?v=Ge3T56GNRw0 comments and feedback are highly appreciated.. thanks.. Last futzed with by aworkshop250; September 28th, 2010 at 08:40 PM. Reason: added video |
September 23rd, 2010, 03:12 AM | #2 |
self wrencher
Very nice. Excellent job.
September 23rd, 2010, 05:03 AM | #3 |
September 23rd, 2010, 05:42 AM | #4 |
Awesome
September 23rd, 2010, 06:06 AM | #5 |
Join Date: Aug 2010 Motorcycle(s): 09' 250 ARRRRRR Posts: 130
Wow.
Posted via Mobile Device |
September 23rd, 2010, 06:41 AM | #6 |
Join Date: Apr 2009 Motorcycle(s): '04 sv650s Posts: 438
Looks cool for sure.
There's 2 types of people in this world, those who complain and those who act. |
September 23rd, 2010, 06:58 AM | #7 |
Join Date: Sep 2010 Motorcycle(s): 1991 EX500 , 2009 250r Posts: 130
Looks great!
Details please I assume you cut down the pivot point of the swinger, sunk the bearings further? Custom Pivot sleeve or drill out the frame for the gsxr pivot bolt? How did you handle chain alignment? Front triple looks exactly like the ex500 triple which is a bit longer than most, did you swap the stem into the gsxr triples or did you make a custom top nut? Thanks Bob |
September 23rd, 2010, 08:08 AM | #8 |
MOTM - Mar '13, Jun '14
All that great work and a cool plate to boot.
September 23rd, 2010, 08:11 AM | #9 |
Wow.
September 23rd, 2010, 08:23 AM | #10 |
Join Date: Mar 2010 Motorcycle(s): Blue 10 250r Posts: 697
See, I would have....
Kept the 250 front end, kept the 250 swing arm, and wedged in the 600cc engine. Keep the bike a complete sleeper, and go look for victims. lol, very nice work. looks cool. |
September 23rd, 2010, 08:30 AM | #11 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Good job.
But with all those conversion parts why not just upgrade to a bigger bike? It's like converting a Civic into a Ferrari minus the power. |
September 23rd, 2010, 08:34 AM | #12 |
Giggity Giggity
Join Date: Feb 2009 Motorcycle(s): 08 ninja 250R aka Hiryu Posts: 481
nice , its like a 250 on steroids
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods |
September 23rd, 2010, 08:39 AM | #13 | |
Bob |
September 23rd, 2010, 08:41 AM | #14 |
You might be out run by a bicycle though cause there's no way that thing would stay on two wheels.
September 23rd, 2010, 08:45 AM | #15 | |
Anyway there is a reason they use thick perimeter frames for those inline 4s. They produce far more HP due to design than you get out of simply doubling displacement. An ex500 has somewhere near 50HP where as a modern 600 I4 has around 80-90. 100 extra CC's don't net almost double horsepower alone. Based on what I have seen so far, the ex650 looks to be the largest engine that can be put into an ex250. But for what it would cost you are better off just getting an ex650. Anyway, some food for thought. |
September 23rd, 2010, 09:31 AM | #16 |
Join Date: Jul 2010 Motorcycle(s): Candy Thunder blue 2009 kawasaki 250r, 2010 Dark Stealth Ducati Monster 696. Posts: 891
Awsome!!!!super cool!!!
September 23rd, 2010, 10:55 AM | #17 |
super ninja
Join Date: Feb 2010 Motorcycle(s): 2009 kawasaki 250r Posts: 127
Sick but why the rear tire u looks flickability
September 23rd, 2010, 08:28 PM | #18 |
Thank you all for the comments and compliments and critics..
bob138: Details: yes what you described is precisely how it goes, carved off a bit of the tip side for the swing arm to fit inside the 250 frame, about 2cm each sides. for the pivot bolt yes it was a custom built for the Gixxer arm to fit the 250. Chain alignment added about 0.5 cm to the front gear so the chain is now wider and straight with the rear gears. ill try to provide pictures soon. front forks using all Gixxers, triple is gixxers as well and the top stem used the original 250 and swapped it to the gixxer, was a bit short but enough to get it locked. ill try to provide and share more pictures on the mods. cab305: haha..would love to do that but its hard to find huge engines in our country. Nemesis: yes in the US understandings, it would be better to get a bigger bike, but in where i live, bigger bikes cost 2-3 times then what the normal price is.. a ZX6 would cost 29k,which is way ridiculous for a bike price so, what we tend to do here in our region is we take OEM parts of bigger bikes from across the globe and try to get it shipped here in the most cheapest way.... 250rStar: flickability? i used a 190-50 for the rear so i think its meant to be that way..(??) thanks all for your time to give feedback, i appreciate it. |
September 24th, 2010, 12:24 AM | #19 |
super ninja
i meant it as it seems to me(could be wrong tho) like the smaller tire would be able to make the bike faster to maneuver from sided to side in the leans then the bigger tire would be thats all, again could be wrong, does the handling seem any different and if so how? don't get me wrong not trying to bash, it looks SICK and i bet all ur friends are envious! lol i know i would be haha
2009 Ninja 250r aftermarket parts *HotBodies double bubble* *Swing Arm Sliders* *Sylvania Sliverstar Ultra* *Akrapovic Slip-on* *Shinto Clip-Ons/Grips/Bar Ends* |
September 24th, 2010, 02:18 AM | #20 |
250rStar:
oh..ok. hehe i get it. well maneuvering and handling has been great especially if you want to lean corners. well i was aiming towards a more of a sport bike feeling then the stock sport touring of a Ninja 250. the riding position has changed a bit, so the handling has changed slightly as well, i dont know how to explain it, but since the front forks are lower and i tend to maneuver more with my body leaning left n right according to where i need go. hope it explains a bit..sorry if it gets you confused... |
September 24th, 2010, 06:07 AM | #21 | |
That rear could potentially be close to the weight of the stock, considering a lower profile tire and a supersport rim, which could be lighter than stock. All in all. There is potential for equal handling, not exactly the same, but just as good with different quirks. As for the importing parts, I post a lot on customfighters.com so I've bumped into some of the streetfighter crowd from overseas. I've seen some of the work they do with the same type of stuff. All in all, amazing. You guys must have been real happy that they redesigned the ninja 250s. Much better bike to start with for you guys I assume Bob |
September 24th, 2010, 02:40 PM | #22 |
Join Date: Jan 2010 Motorcycle(s): 2008 Honda 1000RR, 2008 Ninja 250R Posts: 105
I've got an 08 gsxr front end on my 08 250 too. Only need one caliper (braided line and HH pads), it's just a little lighter than the stock front end it's f'in god-like braking into turns on the track. Still no power though.. :P
My buddy Brian has a busa front end, same story. |
September 24th, 2010, 02:52 PM | #23 |
Did you remove the second rotor too? Just planning and plotting at the moment but don't want to add weight.
Thanks Bob |
September 24th, 2010, 03:07 PM | #24 |
Yeah of course.
I have a single stainless Galfer brake line coming from the gsxr master cyl to a single caliper and rotor (I kept the right side) and I can practically do front flips under braking with just the one side. Ditch the 2nd set for sure. |
September 24th, 2010, 06:29 PM | #25 | |
Bob |
September 24th, 2010, 06:31 PM | #26 |
Also, fresh DOT4 and Galfer HH pads.
September 25th, 2010, 09:20 AM | #27 |
September 28th, 2010, 08:42 PM | #28 |
hey guys, thanks for all the comments and feedback..
i added a video from youtube to give example how the exhaust sounds like..just in case for anyone who is curious about it. cheers! |
December 27th, 2010, 07:25 PM | #29 | ||
Join Date: Dec 2010 Motorcycle(s): 2009 KAW Ninja250r Posts: 72
Sry 4 bumbin a slightly old post
BTW great mods! I'd give my left "bouncy ball" for dual front disk brakes. I hope you did a cleaner fender eliminator once you're all done. |
December 27th, 2010, 08:27 PM | #30 | |
Also, regarding the "why?": I have a GSXR front end and it's f'n dope. It's a whole new game, chasing down liter bikes through turns and braking zones. I've spent just under $3K (net) on my bike as it is now. While, yes, I would love to have a 550 v-twin converted GP bike, this bike does the trick for now. :P |
February 21st, 2011, 01:16 PM | #31 |
how did you get the front sprocket out farther, and doesit affect strength to move it further from the engine?
February 21st, 2011, 04:10 PM | #32 |
Motorcyclist
Join Date: May 2010 Motorcycle(s): 2014 Ninja 300 ABS Posts: A lot.
AWESOME bike, great job!!!
January 24th, 2013, 02:02 PM | #33 |
Join Date: Jan 2013 Motorcycle(s): ninja 250r 2012 Posts: 8
i need your help bro i followed ur mods and now ook i put 08gixxer swingarm and zx6r 06 wheel but im having problem how did you manage to fit the rear axel into the zx6r wheel for the gixxer swing arm for some reason is to big for the rear bearing of the wheel and it wont go thru the zx6r bearing also the brake system did you do something custom to it?
January 24th, 2013, 02:11 PM | #34 | |
Jigglin' your Jiglets
MOTM - Apr '13
This guy needs your help
January 24th, 2013, 02:31 PM | #35 | |
January 24th, 2013, 04:57 PM | #36 |
MOTM - Sep '14
we found your soul-mate look for rojoracing53 many posts here and you will hopefully see the humor
January 24th, 2013, 05:28 PM | #37 | |
January 24th, 2013, 05:33 PM | #38 |
MOTM - Sep '14
January 24th, 2013, 05:46 PM | #39 | |
MOTM - Apr '13
http://www.ninjette.org/forums/searc...&starteronly=1
January 24th, 2013, 06:42 PM | #40 | |
Fast-Guy wannabe
MOTM - Jan '13
FS: Red 2010 heavily modified 250r. Bloomington, Indiana | NathanUc | Motorcycle-related | 23 | March 30th, 2013 01:33 AM |
[sportrider - latest stories] - 2011 Yamaha FZ8 - Fully Capable, Just Not Fully Dress | Ninjette Newsbot | Motorcycling News | 0 | April 19th, 2011 02:50 PM |
looking for a 08-09 black modified 250r | hummer09 | Items Wanted | 3 | April 27th, 2010 05:26 AM |
