October 25th, 2010, 05:01 AM | #1 |
Join Date: Apr 2009 Motorcycle(s): 2000 250 sold; 2005 636 sold. BIKELESS IN ATLANTA Posts: 753
Bike shuts off while riding
After 7600 miles, my bike is acting up on me. It was giving all the classic signs of a bad battery. I replaced the battery and on my way home yesterday, it did it again. This was only a 2.5 mile ride. Right before it shuts off, I can feel it lose power. If I keep the revs high, it does better, but when I let ease off the clutch, it dies shortly after. After a few minutes, it starts up and I can go again... and then it repeats. It's not running hot, the temp gauges is where it normally is and this happens even if it has been sitting for hours. The valves haven't been checked/adjusted since the 600 miles service. I did check the fuel lines to make sure they weren't pinched.
How do I check the Stator? Suggestions, compliments, complaints? |
October 25th, 2010, 05:14 AM | #2 |
Hmmm... Sounds similar to other threads here on the 08+ 250's.
Check this thread and the "similar threads" below it. http://www.ninjette.org/forums/showt...light=stalling
October 25th, 2010, 05:55 AM | #3 |
Thanks. I didn't think to check the problem with the '08+. I do recall opening the gas cap the last time to be sure I had gas, and that didn't solve the problem. It still took about 7-10 minutes before it would start again. I did add SeaForm 2 days ago, but I still haven't had a chance to ride. Thing is this was happening at random times during the day/night. The last time it happened before I changed the battery, the bike had been sitting for 6 hrs. It took me 3x to kick start it. I will check the lines again along with the filter tonight. We are supposed to have 3 days of rain, so I won't get another chance until Thursday or Friday.
October 25th, 2010, 06:18 AM | #4 |
Ok. Sounds like you have a plan. Let us know how it goes and then we will move forward from there.
October 25th, 2010, 06:40 AM | #5 |
Join Date: Apr 2010 Motorcycle(s): 2009 Honda CBR600RR Posts: 633
bad plug?
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja |
October 25th, 2010, 07:06 AM | #6 |
October 25th, 2010, 08:58 AM | #7 |
Join Date: Oct 2010 Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900 Posts: 80
Maybe check the ohm reading on the pickup coil?
j98 |
October 25th, 2010, 10:41 AM | #8 |
October 25th, 2010, 11:09 AM | #9 |
are you sure you have enough gas? have you tried flipping to "reserve" when this happens to see if that helps?
October 25th, 2010, 11:59 AM | #10 | |
October 25th, 2010, 05:29 PM | #11 |
It's under one of the engine side covers. It's also called the crank positioon sensor. Easy to get to and test. You need one of the repair manuals and a volt/ohm meter.
Not sure if this is a sort of common problem with this bike but when this sensor goes bad they die suddenly, then cool down, then work again for a while before they die altogether. Not trying to discourage you, it's really not complicated once you look at the book. I have a Haynes manual and procedures and pictures are very clear. If a dope like me can do it then anyone can. j98 |
October 26th, 2010, 06:30 AM | #12 | |
October 26th, 2010, 06:33 AM | #13 | |
November 1st, 2010, 06:27 AM | #14 |
Ok, I decided to take the bike for a quick ride thinking it would be easier to trouble the problem when it happens. No luck, it ran just fine. I checked the battery again, plugs, hoses, etc and everything was fine. I will give it another shot this week to see if it happens again, otherwise, I guess I will have to pull the bike apart.
November 1st, 2010, 08:18 AM | #15 |
Pull the wires off the coil terminals and check for corrosion, clean and grease with silicone grease as needed.
The rubber hose under the seat from the back of the tank is a drain hose for the filler cap recess; pinching this line can have no effect on the way the bike runs. Take a 5mm Allen wrench and short length of clear tubing that fits the drain nipples on the carbs with you when you ride. Next time it stalls drain the carbs and see if there's any water in the fuel. Have you cleaned the filter screen in the fuel line where it connects to the carbs, or better yet installed a real fuel filter? |
November 1st, 2010, 08:53 AM | #16 |
Will the water/gas separate like oil/water? The fuel filter was clean as well. I thought changing the fuel filters was causing some bikes to have this same issue.
November 1st, 2010, 10:46 AM | #17 |
Yes, the water will sit in the bottom of the gasoline. When water gets into the carbs it sits in the bottom of the bowls where the drain screw is, blocking gasoline from the jets. But the more I think of it, the less likely water seems to be the problem to me. If there's enough water to drown the jets and stall the motor the bike will not restart until the water's been drained, no matter how long you let it sit. Since you're able to restart it after time that rules out water IMHO.
I'm leaning toward electrical/ignition. I had a similar problem where the bike would act like it was running out of gas and then lose most power. Wide open it would barely do 50 mph and that was only if I was already going that fast when it quit and there were no hills or head wind. It turned out to be a faulty connector at an ignition coil, corrosion combined with broken strands in the wire at the terminal. As for voltage, get a meter and measure voltage while running and while stopped. Stopped voltage should never dip below 12.0 volts; any less and a battery is considered discharged. While running and idling it should hover around 13-14V, especially with slight revving of the engine. Measure at the battery. Last futzed with by FrugalNinja250; November 2nd, 2010 at 06:23 AM. |
November 1st, 2010, 12:23 PM | #18 |
This seems to be on 08+ bikes and be careful which filter you choose to install. Some are in fact made for gravity flow and some require some fuel pressure for flow.
November 2nd, 2010, 05:28 AM | #19 |
Thx. Looks like we will have decent weather tomorrow, so I should be able to try this again.
November 12th, 2010, 01:32 PM | #20 |
Join Date: Sep 2010 Motorcycle(s): 1991 EX500 , 2009 250r Posts: 130
Sorry if this has been covered, I only skimmed the thread.
Did you check the vent in your gas cap? If it's plugged it can cut of fuel flow to the carbs. Bob |
November 14th, 2010, 10:09 AM | #21 |
I checked the hose, but not the plug. Is that near the top of the cap.
November 15th, 2010, 06:46 AM | #22 |
The long hose that is connected to the tank only drains from next to the filler neck in case of overflow. In the cap on the inside there should be a little hole. That hole has a check valve built into it to allow air in but no gas out. When that gets plugged it prevents the air from coming in and letting the gas go out.
You can clean it out with canned air, but, you need to blow through the correct side and with the tank filler hole covered so the junk doesn't fall in. More than likely there is a hole on the top near where the key goes in. That should be your air in and where you would blow the canned air. Bob |
November 15th, 2010, 07:08 AM | #23 |
Thanks, I'll check it out today. I rode another 18 miles yesterday without incident. I got on the highway and got up to speed several times on a 3-4 mile stretch. The bike started without any problems too. I think I forgot to mention, but I did add some SeaForm a while back, so maybe that helped clear it up. I was getting fuel at the same BP each week, with no problems. It's time for more fuel, so I'll try somewhere else, just to see if it happens again. It's hard to troubleshoot, when the problem isn't happening, but hopefully it doesn't happen again.
November 15th, 2010, 07:38 AM | #24 |
Next time the problem happens you can unlock the gas cap but leave it in place. If that solves it then the cap vent is plugged.
November 15th, 2010, 10:54 AM | #25 |
Yeah, I had my spare key and was ready for that to happen.
Bike shuts off immediately after starting. | psych0hans | 2008 - 2012 Ninja 250R Tech Talk | 9 | January 13th, 2015 01:06 PM |
bike loses power and shuts off on freeway | realmess | 2008 - 2012 Ninja 250R Tech Talk | 14 | March 18th, 2012 03:37 PM |
[sportrider - riding] - Riding Skills Series: Sport Bike Clutchless Upshifting | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2010 11:40 PM |
[sportrider - riding] - Riding Skills Series: Sport Bike Clutchless Upshifting | Ninjette Newsbot | Motorcycling News | 0 | January 26th, 2010 08:10 PM |
[roadracingworld.com] - Freddie Spencer's Riding School Abruptly Shuts Down--And A Re | Ninjette Newsbot | Motorcycling News | 0 | October 23rd, 2008 04:02 PM |
