February 20th, 2011, 05:09 PM | #1 |
Lifelong Rider
Join Date: Apr 2009 Motorcycle(s): mine-> '04 Kawasaki Vulcan 1600,'08 Ninja 250 / hers-> '05 Kawasaki Vulcan 800, '08 Kawasaki Ninja 250 Posts: 29
Removing bar ends
Anyone have a problem removing the stock bar ends ? I got some new ones with allen head screws with my slider kit but I can't get neither screw to beak loose on the stock ones. I even tried a impact tool you hit with a hammer and all I have done is buggered up the screws so bad I don't think anything will do it now
Jax Kingston TN '04 Kawasaki VN1600 '08 Ninja 250 |
February 20th, 2011, 05:19 PM | #2 |
Heat the screw up with a butane torch for a few minutes then take the impact tool or drill to the screw. Should come right out, just be careful cause it will be friggin hot
February 20th, 2011, 05:21 PM | #3 |
Lifelong Rider
I'll give that a try thx
February 20th, 2011, 05:35 PM | #4 |
February 20th, 2011, 06:07 PM | #5 |
Join Date: Jan 2011 Motorcycle(s): (08 Ninja 250) (07 Suzuki Hayabusa) (08 Suzuki GSXR 1000) (Yamaha dirtbikes) Posts: 33
I used a cutoff wheel on my angle grinder and cut into the end of the bar end and thru the bolt then the bar ends fell off and I used vice grip pliers to pull out the bolt stud. I did not want to put heat to it and the stock bar ends seemed useless to me so I did not care about damaging them. I ordered new heavy barends and love them.
http://www.amazon.com/Kawasaki-Heavy.../dp/B003V12XSW They are inexpensive, great quality, much heavier than stock and beefy. Also I was able to add washers to the inside of the bar end to get the desired space between the bar end and my heated grips. |
February 20th, 2011, 07:20 PM | #6 |
Motorcyclist
Join Date: May 2010 Motorcycle(s): 2014 Ninja 300 ABS Posts: A lot.
Torch for about 1-2 minutes a side worked for me too and as noted above it will be very hot so be careful. After heating I was able to easily use screwdriver to remove.
February 21st, 2011, 09:44 PM | #7 |
ninjee two-fiddie
Join Date: Oct 2009 Motorcycle(s): 2008 Ninja 250r Posts: 61
Only heat the screw head, not the entire bar end.Otherwise you might melt your grips.
It amazes me that Kawasaki is so liberal on red loctite for the bar end screws, but much more important fasteners on the bike have none. |
February 21st, 2011, 10:02 PM | #8 | |
February 21st, 2011, 10:18 PM | #9 |
Join Date: Sep 2010 Motorcycle(s): 04 250r(sold), 09 250r(sold), 07 CRF450x, 07 sv650(sold) Posts: 110
I used a ratchet with a #2 Phillips bit and it came right off.
February 21st, 2011, 10:21 PM | #10 |
I will get one for you tomorrow. They are the same diameter of the grip at the grip and then taper down a little, but look good IMO. They are a huge improvment over stock as they are beefy and heavy to reduce vibration. And come with a allen head bolt.
February 22nd, 2011, 01:09 AM | #11 |
Join Date: Sep 2009 Motorcycle(s): 08 Ninja 250 Posts: 36
I used a butane torch.
As someone said, make sure it is just the bolt otherwise you might start cooking your grips. Afterwards screws come of really easy. |
February 22nd, 2011, 01:25 AM | #12 | |
http://www.amazon.com/Kawasaki-Heavy.../dp/B003V12XSW |
February 22nd, 2011, 03:54 AM | #13 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
Jax, you aren't alone. Before I realized there was locktite in there, I mangled my bar end screws when I tried to take them off to change grips. Ended up using a little chisel to remake and deepen the mangled screwdriver hole for better grip, heating up the ends with a soldering gun to release the locktite, then used a ratchet attachment on the screwdriver. I destroyed the screws and had to replace them, but they came out.
If I had to do it again, I'd have gone straight to the soldering gun or torch and used an impact wrench. (I chose the soldering gun last time to localize the heat to the screw and protect the grips and throttle tube.) Locktite melts at 400 degrees and lubes the screw, so heat is really the way to go. Would have been able to save the screws that way. Also, if I had to do it again I would have switched out to the heavier bar ends with the allen head screws seen below. Allen head screws should have come standard on the bike if they are going to use locktite. Good luck.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
February 22nd, 2011, 05:40 PM | #14 |
Lifelong Rider
I will try all of the above this weekend --- thankx
BTW, I guess I need to post up some pics soon of the Black one in the garage next to the Green slower one and here I am talking bad about green when I have lots of Kawi green shirts plus a 12 ft Green Kawasaki banner in my garage as well as Kawi streamers hanging from the ceiling sorry Greenie owners, my bad LOL
February 22nd, 2011, 05:45 PM | #15 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
One screw of mine is also stripped - tried to remove before finding the site. Have the screw, but have not had no desire to try to remove the messed up screw after yelling at it back then...
February 22nd, 2011, 07:23 PM | #16 |
February 22nd, 2011, 08:28 PM | #17 |
February 22nd, 2011, 08:31 PM | #18 |
Motorcyclist
LOL, that's funny! But kkim is right, green is faster!
February 22nd, 2011, 09:18 PM | #19 | |
I just used my mom's creme brule butane torch. Worked like a charm. |
February 23rd, 2011, 03:43 PM | #20 |
Lifelong Rider
haha
color don't matter much here on the roads of East TN and W NC.... The Dragon and the Cherohala and the Blue Ridge don't care what color it is just as long as you ride and enjoy
February 24th, 2011, 11:18 PM | #21 |
February 28th, 2011, 03:52 PM | #22 |
Join Date: Feb 2011 Motorcycle(s): 2009 Kawasaki Ninja 250r Posts: 7
bar end removal
I used a #3 and it came off . . although it did break the bit . . lol. I did it in -3deg c weather though possibly why the btt broke. Used the #2 to finish the job. Did a number on the screw, may oped to change the screw down the road.
July 4th, 2013, 12:57 PM | #23 |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
RISE OLD THREAD!
Are there any new methods to removing the bar ends? Dont have an impact gun or heat gun, so i just used a massive bbq lighter and heated the bolt for about 4 minutes, tried, failed..and continued to 10 minutes. could definitely feel the heat when i put my hand on the grip..but to no avail. I know theres a good gallon of red loctite or so on them and ppl seem to get it with a heat gun, but no matter which method or tool i use, it wont budge..not even an inch. |
July 4th, 2013, 01:26 PM | #24 |
Join Date: May 2011 Motorcycle(s): 2006 GSXR 750; 1983 CB750SC Posts: 277
I used a propane torch (jet lighter would work too). I found that I had to tap the bolt with a hammer several times (and by tap, I mean put some effort into it, but don't go overboard). It should be fairly easy to remove the bolt after that.
July 4th, 2013, 01:28 PM | #25 |
Simple kind of man
Join Date: Apr 2013 Motorcycle(s): 2013 Ninja 300 Posts: 133
I used a porter cable impact drill and a large Philips bit, both came off in seconds.
One can also use a Philips socket on a long ratchet, just keep pressure against the socket and screw.
July 4th, 2013, 01:42 PM | #26 |
Ive tried all the methods in this thread other than the impact gun and obviously drilling the head off. I have a feeling im gonna have to completely destroy them to get them off, just like i did with my oil bolt >_>.
July 4th, 2013, 01:42 PM | #27 |
Skip all the hassle.
1/4" drill bit and 60 seconds of your time, and that bar end will be off. |
July 4th, 2013, 02:37 PM | #28 |
July 4th, 2013, 06:01 PM | #29 |
i have done it! 16threads of red locktight.... was also heating the bolt throughout the day....that was fckn ridiculous. F u kawi!
July 4th, 2013, 06:05 PM | #30 | |
http://2.bp.blogspot.com/_3MANcVjKs7...20/10cr_lg.jpg Grab that sucka and twist it out! |
July 4th, 2013, 06:06 PM | #31 |
dirty boy
MOTM - Apr '14
i got mine out with just a 1/4inch driver and a phillips screw head attachment, sure i broke 2 phillips head bits before i got the one out but they were cheaper bits
July 4th, 2013, 06:12 PM | #32 | |
sadly my new bar ends dont fit. Rojo tried to warn me but it was too late |
July 4th, 2013, 06:17 PM | #33 | |
July 4th, 2013, 07:00 PM | #34 |
Yeah they use tons of red locktite there. I drilled the heads on mine, still haven't gotten the shaft of the screws out
July 5th, 2013, 08:22 AM | #35 |
Join Date: Feb 2013 Motorcycle(s): '13 GSX-R600, '09 Ninja 250, 04 SV 650 (track) Posts: 157
July 5th, 2013, 12:56 PM | #36 |
Yeah well, I don't have the phillips head attachment for a ratchet, but I have a drill and drill bit, so it was cheaper and easier to just drill it since I went with WC bars anyways.
July 6th, 2013, 10:07 AM | #37 |
I'm crazy,your excuse is?
Mine came out after some pounding with a manual impact driver and then used the bit on a ratchet.
July 7th, 2013, 02:55 PM | #38 |
Join Date: Apr 2013 Motorcycle(s): 2010 250r SE (without stupid tribal decals) Posts: 110
After going to home depot to buy one my drill bit snapped while trying to drill that dang screw out. I got so pissed I smacked it with a rubber hammer and the head popped right off.
July 7th, 2013, 03:08 PM | #39 |
Did you use a cobalt or HSS bit? That's pretty damn impressive to break the bit like that...the oem screw was pretty soft. Maybe you applied pressure some pressure in the wrong direction?
July 7th, 2013, 04:23 PM | #40 |
Removing the bar ends | ChaoSS | 2008 - 2012 Ninja 250R Farkles | 2 | January 7th, 2013 03:14 PM |
bar ends | skikman | 1986 - 2007 Ninja 250R Tech Talk | 8 | January 7th, 2013 06:15 AM |
!@#$!ing bar ends! Torch, impact screwdriver, breaker bar, etc ALL failed. :( | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 64 | September 13th, 2012 11:50 AM |
ZX-R bar ends | Shaol1n Monk | 2008 - 2012 Ninja 250R Farkles | 14 | July 29th, 2011 12:30 PM |
Good kitchen tool for removing bar ends. | irishjohn | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 30th, 2010 07:39 PM |
