Old March 6th, 2011, 07:53 PM   #1
Chain Lube... What Do You Use and Why??
I've tried many different lubes over the years and recently have switched to using Dupont Teflon Multi Use. It goes on easily, doesn't make a mess, dries quickly and doesn't fling like conventional petroleum based lubes.
I was a Maxima Chain Wax convert for many years, but even that left me wanting a bit better lube for not flinging lube around while riding.
When I heard about the Dupont stuff, I was very skeptical, but after using it on the Ninja and even the dirt bikes, I'm sold.
So, what chain lube do you use and why?
Last futzed with by kkim; March 7th, 2011 at 10:09 AM.
Old March 6th, 2011, 07:57 PM   #2
cinjette10
Motorcycle(s): 2010 Ninja 250r Special Edition
My husband uses it on both of our bikes, best stuff he's found it goes on very nice dries quickly and the most important thing is it doesn't fling off all over everything.
cinjette10 is offline   Reply With Quote
Old March 6th, 2011, 07:57 PM   #3
patw
patw's Avatar
Motorcycle(s): 2009 Ninja 250 SE
Maxima is the only one I've used so far. I haven't had any noticeable fling issues. If the teflon based one smells better, I'll try it
2013 CRF250L
1985 GL1200 Interstate
patw is offline   Reply With Quote
Old March 6th, 2011, 08:04 PM   #4
The fling from the Maxima was not bad at all, but on occasion I would find a small black drop on the body work. No telling when you get it on your clothes and end up tracking it everywhere.
Yes, it does smell better/less than Chain Wax, which was one other thing about using it that I like, too.
Old March 6th, 2011, 08:26 PM   #5
Boom King
So, where's the reverse?
Boom King's Avatar
PJ1 Blue Label. Did some research on the internet and found that this stuff got some pretty favorable comments on various forums. It has worked well so far. Once the can runs out, I'll probably switch to the Dupont Teflon Lube as I can get a bigger sized can for a cheaper price than the PJ1 at my local hardware store.
Old March 6th, 2011, 08:29 PM   #6
utahninja
Ride Smart, Ride Safe
utahninja's Avatar
Motorcycle(s): 2007 Ninja 250, 2006 Yamati 150cc Scooter
Dupont Teflon Multi Use. Love it for all the reasons mentioned above.
Ride Smart! Ride Safe!
utahninja is offline   Reply With Quote
Old March 6th, 2011, 08:35 PM   #7
setasai
setasai's Avatar
+1 Dupont's Teflon spray is wicked. I use it on both bicycle and motorcycle chains and it's just fantastic at keeping everything clean. Even after washes.
Old March 6th, 2011, 08:39 PM   #8
grandelatte
Go Pack Go!
grandelatte's Avatar
Motorcycle(s): 09 250R, 07 XL1200L
Originally Posted by Boom King View Post
PJ1 Blue Label. Did some research on the internet and found that this stuff got some pretty favorable comments on various forums. It has worked well so far. ...
+1 been using it for MANY years.
09 Ninja 250R (commuter)
07 XL1200L (weekend fun)
02 SV650S (totaled by an idiot cager) & others
grandelatte is offline   Reply With Quote
Old March 6th, 2011, 09:54 PM   #9
nexus
ninjee two-fiddie
nexus's Avatar
Another fan of DuPont Teflon for the same reasons as stated in the OP. I also use it on my mountain bike.
nexus is offline   Reply With Quote
Old March 7th, 2011, 04:06 AM   #10
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
I've used both Castrol Chain Wax and Cyclo Industrial Graphite/Moly Lube (pretty much the same as the Schaffer #227). The Castrol wax was good, but I had concerns that a wax may not be as resilient as other lubes and I'd heard that waxes degraded over time more than other lubes, compressing more and lubing less. Plus, it flung off the chain a bit. Probably no problem if you clean and lube often.
The Graphite/Moly goes on messy and looks like you've coated the chain in grease. But it has an outstanding reputation for industrial chains and farming use, and has solid science behind it. The stuff has been on now for about 350 miles and is still there lubing like a sonofagun. And it hasn't attracted dirt/sand, and is holding onto the chain like glue, though I'm not sure how because it is so goopy. Weird stuff. Of course, for me the good reputation of the Graphite/Moly in industrial circles was just good luck. I use it because it was the only lube available on the entire island.
Probably more important that what you use is that you clean and lube regularly. Any dirt that gets in, lube that comes off, etc. would be pretty much a non-issue if you clean and relube every 3 or 400 miles.
Old March 7th, 2011, 06:04 AM   #11
dubojr1
dubojr1's Avatar
I love this stuff. I'm not sure but I think it's pretty much like the DuPont stuff but made with synthetic stocks. What ever it is made of, I absolutely love it!!!
I've also included a picture of the "waxy-like" film it leaves. The picture was also taken when the chain was ready for service. It had approx. 500 miles on the chain. Note the zero presents of dirt even though the path to my garage is 300 feet of dirt.
Old March 7th, 2011, 06:46 AM   #12
DaBlue1
DaBlue1's Avatar
Nothing but Maxima Chain Wax here. I use it on my motorcycles and bikes. I like the fact it does not fling and does not get as dirty as other petroleum lubes, makes the chain easy to clean. The smell is pretty strong though.
I've read some great reviews on the Dupont. I my buy a can and try it my next chain clean/lube session. They said it smells like a cross of WD-40 and coconut.
Old March 7th, 2011, 06:54 AM   #13
Apex
Livin' the Minimoto Life
Apex's Avatar
I always used Maxima Chain wax...
Old March 7th, 2011, 06:58 AM   #14
KGar
Mid Life Crisis
KGar's Avatar
Motorcycle(s): 2010 Ninja 250r (Passion Red); 1999 BMW K1200RS (Marrakesh Red)
I picked up a can of Dupont chain saver last week at Walmart.I cleaned the chain which had the factory lube on it (bike has only 425mi) and applied the new stuff on and let it dry completely. I have noticed that the chain makes more noise than before. Maybe I needed more product on the chain or remove the chain and soak it in kerosene? I will try that and report back.
KGar is offline   Reply With Quote
Old March 7th, 2011, 07:11 AM   #15
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Maxima wax. Seems to last pretty good, though I probably lube more frequently than I need to, and not messy.
Old March 7th, 2011, 07:45 AM   #16
karlosdajackal
karlosdajackal's Avatar
Motorcycle(s): Ninja 250R Fuel Injected Model 2009
putoline o-ring chain lube, its readily available and seems to work ok, goes on very easy, fizzes out of the can and snakes its way along the chain as it turns from foam to liquid
My vlogs on Youtube are here
karlosdajackal is offline   Reply With Quote
Old March 7th, 2011, 08:06 AM   #17
lux
I use Dupont Teflon Multi-Use too.
lux is offline   Reply With Quote
Old March 7th, 2011, 10:26 AM   #18
llenta
llenta's Avatar
Motorcycle(s): 2010 Daytona 675 SE
another fan of the DuPont Teflon Multi Use
llenta is offline   Reply With Quote
Old March 7th, 2011, 10:31 AM   #19
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
living in a sandy state i can't use anything that sticks, due to having to clean regularly (and re-do). Honda chain lube was the best when i got back into riding years ago and i ignore tech. stuff (real tard) so i'm still using the honda chain lube. i have seen guys with stuff they can't get off and chains that are literally white with whatever product, so i'll stick to my guns on this one. environment dictated, and a stick in the mud (me).
coondog is offline   Reply With Quote
Old March 7th, 2011, 10:35 AM   #20
"A"
vampire
Motorcycle(s): 2 many 2 list
I use whatever is on sale, keep chain clean and lubricated, seems to work well no matter which brand of lube.
"A" is offline   Reply With Quote
Old March 7th, 2011, 11:37 AM   #21
highpsiguy
highpsiguy's Avatar
Motorcycle(s): 1981 Honda Cx500 Custom, 2002 Ninja 250
WD40------- can of worms offically opened---------
"Rudeness is a weak persons attempt at strength."
highpsiguy is offline   Reply With Quote
Old March 7th, 2011, 11:53 AM   #22
"A"
vampire
I clean my chain with WD40, but need actual lube after cleaning.
Old March 7th, 2011, 11:53 AM   #23
europachris
europachris's Avatar
Motorcycle(s): '09 Ninja 250R (hers), '06 Buell XB12Ss (mine)
Sounds a lot like Tri-Flow.
I started out riding dirtbikes around 1980 and used a graphite-based chain lube until every shirt I wore had a stripe of black dots up the back.
My father, who got hooked on riding my little Yamaha GT80, went and bought an XS400 and discovered Tri-Flow.
I've been using Silkolene "Pro-Chain" by Fuchs on the wife's Ninja and it seems to work very well so far.
europachris is offline   Reply With Quote
Old March 7th, 2011, 12:15 PM   #24
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I never knew you were supposed to lube the chain! What a great idea.
Old March 7th, 2011, 12:18 PM   #25
you young kids... you should learn something and try it at least once.
Old March 7th, 2011, 12:40 PM   #26
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
Wow everybody uses that DuPont stuff. I use the maxima chain wax like others here. I'm fairly happy with it, but my gripe with it is that when it dries it becomes fairly tacky and I notice that it does attract dirt particles. From what I've heard that DuPont stuff isn't sticky at all after it dries. I should probably get off my butt and look for a can....
Old March 7th, 2011, 12:49 PM   #27
I usually can find it at Ace Hardware.
Old March 7th, 2011, 01:04 PM   #28
LOL - now do you lube the chain on a 2 stroke twice as often as on a 4 stroke, or vice versa, or do you just go by the number of cylinders?
You could lube every other link on odd numbered months, and the links in between on even numbered months.
Old March 7th, 2011, 01:05 PM   #29
now for the age old question - safe for o-ring chains?
Old March 7th, 2011, 01:12 PM   #30
good question. all I can say is that I haven't had any problems that I can see/tell. no O rings falling out of the chain.
Old March 7th, 2011, 01:15 PM   #31
LOL - the guy riding behind me had them all over his front fairing and helmet shield.
Will have to give it a try as my can of Maxima Wax is running low.
Old March 7th, 2011, 01:20 PM   #32
dubojr1
dubojr1's Avatar
Pretty sure I've seen it at Lowes and Walmart too...
Old March 7th, 2011, 03:31 PM   #33
Xoulrath
Xoulrath's Avatar
Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X)
It sounds very similar in function to the Royal Purple Max-Chain I use and it says it is safe for o-rings.
Xoulrath is offline   Reply With Quote
Old March 7th, 2011, 09:24 PM   #34
Memengkamatis
Memengkamatis's Avatar
Motorcycle(s): ex250r, vulcan 800b, k1200r
Chain Lube
I use the Maxima Wax and clean it off every 500 miles or so. After each ride, while the chain is still hot/warm, I spray a dose of Motorex penetrant. It's like WD-40 only better.
Meng
Memengkamatis is offline   Reply With Quote
Old March 7th, 2011, 10:14 PM   #35
DaBlue1
DaBlue1's Avatar
From Webbike world's review:
"I never considered that DuPont would develop a motorcycle chain lube, but the fine print claims that the lubricant "lasts 3-5 times longer in friction testing against other leading brands" and that it's recommended for use on chains, "O-Ring Safe". When I read that, I figured we had to give it a try".
http://www.webbikeworld.com/t2/motor...chain-lube.htm
Old March 7th, 2011, 10:27 PM   #36
tapdiggy
Humble Observer
tapdiggy's Avatar
Motorcycle(s): 2009 Yamaha XT250
Highlights from the Dupont website:
DuPont™ Teflon™ Multi-Use Lubricant
A superior multi-use lubricant featuring proprietary self-cleaning technology. Lubricates without attracting grit and grime, eliminates squeaks, prevents rust and protects moving parts.... Goes on wet... Sets up to a clean, dry, wax film which will not absorb dirt or grime... self-cleaning technology sheds contaminants to minimize or prevent abrasive wear... Highly resistant to water wash-off, and won’t fling off...
Applications: Motorcycle, ATV and go-kart chains (o-ring safe and no fling-off)... Can withstand temperatures up to 300°F (149°C)
Everything I post is "IN MY HONEST OPINION".
Why is "Parking Lot Enduro" not a thing?
tapdiggy is offline   Reply With Quote
Old March 7th, 2011, 11:00 PM   #37
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
I used the DuPont Teflon stuff. When I ran out of that I picked up a can of Motul for about the same price. Seems to do the same thing.
'08 Bonneville Black
sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator
Reswob is offline   Reply With Quote
Old March 8th, 2011, 12:08 AM   #38
Ichiro
Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150
DuPont Teflon
Ichiro is offline   Reply With Quote
Old March 8th, 2011, 03:57 AM   #39
n_aditya
n_aditya's Avatar
Motorcycle(s): 2010 Ninja 250R (for the weekend's) and the Suzuki Fiero for office commute.
The product description mentions that its safe for O-Ring chains.
I use Motul Chain Clean and Motul Chain Lube (Road) for cleaning and lubing the chain on my bike.
But the lube although sticky does fly off and causes a nasty mess on the wheel.... even when i spray the lube and leave the bike to rest for a couple of days before i ride out.
So i contacted DuPont and they will be sending me some information on where I can buy this in India. Apparently its not listed on the India page and i have not seen it in any shops here too.
Costs approx. US $ 20 as mentioned by the company rep I spoke to here.
n_aditya is offline   Reply With Quote
Old March 8th, 2011, 04:02 AM   #40
gfloyd2002
gfloyd2002's Avatar
MOTM - Feb '12
Okay, I'll bite. WD-40, while not ideal, makes a fine chain cleaner, but that is all. See discussion in this thread that talks about some studies on the lack of effect of WD40 on your o-rings on short term exposure, but moderate effect on your o-rings on long term exposure.
Because it has been shown to hurt o-rings on long term exposure, and because WD40 itself just isn't meant as anything other than a very light lubricant, you are better off going with one of the other products discussed in this thread. WD40 consists of 50% Stoddard Solvent (which is just desulferized kerosine with a lower flash point), 25% propellant, 15+% Mineral oil (light lubricating oil), and 10-% Inert ingredients. The solvent will act as a very good cleaner, which will leave your chain free of oils, but it is a terrible lubricant largely for the same reason. It is going to take stuff OFF your chain, and for a lube you want to put stuff ON your chain. And it will fling off your chain and not continue to protect it - and to the extent it does stay on long term, its solvent is slowly eating away at your o-rings while it is there.
Apart from the solvent issues, you are essentially just using a bit of mineral oil mix as your lube if you use WD40. And a little bit of mineral oil it just doesn't have the load bearing chemical properties to do the job needed - not enough lube for loads you put on a motorcycle chain. And if me saying so doesn't convince you, here is Motorcyclist magazine's take: "Whether it's WD-40 or LPS3, a motorcycle chain has such demands on it, and one of them is absorbing shock, whether it's between the sprockets and the chain, or whether it's between the internal parts of the chain. And WD-40 doesn't have that, it's not designed for that purpose, it's not formulated for that."
Last futzed with by gfloyd2002; March 21st, 2011 at 06:44 PM. Reason: added italics for emphasis to correct impression I agreed with WD40 as a lube.
did i get the right chain lube? RogerPapaMike 1986 - 2007 Ninja 250R Tech Talk 15 July 5th, 2014 08:44 AM
Chain lube! corksil General Motorcycling Discussion 27 June 20th, 2014 06:27 PM
Chain Lube OzzyDevil General Motorcycling Discussion 3 April 21st, 2012 07:41 AM
Chain Lube BobsPT 1986 - 2007 Ninja 250R Tech Talk 28 October 17th, 2010 08:49 AM
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review Ninjette Newsbot Motorcycling News 0 May 18th, 2009 09:50 PM
