Go Back   ninjette.org > Marketplace > Motorcycle-related
Old April 27th, 2011, 12:27 AM   #1
Group Buy: PREGEN- Area P Full Exhaust System
Okay, pregen owners, this is your chance to get in on a deal!!! This is another Ninjette.org only, exclusive group buy from Area P, so if you know pregen owners on other forums, let them know about the offer so they can get in on the great pricing. Everyone is welcome to participate as long as they are a Ninjette member.
First, some background on the system and it's development...
http://www.ninjette.org/forums/showthread.php?t=13852
After working with Kerry for a few weeks to get the best pricing for these, this is what he's come up with...
So here's the deal - the system would only come one way; 18" stainless steel muffler, 2.0" inlet/core/turn down exit tip.
More details from the AP site...
http://www.areapnolimits.com/product...Ninja-1988.php
Price for this system will be...
$295.00, plus $19.50 shipping (within the lower 48 states). Outside, we'll quote them the best rates by USPS.
The "Performance Kit", Jet Kits and/or D.E.I. will be available at the normal discounted prices noted on the website page.
As a comparison, AP sells their universal Stainless muffler only for $295, but this is a full system being offered... header pipe and muffler for this GB for this same price!
This GB will be open for 4 weeks from today. It will close on 24 May at 12 midnight Hawaii Standard Time.
We need a minimum of 5 participants to make this happen, so if you are serious and want to participate, please add your name to the list below by copying and pasting.
Thanks, guys.
____________________________________________________
1.
2.
3.
4.
5.
Old April 27th, 2011, 04:06 AM   #2
fjyang
fjyang's Avatar
Motorcycle(s): 87 Ninja 250, 90 Ninja ZX750R, GPZ 900r, 02 Moto Guzzi LeMans, 95 Triumph Speed Triple
1. Fjyang
2.
3.
4.
5.
fjyang is offline   Reply With Quote
Old April 27th, 2011, 04:07 AM   #3
Thanks, Frank.
Old April 27th, 2011, 06:40 AM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Read through the original thread but couldn't seem to find a definite answer to my question, namely, what muffler? Is the 18" the long or the standard (which I presume is the short?) muffler? Loudness, or better yet, lack of loudness, is important to me. Is the 18" as quiet as the original system? My main goal is a 2 into 1 so that I can use the helmet lock on the bike. Sounds simple I know, but that's what I want. A secondary goal is eventual conversion to FI so 2:1 is definitely needed for that.
Old April 27th, 2011, 11:20 AM   #5
I'll check.
Old April 27th, 2011, 11:42 AM   #6
kbryant
Area P
kbryant's Avatar
As indicated above, it is the 18" long stainless muffler only. With the 2.0" inlet/core/outlet, it is slightly louder than the long quiet core, but much quieter than the standard 12" muffler. No aftermarket muffler will be as quiet as the original oem system. Sound data & bytes are on our website for referance. The system should have no bearing on your helmet lock and/or location, but honestly I've never been asked that question before. Look at the picture and see if this will possibly answer this for you.
Old April 27th, 2011, 12:16 PM   #7
FrugalNinja250
The stock pregen helmet lock location places the helmet (face shield in my particular case) in direct contact with the left muffler, generally resulting in something melting, unless one waits long enough for it to cool down after a ride. The Area P system has one muffler on the right, making the helmet lock usable to me. IIRC you said an O2 sensor bung can be welded in place, can you supply one? Or suggest where to get one? I've got a TIG welder and just finished TIG class so should be able to weld it on myself.
Thanks!
Old April 27th, 2011, 12:36 PM   #8
kbryant
Area P
kbryant's Avatar
Here is my reply to a similar request. "
For the Bungs you have noted, the issue with using automotive type units is primarily the material and design. Our system is made from 304 series stainless steel. Most Auto bungs are from 400 or 303 series (they may say they are 304, but it is highly unlikely....). 400 does not weld very well and will rust. 303 is easier and cheaper to machine, but also is dubious when welding. Also they do not machine in any kind of orientation shoulder, so there is not additional support or location set. One of them you have noted is steel. I don't recommend you use a steel version.
Our Bungs are cnc machined from 304 series stainless steel only, which is costly and a pain. But they are done correctly and TIG weld perfectly. We also machine in a "Shoulder" so when we drill/mill the hole in the tubing, the Bung stays properly located for a smooth transition through the tube, as well as having additional support on the material. We pre-heat the component when welding (since it is so much thicker than the tubing) to assure minimal distortion with no stress cracking when cooling."
We charge $25 when purchased/installed with the system. Simply let us know where you would like it located.
Old April 27th, 2011, 03:42 PM   #9
Hunsy34
Hunsy34's Avatar
Motorcycle(s): 2009 Ninja 250 2016 Ninja 300 1994 KTM 300 EXC
1. Fjyang
2. Hunsy34
3.
4.
5.
Was hoping for the 12 inch I like the way it looks but the 18 inch will do!!!!
Hunsy34 is offline   Reply With Quote
Old April 27th, 2011, 04:49 PM   #10
Kerry... just noticed that Fjyang's bike is an 87'. Will this system fit his bike?
Old April 27th, 2011, 05:39 PM   #11
kbryant
Area P
kbryant's Avatar
Good question. Though we only list it for '88 - 07, from an exhaust standpoint, I don't believe there is any fitment issue/difference for '86-87 models. If I remember correctly, they did make quite a few other changes in '88. I had a fairly big crash in 1988 at the Suzuka 8 hour race in Japan, so I may not remember exactly every detail, on every model, prior to that year....
Old April 27th, 2011, 09:00 PM   #12
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
1. Fjyang
2. Hunsy34
3. Sombo
4.
5.
Even though it's not the long quiet core it can't be any louder then my current Yoshi pipe that is in need of replacement soon from corrosion on the pipe.
sombo is offline   Reply With Quote
Old April 27th, 2011, 09:07 PM   #13
Mike,
if you click the link to AP in the original post, they have dB readings of the system. I don't know what level the Yoshi pipe emits, but if you can find that info, it will at least give you some basis for comparison.
Old April 28th, 2011, 03:40 AM   #14
fjyang
fjyang's Avatar
Even though the body work on 86-87 model is completely different from 88-07 model, the engine is the same except for carb which went down from 32mm to 30mm to boost mid range. The 86-87 model dosnt have a lower fairing so I know for sure the header and mid pipe will fit. In fact I just mounted the sprocket cover and kick stand from a 2009 250 to my 87 as I like the look and it bolt right on which tell me the 250 engine is pretty much the same from 86-11. The clutch cover bolt pattern looks the same too.
The only issue it might have is the canister mount as the rear peg position is different between the two bikes but since Area P is a removable bracket and can slide up and down the canister, I hope I get lucky The earlier Yosh and Muzzy full system for the 88-07 model have a fix mount tab that is welded onto the canister or mid pipe so it won't work on the earlier 86-87 model but later Muzzy systems change to the modern system of canister bracket which should work.
Old April 28th, 2011, 07:24 PM   #15
sombo
sombo's Avatar
Mike,
Yah, I've seen that and how each of their pipes compare to one another. I was more impressed with the long quiet cores numbers. I also have no idea what the yoshi pipe's numbers are cause I don't think anyone has ever really tested it. My point was that none of their systems could really be any louder then my aging yoshi pipe, and therefore an improvement.
Old April 30th, 2011, 06:31 AM   #16
Hunsy34
Hunsy34's Avatar
I know each bike and climate are different but as far as a jet kit is there a base to go off of or is it a hit and miss. Really only wanna rejet this once and be done not keeping having to trouble shoot.
Old April 30th, 2011, 08:22 AM   #17
kbryant
Area P
kbryant's Avatar
Yes. We have jetting specs and can help fine tune them for your conditions.
Old April 30th, 2011, 06:34 PM   #18
Hunsy34
Hunsy34's Avatar
Ok thats good to know I am sure my buddy who works on bikes and I can figure it out. So we have 3-4 people signed up what do we need 5-7 or a few more?
Old April 30th, 2011, 06:42 PM   #19
Old April 30th, 2011, 11:16 PM   #20
fjyang
fjyang's Avatar
I got a Yoshi system too but have to repaint the sytem every few years is getting tire for me. The Area P is made of stainless and have direct access to oil fitler without removing the header along with keeping the center stand made the decision easier.
Did you ever did a Dyno on your Yoshi systems? wonder how it compare to Area P's in terms of HP.
Old May 1st, 2011, 08:39 AM   #21
sombo
sombo's Avatar
Nope, never did a Dyno with it and until I get the exhaust leak fixed and cam chain replaced there's really not much point. I need those two things taken care of to make sure it's in top condition before even thinking about putting it on a Dyno. Only thing is that if this group buy goes through I plan to just use that to fix the leak lol.
Old May 2nd, 2011, 03:55 PM   #22
Hunsy34
Hunsy34's Avatar
We have 3 people right now we only need two more. Can someone post a link on the 250.org site since there was a new topic started maybe they got lost.......
Old May 3rd, 2011, 11:19 PM   #23
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
been gone for a few daze
i'll be #4 on this list
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old May 4th, 2011, 12:00 AM   #24
okay, I'll add you
1. Fjyang
2. Hunsy34
3. Sombo
4. komohana
5.
Old May 4th, 2011, 06:21 AM   #25
FrugalNinja250
Still thinking about it. I really don't want a loud exhaust. The stock exhaust is ideal to me in terms of noise.
Old May 4th, 2011, 07:19 PM   #26
Hunsy34
Hunsy34's Avatar
You would be our 5th that would give us enough to go ahead and make the group buy!!! Dont be shy haha. Does anyone know the stock exhaust to the Area P exhaust as far as dbA?
Old May 4th, 2011, 08:50 PM   #27
sombo
sombo's Avatar
Their site has it listed with the shorter 12" 2"/core muffler and the 18" 1.75"/core muffler vs the stock:
Static sound readings:
.................................................... Idle 5000rpm
Stock ....................................... 80 dbA 86 dbA
Standard muffler (2.0" core) ....... 88 dbA 99 dbA
Long Quiet muffler (1.75" core) ... 83 dbA 90 dbA
Not sure what the dbA of the 18" 2"/core is though since they don't have it listed. But I would imagine it being somewhat between their other offerings. Perhaps it's somewhere in the range of say 85dbA idle and 95dbA at 5000rpm?
Old May 4th, 2011, 09:21 PM   #28
This is a quote from Kerry when we were discussing the GB.
The sound will be deep and low frequency, but on the louder side of things. Probably slightly quieter than our standard mufflers (12" muffler/2.0" core) with a deeper tone (less high frequency).
Old May 7th, 2011, 03:03 PM   #29
come on guys... one more and we can get this GB moving. who's up for a great exhaust for their pregen?
Old May 11th, 2011, 08:29 PM   #30
poorfatjames
Motorcycle(s): 1974 Honda CB550F, 1986 Kawasaki Ninja 250, 1975 Honda CB400F, [sold: 1999 Suzuki SV650]
anyone out there that has the 1.75" long pipe and wants to upgrade to this 2.0", I'd be interested it taking yours. send me a line.
poorfatjames is offline   Reply With Quote
Old May 14th, 2011, 08:35 AM   #31
poorfatjames
Does Area P have jetting recommendations for this group buy exhaust for stock air box and/or pod filter bikes?
-pfj
Old May 14th, 2011, 09:31 AM   #32
Hunsy34
Hunsy34's Avatar
couple posts up this is what was said when I asked
Old May 14th, 2011, 08:19 PM   #33
fjyang
fjyang's Avatar
Come On guys..... just one more. Can't believed the demand is that low, got to post where people will see. Besides the Yamaha V-Max and Kawsaki Concourse, the 250 has been in continuous production for almost 20 years, theres gotta be more then 5 people who want an exhaust system?
Old May 15th, 2011, 06:39 PM   #34
Bump the post on Ninja250.org? Their community is much more pre-gen-leaning.
Old May 15th, 2011, 06:45 PM   #35
I'd love to see pics with the new sprocket cover mounted.
Old May 17th, 2011, 01:28 PM   #36
One week left. If we can't get at least 5 people signed up, this GB will be closed at that time and will not happen.
Again, I have no vested interest in this, so if you own a pregen, please do what you can if you would like to see this happen.
gl, guys
participants to date...
1. Fjyang
2. Hunsy34
3. Sombo
4. komohana
5.
Old May 17th, 2011, 01:51 PM   #37
poorfatjames
done.
Old May 19th, 2011, 02:36 PM   #38
Mad-B-Man
Motorcycle(s): 07 EX250F, Honda NCZ50 Motocompo
I would have been interested if this was the quiet core
Mad-B-Man is offline   Reply With Quote
Old May 19th, 2011, 02:52 PM   #39
sorry, this GB is only for the muffler option that is listed in the original post.
Old May 20th, 2011, 06:31 AM   #40
FrugalNinja250
I've decided not to get in, though this is a spectacularly good deal. Reason is that I don't particularly want a louder than stock exhaust.
Muzzy full system for pregen (88-07) b.miller123 Motorcycle-related 7 October 14th, 2014 04:56 PM
WTB: Muzzy or Area P full system for Pregen quarterliter Items Wanted 0 January 20th, 2014 09:19 PM
WTB: Area P 18" Quiet Core Full Exhaust System Slono Items Wanted 0 January 1st, 2012 04:00 AM
Area P Group Buy WhiteRice Motorcycle-related 141 December 17th, 2011 10:28 AM
Group Buy: Area P Race System (Completed!) kkim Motorcycle-related 208 May 15th, 2011 07:55 PM
