April 29th, 2011, 06:53 PM | #1 |
Join Date: Mar 2011 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 121
Ballistic Performance Components 4-Cell Lithium Iron Phosphate Battery Upgrade
Hi Guys,
I just finished installing a Ballistic Performance Components 4-cell lithium iron battery in my 09 Ninja 250. It was a really simple swap that required nothing more than a few basic tools, some foam padding, and about 30 minutes. I snapped a few pictures along the way for reference, and I weighed both batteries accurately to get an idea of the actual weight savings from this modification. Overall, you'll save 6.5 lbs or 2985 grams which is a pretty significant amount all considered. I paid $109 CAD for the Ballistic battery from a local dealer. Original battery with plastic cover - 7.5 lbs (3410 grams) Ballistic 4-cell battery - 0.95lbs (426 grams) If your battery is getting a little old, then this really is a no-brainer. It's only about $20 more than the stock battery, weights 1/7th the amount, lasts longer and works just as well. The stock bolts and lugs fit without any modification, but you'll need to use something to hold the new tiny battery in place. I used adhesive back acoustic foam and just built up the battery box around the tiny 4 cell battery. Cheers, Owen |
August 22nd, 2011, 07:43 PM | #2 |
How has this been holding up?
August 22nd, 2011, 07:48 PM | #3 |
Great write-up.
August 22nd, 2011, 08:09 PM | #4 |
Hi Alex,
No mishaps to report so far. It's getting a little cooler here, and I was recently doing some work on the carbs that required frequent starts with minimal run time, and that little battery doesn't seem to mind one bit. I was going over my list of stock vs. aftermarket weights for all the parts I've replaced, and this battery is by far the best bang for the buck. I know most of the threads on here quickly digress into arguments when it comes to shaving weight, but I've dropped 35 lbs off my bike since I got it, and it has made a very notable improvement overall. Coming from a background in road bike (as in bicycle) racing, it's hard to imagine they built the 250R the way they did. It's almost as though every single part was made to be as heavy as possible. I found it comical that replacing just the gas tank cap dropped nearly a pound off the bike. That kind of weight savings on a road bike would cost you $1000. I've attached my list for fun, and I'll be sure to report back if I ever run into a problem with the battery. Are you considering an upgrade? Cheers, Owen |
August 22nd, 2011, 08:22 PM | #5 |
I likely won't upgrade until mine needs it, but I am interested in the new battery technology, It does seem like it's become very popular in just the past few months, and I wonder when such lightweight batteries will make it into OEM specs. Honda made a big deal when they shaved 1 pound off the battery in their new 1000RR for 2008, requiring a special starter motor to deal with the slightly lower capacity battery than before. These lithium batteries are fractions of the weight of the older-tech, and seem to have very little downsides.
August 22nd, 2011, 08:24 PM | #6 |
If I'm reading that list correctly, you removed the entire rear brake assembly?
August 22nd, 2011, 08:49 PM | #7 |
Hi Guys,
The digression begins... The rear brake was not removed to shave weight, it was removed because I almost killed myself with it... twice. I've had it off the entire year so far, and I can honestly say that it has been better without it. Say what you want about "training yourself to brake properly in panic situations" but for me, it was hard to resist the urge to mash that pedal when you really need to stop. On a road bike it's fine to lock the back wheel, but it's not fine on a motorcycle. I would not suggest it as a weight saving measure, and I would not suggest it for all riders, but if you're like me, and don't feel comfortable having it there, then I don't think it's all that bad to go without. Remember the 80/20 rule? Those guys weren't pulling on the front brake hard enough Cheers, Owen |
August 22nd, 2011, 10:21 PM | #8 |
I use the rear very rarely myself. But it sure did come in handy when I didn't realize my front pads were down to almost nothing and I was a few hours from home.
August 23rd, 2011, 05:07 AM | #9 |
Hi Alex,
That has been my one actual fear. Not that the pads will wear out, but that I might have some fluke mechanical failure on the front brake which would leave me with no brakes at all. I reasoned that under the circumstances I'd just have to downshift aggressively to shed some speed, and hopefully avoid whatever obstacle I was trying to brake for. Not having any braking redundancy is definitely a valid concern! Cheers, Owen |
August 23rd, 2011, 02:38 PM | #10 |
how hot does the Li-ion battery get with all that padding acting as insulaltion around it in the summer?
August 23rd, 2011, 03:40 PM | #11 |
this thread is awesome. this pdf just got printed out. and i don't print out many things so take that as a compliment.
good work... but damnit, now i have to buy two of these batteries...
August 23rd, 2011, 04:39 PM | #12 |
Hi Guys,
DaBlue1: The battery itself doesn't generate heat, so I don't think it's an issue. I know the Lithium Iron type batteries are a lot more tolerant to temperature extremes than their Li-Ion or Li-Po counterparts. Either way, it hasn't given me any problems, and I've never noticed any heat buildup. alex.s: Glad to hear that list can be of use! I've been meaning to post it up in its own thread, but never got around to it. I'm always updating it, so I'll post a new one every now and then. Next time I have all the fairings off, I plan to weigh those as well and add them to the list. If you were race prepping a Ninja, I figured it would help to know what parts need the most attention. Cheers, Owen |
August 23rd, 2011, 06:58 PM | #13 |
Join Date: Feb 2010 Motorcycle(s): 2008 Ninja 250R Posts: 36
Top post! Now to find one of these batteries in Australia...
EDIT: Search over! http://frps.com.au/store/index.php?m...index&cPath=24 Although I think I just bought their last 4-cell. Last futzed with by CoinSlot; August 24th, 2011 at 04:10 PM. |
August 25th, 2011, 07:19 PM | #14 |
Good Stuff! You won't regret it...
It's fun to hold the new and the old battery in each hand. It's almost hard to believe they both accomplish the same thing! Best of luck with the install! Cheers, Owen |
August 25th, 2011, 09:46 PM | #15 |
You are sleeping
I use to use lithium in my RC vehicles.
High power tiny stuff, that's for sure. This is an interesting thread. Something I would like. Get one and delete the whole battery box and mount it on that ledge on the undertail with a rubber strap like in the tail box. Or just put the battery in the tail maybe.
<Yeah, it's a 250. LMFAO! Weaksauce |
August 25th, 2011, 09:51 PM | #16 |
Sweet. Keep us posted on reliability. When I need to change mine out, I might just do that since it'll leave a little more space under the seat. Maybe a decent place to put extra tools or maybe a tire repair kit.
August 25th, 2011, 09:52 PM | #17 |
You are sleeping
Yeah this is a cool one.
I wonder if a bettery tender still works with this. I don't imagine so?
August 25th, 2011, 11:04 PM | #18 |
August 26th, 2011, 12:11 AM | #19 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
i want... but the friken PayPal transaction wont let me send the battery to a US address, because my PP is registered to me here in Indonesia! arghhhhhh.........
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
August 26th, 2011, 12:23 AM | #20 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
No rear brake? Wow, you must not do a lot od motocross and enduros with your bike.
Posted via Mobile Device |
August 26th, 2011, 12:46 AM | #21 |
yeah... i would never dream of taking the back brakes off, regardless if i use or don't use it, that's like a spare lifeline that i want to know i can rely on if the front brakes for some reason were to fail.
downshifting would not be as fast as the back brakes, and it could lead to dire conciquences. having said that, i could fully understand that you can get away with only using the front brakes, but it would be more a matter of reassurance for me to have still have the back ones there just in case. gravel and rain is not my best friend, but if i have to slow down on gravel, or a wet road, i always use a good dose of the back brakes, so that i can avoid loosing traction on the front wheel, and slip out.
August 26th, 2011, 03:38 AM | #22 | |
You are sleeping
August 26th, 2011, 04:48 AM | #23 | |
As setasai mentioned, the better thing to do would be to move the toolkit into the battery box and just tape a single allan key in the rear compartment. That would give you some easily accessible storage space that you could actually use. I got rid of my tool kit a long time ago, and I use the extra space to store my wallet, keys, phone, and anything else I have to carry. Cheers, Owen |
August 26th, 2011, 08:38 AM | #24 |
You are sleeping
Where did you guys get it though that's the important part lol.
There;s likely a million ways to mount that tiny thing on this bike. could customize it's own tiny battery box for it. On a stunt bike it's nice to be able to lose weight. What kind of charger do you use for this battery also? As far as I remember, I think you can use the undertail just fine without the battery box. I could be wrong though.
August 26th, 2011, 10:14 AM | #25 | |
Man, now i want one. |
October 17th, 2011, 12:31 PM | #26 |
Join Date: Oct 2011 Motorcycle(s): 2004 Moto Guzzi V11 LeMans, 2001 ZZR250 Posts: 38
Owen, where did you find the Ballistic batteries up here? While they are carried through Parts Unlimited and Parts Europe, Parts Canada doesn't and my local dealer can't seem to find a source.
I have a good AGM battery in the ZZR put in by the PO, however my Guzzi battery just died on a ride yesterday after the second restart in 10 minutes of riding. I'd like to find one locally given the riding weather is perfect and I need it now. Thanks. Steve |
October 17th, 2011, 01:27 PM | #27 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
Have you had any issues with your battery now that it's getting cooler? I've had an 8 cell Ballistic Performance battery in my Hawk 650, and it seems that now that it's cooler out it's not liking starting in the morning. I was able to start my bike this morning, but after riding it to work and getting ready to ride home for lunch it didn't start.
October 17th, 2011, 04:58 PM | #28 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
Hi there,
Did you get the 80 Amps or the 135 Amps version? The 80 Amps is $49.95 (ebay) but I'm assuming that's too low of a current for our bikes (scratching head)? |
October 17th, 2011, 10:57 PM | #29 | |
October 18th, 2011, 05:42 AM | #30 | |||
@dale-j:
@k-os: Quote:
How old is your battery now? You seem to have the correct general size for a 650, so I'm not sure what the problem would be. Do you have an alarm or anything that would have drained it? @EthioKnight: Quote:
Cheers, Owen |
October 18th, 2011, 06:22 AM | #31 | |
October 18th, 2011, 10:04 AM | #32 |
Thanks Owen. Was hoping to find a place locally near Vancouver but I have ordered from Motorcycle Superstore with good results in the past.
I also found that BikeBandit sells these at a small (10%) discount as does Solo Motor Parts. Solo ships USPS to Canada and international, which is slower but a big bonus as Canada Post, when they charge brokerage (not always) only charges $5.00 flat fee versus +\- $40 brokerage plus COD fees (for their brokerage charges) from UPS. The savings of using USPS/Canada Post is typically about $50.00 (!!) |
October 18th, 2011, 02:11 PM | #33 |
Join Date: Jun 2011 Motorcycle(s): Red 2009 Ninja 250r Posts: 132
+1 on motorcycle superstore. ive seen those batteries on there and ive ordered multiple things from there and never had a single issue. there the best online store ive ordered from i usually order on sunday or monday and get it by wednesday
"The goal in life is to die young at a very old age" " Four wheels moves the body, two wheels moves the soul' |
[RoadRUNNER] - Is That a Shorai Lithium Iron Battery in Your Pocket? | Ninjette Newsbot | Motorcycling News | 0 | October 2nd, 2013 01:00 PM |
[RoadRUNNER] - Shorai LFX Lithium-Iron Powersports Battery | Ninjette Newsbot | Motorcycling News | 0 | June 2nd, 2013 11:00 AM |
[sportrider - latest stories] - MOTY Design 8-Cell Lithium Ion Phosphate Battery | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2012 04:50 PM |
My New Battery - Ballistic Performance | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 60 | January 6th, 2012 12:23 PM |
