June 6th, 2011, 10:23 AM | #1 |
ModMy250.com
Heads up for anodized parts
Hey guys, I just read the thread on the 2wheels adjustable levers and wanted to comment on the fading bits. Anodizing is not a color treatment, contrary to what people believe. The side effect is the color, but anodizing creates a sacrificial top layer on aluminum to keep it from corroding. You may be thinking, "aluminum doesn't corrode." Generally, you'd be right, but it is susceptible to Galvanic Corrosion. What this means is when two metals of different compositions are in contact with each other and then subjected to an electrolyte like water, one of the metals will begin corroding. In this case, the bolts used to connect the folding levers are steel and the levers are aluminum.
One of the other things that the anodized layer is susceptible to is heat, and to a lesser extent UV. So it will also begin to color fade (layer break down) when in constant contact with either of these. I'm not saying there are better or worse anodizing jobs, but every anodized part, no matter how good the processor, will eventually fade if left in direct sunlight. I've seen black parts turn purple and as far as completely gone back to the brushed aluminum. I just wanted people to be aware that if they are buying parts for looks, I would suggest powder coating the part as an alternative. I wouldn't powder coat the joints since those are usually machined to have tight tolerances, but the exposed parts would be a good candidate. Powders are usually polyester based and certain single stage powders are premixed with the clear coat to achieve a glossy, UV resistant finish. The colors available will also be a closer match to body paint unless you have a metallic finish on your vehicle.
The www.ModMy250.com guy |
June 8th, 2011, 05:37 AM | #2 |
How would you recommend that I paint my triple tree and clip-ons the closest to the rest of the frame?
June 8th, 2011, 06:23 AM | #3 |
Minor correction: Aluminum corrode extremely easily and quickly, in seconds in fact. It's a "friendly" metal in that it has a strong affinity for oxygen. When aluminum corrodes the result is aluminum oxide. Al2O3 is very stable, essentially inert, and fairly hard, so when the surface of aluminum oxidizes it forms an oxide layer that does a good job of protecting the metal underneath. It is not a "sacrificial" surface.
Anodizing is a process that produces a thicker layer of aluminum oxide on the surface of the aluminum quickly, thicker and faster than what would occur naturally. Dyes can be added to give color effects. If the dyes are organic in nature they're more susceptible to fading under UV exposure. http://en.wikipedia.org/wiki/Aluminium_oxide http://en.wikipedia.org/wiki/Anodizing |
June 8th, 2011, 07:47 AM | #4 | ||
ModMy250.com
June 9th, 2011, 02:57 AM | #5 | |
June 9th, 2011, 08:09 AM | #6 |
ModMy250.com
The high temp paints that are enamels will work, it doesn't necessarily have to be exhaust paint.
June 9th, 2011, 10:17 AM | #7 |
Thanks. Will it require any special prep or can I just paint over what's there? I want to paint some other parts of the bike too, like my rusty mirror stalks, but I know that'll take prep (don't want rust under the paint)
June 9th, 2011, 10:56 AM | #8 |
ModMy250.com
Best thing to do will be to sand the parts. You want to rough up the surface a bit so the paint will stick to it better. If at all possible, find a shop that will sand blast it for you. If not, find some 1000 grit and go over the entire triple clamp. After you sand, wash it with soap and water, then let it dry. You can also use simple green or another mild degreaser. Then follow the directions on the can. The same would apply to the rusted parts. You want to remove any rust you can see since rust is like a cancer and will keep on spreading. You'll probably want to work with 400 grit for the rust, then follow with 800, then 1000 to get a nice finish before painting.
March 6th, 2012, 09:18 AM | #9 |
Ex ninjette!
Join Date: Nov 2011 Motorcycle(s): Suzuki GSXR 600 K4, Kawasaki ninja 250r 08 Posts: 294
Sorry to bring up another old thread, if i was to get the2wheel levers would it be possible to sand them down and then spray them white, a sort of glossy white?
Mods: Puig Double bubble windscreen, Targa Fender eliminator, Custom LED integrated Tail light, Exhaust Hanger, Two brothers titanium exhaust More on the way! |
March 6th, 2012, 10:51 AM | #10 |
ModMy250.com
You would want to get them sand blasted. Sanding by hand would be difficult because of all the grooves machined in. If you just want to color change with spray paint, just mask off the area of the switch and mounting block. Clean the lever with a degreaser and just paint over the anodized lever.
March 6th, 2012, 10:53 AM | #11 | |
Ex ninjette!
March 6th, 2012, 11:14 AM | #12 |
ModMy250.com
Use a high temp ceramic paint. Those have very durable coatings.
March 6th, 2012, 11:24 AM | #13 |
Ex ninjette!
Thanks for the advice i will get round to doing this when i get some new levers hopfully soon
[roadracingworld.com] - Parts Unlimited To Handle EBR OEM Parts Distribution In North | Ninjette Newsbot | Motorcycling News | 0 | July 16th, 2014 06:00 PM |
[roadracingworld.com] - Parts Canada Superbike Championship Heads To Race City This W | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2009 12:50 PM |
[roadracingworld.com] - Parts Canada Superbike Championship Heads To Race City This W | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2009 12:20 PM |
[roadracingworld.com] - Parts Canada Superbike Championship Heads To Circuit ICAR Thi | Ninjette Newsbot | Motorcycling News | 0 | June 10th, 2009 03:50 PM |
