Old July 17th, 2011, 10:37 PM   #1
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
DIY: Installing No-Cut Diode kit from modmy250.com
In anticipation of a new product I'm making, I wanted to post a DIY. It's a diode kit so if you install 4 or more LED blinkers, you retain stock function from all the lights as well as the turn signal indicator.
Tools you will need:
10mm socket & socket wrench
small flat screwdriver (about as small as one that you fix glasses or a watch with)
First thing you will need to do is remove the Left fairing. Please see this DIY on how to do it.
Once the fairing is off, you should easily see the 2 harnesses you will need to disconnect. They are almost right up against the front cowl. In the first pic, you can see where it should be as well as the two unplugged. You will be removing the solid green wire from the 9 pin harness.
Here's another picture of which connector you will be removing in case you're a little unsure still.
In this picture, you can see I've stuck in my pick to bend the tab. You can use a small flat head screw driver or pick if you have one. Just push it in with one hand while gently pulling on the wire with the other hand. It will come out really easily. Notice that the pick is pushing into the harness on the right side of the connector. That's where the tab is.
Image of the green wire pulled out. Notice how the tab is all bent inwards.
Bend the tab back out so that it sits at an angle. You need to do this for the next step.
Now, insert the green wire into the smaller 3pin harness you unplugged earlier. There's an empty middle spot that will fit it perfectly. You should hear it click in. If you didn't bend the tab, the green wire will just be loose and not stay in the harness.
Now, all you have to do is grab the Diode kit and plug everything in. It will use the same stock connectors to keep as much of the install as easy as possible, just like my other products .
Here, you'll see the new connector installed into where the green wire used to be.
Pic of the new kit installed with the ground wire attached. Don't worry about the unwrapped diodes. I left them that way on purpose. The final product will have everything wrapped in heat shrink. Note: If the kit doesn't seem to work, try using a wire brush or sand paper on the mounting point. It needs a good ground for it to function.
Final product:
The www.ModMy250.com guy
Last futzed with by CThunder-blue; July 29th, 2011 at 07:58 AM.
Old July 17th, 2011, 10:46 PM   #2
/linked from main DIY thread
Old July 17th, 2011, 11:04 PM   #3
Mr.E
That rider dude.
Mr.E's Avatar
Motorcycle(s): 2011 White Ninja 250 SE.
I've been hearing about the diode mod just recently, any chance u can explain to me what it is? This diy seems pretty easy, thanks. X-)
Mr.E is offline   Reply With Quote
Old July 18th, 2011, 07:59 AM   #4
CThunder-blue
ModMy250.com
Hi Eric. The diode mod is for people who go remove their factory blinkers and install LED's for all 4 blinkers. Usually, if you only install 2, ie, just replacing the front blinkers with LED's, you don't need to install any diodes. When you replace all the blinkers, many people do integrated rear lights and front LED's, there seems to be a power bleed. The new LED's only take a fraction to work, so the left over power gets sent to the other set of blinkers. This causes the bike to flash all 4 blinkers at the same time, like hazard lights. The diodes prevent this power backwash so that the blinkers behave the way they're designed.
Here's another DIY that shows you how to do it, but you have to cut wires, solder connections and add a ring terminal. You also have to remove both front fairings and the front cowl to get access to the gauge's rear. With my kit, you just remove the left fairing and you're finished in under 15 minutes total.
Old July 18th, 2011, 08:12 AM   #5
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
Tri - nice, any chance you gonna have a GB for P&P LED rear turn signals too?! I'd be interested in this and P&P LED rear turn signals.
gt_turbo is offline   Reply With Quote
Old July 18th, 2011, 09:25 AM   #6
CThunder-blue
ModMy250.com
I haven't given much thought to rear LED turn signals. Most people opt for integrated rear lights. Are there any you would like to see turned into a kit?
Old July 18th, 2011, 09:34 AM   #7
gt_turbo
gt_turbo's Avatar
how about these LED's
i like integrated tails, but i don't think they are the most visible at times. and i would still keep the signals on to make it appear more in compliance with being street legal in case pig was to ride behind me.
Old July 18th, 2011, 09:50 AM   #8
CThunder-blue
ModMy250.com
Those would be ok, but they don't seem all that bright. Can I suggest either of these?
http://cgi.ebay.com/Motorcycle-14x-L...item4149edeec4
or
http://cgi.ebay.com/Motorcycle-18x-L...item4149dd8ee3
Old July 18th, 2011, 10:11 AM   #9
gt_turbo
gt_turbo's Avatar
or
i like the top one. botoom ones shape is a little wierd for me.
Old July 18th, 2011, 10:15 AM   #10
jezebel
ooh, excited to see your site when it's up! Let me know, and i'll link to you on mine
www.ridingjezebel.com - my resource site for new, short and female riders!
my mods
jezebel is offline   Reply With Quote
Old July 18th, 2011, 10:31 AM   #11
CThunder-blue
ModMy250.com
Thanks! I'll let you know
Old September 15th, 2011, 08:34 PM   #12
YORCHI
n00b
YORCHI's Avatar
Motorcycle(s): Blue 2010 Ninja 250
I'm super brain dead right now so I can't seem to figure this out...
but just to make triple sure before I take my bike apart...the actual diode is already in the kit you sell right? I don't have to buy a diode and add it to the kit you make?
I got my order today and when I was looking over everything I started thinking, "Wasn't there a diode I needed?"
Facebook YouTube
#KCCO
YORCHI is offline   Reply With Quote
Old September 15th, 2011, 10:52 PM   #13
Momaru
Momaru's Avatar
Yeah, it is. It's under the black shrink-wrap in the last pic of the OP.
If you look at the small black/grey cylinder connected to the blue wire in the next-to-last pic int he OP, that's one of the two diodes in the kit. The other is under the black electrical tape next to it.
They're very small, about the diameter of the wire Tri seems to have used, so they're easily overlooked.
Proud member of the Blue Army
Old September 16th, 2011, 05:12 AM   #14
YORCHI
n00b
YORCHI's Avatar
Yup I get it now. I wanted to install them this weekend but I'm gonna be out of town until Monday
Facebook YouTube
#KCCO
Old September 26th, 2011, 06:09 PM   #15
Highalltheway
Highalltheway's Avatar
Motorcycle(s): 2011 ninja 250 special edition
Great product. My LEDs are flashing ok now.
World champs
Highalltheway is offline   Reply With Quote
Old September 26th, 2011, 07:22 PM   #16
CThunder-blue
ModMy250.com
Old September 28th, 2011, 05:57 AM   #17
smiley424
Guest
Posts: n/a
simple, straight forward, and easy install, thanks Tri!
Old September 28th, 2011, 08:52 AM   #18
CThunder-blue
ModMy250.com
You're welcome Phil
Old September 28th, 2011, 05:16 PM   #19
ninjagaiden09
ninjagaiden09's Avatar
Motorcycle(s): 2011 Ninja 250r
Tri, just want to say thank you for the flush mount turn signal and the no- cut diode. And with your DIY made the installation easy. works great.
ninjagaiden09 is offline   Reply With Quote
Old September 29th, 2011, 04:04 AM   #20
CThunder-blue
ModMy250.com
Awesome Gai! I'm glad you like them
Old October 5th, 2011, 04:17 PM   #21
slim08xxx
Motorcycle(s): Ninja 250R
I have a weird problem. I installed this kit and I have 2 regular signals in the front and the 2 rear signals are leds mounted to license plate.
1. If I switch the turn signal switch to right then front right signal turns on and stays solid not blinking and the rear right doesn't even turn on.
2. If I switch the signal switch to the left then left rear signal turns on and stays solid. the front left is off.
3. if I turn the switch to the right then on the dash nothing light up while if I switch to the left then the dash indicator light turns on and stays on not flashing.
What are the fixes?
thanks.
P.S.- Just got the Tridon flasher mentioned in other posts and plugged it in. with the new flasher and diode kit all the lights stopped working. with diode kit disconnected if I switch to the right then right front and left rear blink normally. If I switch to the left nothing turns on.
Last futzed with by slim08xxx; October 5th, 2011 at 05:49 PM. Reason: missed something
slim08xxx is offline   Reply With Quote
Old October 6th, 2011, 07:24 AM   #22
CThunder-blue
ModMy250.com
What model is your relay?
Old December 8th, 2011, 11:16 AM   #23
gadgetguy1288
Coastie Tweet
gadgetguy1288's Avatar
Motorcycle(s): 2011 250R Ebony, 2012 BMW F800R White
The green wire that I removed from the factory harness wont fully seat in your connector(almost like its too big), and I don't see any wires in the other side so I didn't worry about it as long as its not falling out(its wedged in there pretty good, and its not gonna fall out on its own at least. Am I missing the wire on the other side of that connector or did you you just stick the green wife in there to keep it out of the way? Also, IDK if its a change on the '11's or what but my green wire is actually two green wires both connected to the same connector.
Randy
USCG
Air Station Elizabeth City
gadgetguy1288 is offline   Reply With Quote
Old December 9th, 2011, 12:25 AM   #24
Mr.E
That rider dude.
Mr.E's Avatar
Do you mean the spot where you insert the wire is a little too big? If so, this is normal. Mine was a bit larger too, but it stays in and works perfectly. Just make sure to prop that tab up like he states to do.
As for the two in one wire, Im not too sure, but I think my wire was slightly different looking too. As long as you test your blinkers before putting back on the fairings, and they work, you will be fine.
Mods: flushmount Led front binkers, diode mod, pazzo levers, clear tank pad, racing replica grips, bike monkeys integrated tal light, zx-2r vinyls, rearsets, red bar ends, and more red accented stuff.
Old December 9th, 2011, 01:09 AM   #25
gadgetguy1288
Coastie Tweet
No the other way around, the hole in the plug is too small for the wire/s. The gold plated connector is too big to fit in the harness. Like I said its wedged in there as far as I could get it and doesnt appear to be coming out, and everything is working fine, I just wanted to verify that i was just being put there to keep it out of the way as there is nothing on the other plug to connect to at that spot in the harness.
Randy
USCG
Old December 9th, 2011, 09:58 AM   #26
gadgetguy1288
Coastie Tweet
Nvm, I figured out what I was doing wrong. lol I need to read the directions better when I do this stuff. haha
Randy
USCG
Old January 28th, 2012, 01:27 PM   #27
The Blue Rider
The Blue Rider's Avatar
Motorcycle(s): '09 Ninja 250R
I just wanted to say, I put in this mod last week and it was easy as pie; I have a CF12ANL-01 flasher from SuperbrightLEDs.com, and Rizoma Zero 11's on all four corners... No issues. Installation took only a couple of minutes. Beats the pants off of soldering!
The Blue Rider is offline   Reply With Quote
Old January 29th, 2012, 02:19 PM   #28
CThunder-blue
ModMy250.com
Thanks Terry
Old January 30th, 2012, 04:43 AM   #29
jack_bm
Ex ninjette!
jack_bm's Avatar
Motorcycle(s): Suzuki GSXR 600 K4, Kawasaki ninja 250r 08
Nice DIY Will you be doing one of these for the relay? or are you going to do it when you do the DIY for the tail lights?
jack_bm is offline   Reply With Quote
Old January 30th, 2012, 08:44 AM   #30
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
The relay is literally, unplug the old one, and plug in the new one; then zip tie or glue the new one in place.
saxnbass is offline   Reply With Quote
Old January 30th, 2012, 11:36 AM   #31
jack_bm
Ex ninjette!
jack_bm's Avatar
No idea what a relay looks like though or even where it is, thats the problem lol
Old January 30th, 2012, 11:47 AM   #32
CThunder-blue
ModMy250.com
Already done . http://www.ninjette.org/forums/showthread.php?t=76116 scroll to the bottom of te first post.
Old January 30th, 2012, 11:51 AM   #33
jack_bm
Ex ninjette!
jack_bm's Avatar
Ohhh thats cool, feel stupid now that is REALLY simple haha i work best with pictures i find so all these DIY's are good for me cant wait to get the tail light now How are we going about paying and eveything, I PM'd about it
Old January 30th, 2012, 12:16 PM   #34
CThunder-blue
ModMy250.com
Please read theGB thread for info. I'm asking people to pm me their email so I can send invoices out.
Old February 23rd, 2012, 04:30 PM   #35
Redsvt
DIode install done...but
After removing the connectors I come to find out that I have 2 green wires plug into the #9 connector, not one as the photo indicates. Now I connected everything and all works well, front and rear, horn works, dash lights all come on and the bike starts.
Quick question, does the headlight come on when you turn the key or does the engine need to be started before the head light comes on. With engine running low and high beam work , but the two green wires in the #9 hole bother me. Bike is a 2012.
Redsvt is offline   Reply With Quote
Old February 23rd, 2012, 05:42 PM   #36
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
I just did my diode kit last week on my 2011, it also had 2 green wires in that spot. Tri said he's seen this before, I've had no problems with mine either.
Also, my headlight doesn't come on until the engine is running.
kevheads is offline   Reply With Quote
Old February 24th, 2012, 11:09 PM   #37
2012NewRider
Motorcycle(s): 2012 Kawasaki Ninja 250R
it happens on my 2012 as well. I think its just how our bikes are made now.
2012NewRider is offline   Reply With Quote
Old March 2nd, 2012, 12:56 AM   #38
USAFmills90
Modify to Survive
USAFmills90's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R
just intalled the diode kit. works perfectly and it was a snap to install. took about 15 minutes to install (fender removal included)
The more modified it is, the more it is your own creation..
USAFmills90 is offline   Reply With Quote
Old March 23rd, 2012, 04:04 PM   #39
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
so im having a problem. I no longer see the blinker indicator light on the dash lighting up. Is this because I dont have a proper ground?
*edit nvm yeah its the ground.
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old April 2nd, 2012, 02:51 PM   #40
Pudge Ate Me
2012 Ninja 250R Green
Pudge Ate Me's Avatar
Motorcycle(s): 2012 Ninja 250R Green
Quick question here,
I am about to install the proton flush mount turn signals. I understand that you do not need to change any wiring for one set of LED's but I am thinking of future intergrated tail light. If I purchase this kit, this will be the only diode thing I will have to do if I get an intergrated tail light and led turn lights correct?
Pudge Ate Me is offline   Reply With Quote
DIY - Installing a ZX-6R Master Cylinder VeX 2008 - 2012 Ninja 250R Tech Talk 33 August 27th, 2018 11:30 AM
DIY: Installing the Ecotrons EFI Kit on a Pregen n4mwd Videos 174 May 10th, 2013 08:48 AM
No-cut Diode kit CThunder-blue Motorcycle-related 16 July 24th, 2012 09:37 PM
DIY- Installing Footpeg Extenders kkim 2008 - 2012 Ninja 250R Tech Talk 78 November 20th, 2010 09:58 PM
DIY: Installing Halos tlhamon 2008 - 2012 Ninja 250R Tech Talk 26 October 27th, 2010 08:40 PM
