July 28th, 2011, 07:50 AM | #1 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
13t front sprocket
anyone know if the front sprockets are interchangeable from the pregen to the new gen? i cant find a 13t front sprocket anywhere for the newgen, only the pregen, even the dealer doesnt show a listing. only one i can seem to find http://www.amazon.com/JT-Sprockets-F.../dp/B00316Y402
#1 |
July 28th, 2011, 08:53 AM | #2 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
As far as I know yes, with a shim.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
July 28th, 2011, 09:00 AM | #3 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
I thought I read somewhere that the 13t sprocket can cause excessive chain wear due to the diameter of the sprocket being so tight. Hopefully they were wrong and you'll be fine switching.
July 28th, 2011, 10:03 AM | #4 |
Ridin Dirty
i read a post on a different forum through google searching from kkim saying he was gonna try a 13t.. the post looked like it was from 2008 so maybe he can chime in.. im gonna order it since its only $15 shipped.. ill post back with the results once on.
#1 |
July 29th, 2011, 04:09 AM | #5 |
Ninjette wanabe :D
Join Date: Apr 2011 Motorcycle(s): white 300 :D Posts: A lot.
Should be great if you ride city only id think.
VROOOM vrooom >.> |
July 29th, 2011, 06:11 AM | #6 |
Ridin Dirty
i do about 0 miles in the city
#1 |
July 29th, 2011, 11:08 AM | #7 |
Why you want to go down in size, when everyone always seems to want to go up in size?? (just curious, if ya will)
PS- off topic, but meaning to ask since seeing a pic of your windscreen mod... where the hell are your front turn sig's? |
July 29th, 2011, 11:09 AM | #8 |
Wait, we still talking about sprockets?
July 29th, 2011, 11:15 AM | #9 |
Ridin Dirty
I'm larger then the average 250 rider so I need to go down not up .. and front turns are some flushmounts I got at cycle gear .
#1 |
August 2nd, 2011, 05:08 PM | #10 |
Ridin Dirty
ok, so i got the 13t sprocket today.. ordered it from amazon the link is in my first post, now the sprocket i recieved has the correct part# stamped on the sprocket, but the sprocket itself is completely different then what i need or even pictured in the link from when i purchased, i emailed the company and havent herd back yet.. im confused now if i got a wrong sprocket or the 2007 and older ninjas arent the same front??
VV... this is what is showed and what the center should look like to fit..
#1 |
August 2nd, 2011, 09:12 PM | #11 |
One shim should do you fine. I have the same counter sprocket, only with 15T. Yes, it is the one for the pre-gens, but that is why the shim. I have run mine for about 2 years that way with no problem. Your RPMs are going to run HIGH on the freeway, but if that work for you, that is all that is important.
August 2nd, 2011, 09:16 PM | #12 |
Ridin Dirty
I gotta get them to send me the right sprocket first .. what are you using for a shim?
#1 |
August 2nd, 2011, 09:20 PM | #13 |
Part# 92200A at bikebandit.com (or other retailers). You will find this part under the transmission section of the parts fiche.
This is a splined washer that is used inside your transmission, but is also the perfect shim (also what I use).
August 2nd, 2011, 09:26 PM | #14 |
Ridin Dirty
Cool thanks
#1 |
August 3rd, 2011, 09:35 AM | #15 |
Ridin Dirty
well found out why the 13t i got wouldnt fit, ended up being for a honda! amazon.com has wrong info.. the correct part# for the pre gen front 13t sprocket from jt sprockets is JTF516-13.. for future reference.
#1 |
NEW PitBull 13T Front Sprocket for 250r / Ninja 300 | 1ER6F | Motorcycle-related | 6 | July 11th, 2014 11:16 PM |
Set Me Straight on 13T Front Sprockets | Outlander Systems | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 8th, 2011 08:04 PM |
Front Sprocket | Archerzz | 1986 - 2007 Ninja 250R Tech Talk | 66 | June 29th, 2011 10:22 AM |
13t Sprocket. | indr | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 16th, 2011 03:25 PM |
Anyone find a 13T countershaft sprocket? | RaceBikeRentals | General Motorcycling Discussion | 3 | January 27th, 2010 09:14 PM |
