August 4th, 2011, 11:34 PM | #1 |
Fumoto Valve
Has anyone used a Fumoto valve on their 250? It replaces your oil drain plug and eliminates the need for crush washers. Helps if you ever overfill you oil and makes changing oil more convenient.
Our drain plug size is 17mm but is that also the thread size? |
August 4th, 2011, 11:43 PM | #2 |
i don't have this particular one but i have another generic quick valve... it's got a screw on cap below the quick valve with a rubber seal on it just in case the quick valve leaks... it makes it really easy to change the oil though i wish there was an easier way to get the oil filter cover off...
August 4th, 2011, 11:52 PM | #3 |
What size thread did you get?
August 4th, 2011, 11:59 PM | #5 |
Hmmm, sounds like 12mm x 1.5 which makes sense. 675 uses 14mm x 1.5.
August 5th, 2011, 12:00 AM | #6 |
from the other bolts they list it looks like the 15 is the depth? looks like 12mm though yeah
August 5th, 2011, 05:12 AM | #7 |
There is an easier way to change the filters but it's expensive...
August 5th, 2011, 06:17 AM | #9 |
Nope... But you can start using regular automotive type filters...
Check out this link: http://www.murphskits.com/catalog/pr...roducts_id=145
August 5th, 2011, 08:35 AM | #10 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150 Posts: 223
The size is 12mm-1.5. The Fumoto part # is F-109.
I have installed both the Fumoto valve and the Bergnmen spin on oil filter adapter on my 2008. Extremely high quality products that make changing the oil and filter a breeze. Have used both for about two years and absolutely no problems. Highly recommended. It should be noted that you will need to install the Fumoto valve in the "old gen" drain plug location since it will hit the housing of the new gen location. Luckily Kawasaki left the old oil drain bolt next to the oil filter even though they added the new one. Pictures from company ads. Fumoto.jpg 13-install short oil filter.jpg Bergmen adapter.jpg |
August 5th, 2011, 08:37 AM | #11 | |
August 5th, 2011, 08:37 AM | #12 |
Sweet, thanks for confirming. No adaptor needed for the 250?
August 5th, 2011, 09:22 AM | #13 |
Not sure what you mean by adaptor since the Bergmen is an adaptor that allows you to use the standard auto/motorcycle spin-on oil filters on our bikes. So much easier than the drop-in filter assembly that comes stock
As for the Fumoto valve, get the F-109 and install it in the old oil drain hole as I mentioned before. If you mean the extension for the Fumoto valve, you won't need the extension adapter, although I used one. The reason I have the extension is originally I tried to install it in the new gen location and kept hitting the housing trying to screw it in. Thought the extension would allow me to get it in, but it still hit. I put it in the old location without removing the extension because I forgot about it. Can be done either way. If I get some time after this weekend, I'll try to post up some photos of both products on my bike. Actually I might start a whole new thread if that's OK since the title of this one may not be understood by the majority of readers. Last futzed with by Ichiro; August 5th, 2011 at 02:56 PM. |
August 5th, 2011, 09:24 AM | #14 |
Yea, I meant the extension for the Fumoto. Thread it up! It'll definitely help people out. I wish I knew this existed about 6 oil changes ago.
August 5th, 2011, 09:27 AM | #15 | |
August 5th, 2011, 09:30 AM | #16 |
August 5th, 2011, 09:32 AM | #17 | |
August 30th, 2012, 05:47 AM | #18 |
August 30th, 2012, 12:01 PM | #20 |
I just figured there has been thousands of new members that has joined that may be interested in these 2 products.
August 30th, 2012, 04:50 PM | #22 |
ModMy250.com
The adapter is pretty nice, but not really cost effective. If you use good automotive oil filters like a Mobile 1 or K&N, you're looking at $10+ per filter. K&N stock replacement filters is under $5. Never mind the $120+ for the adapter. Each oil filter change will cost you twice what one would have cost. I'm all for convenience, but cost efficiency is important too.
Here's an alternative drain valve that's popular with the R6 guys. http://aggracing.com/store/index.php...&product_id=75
The www.ModMy250.com guy |
August 30th, 2012, 04:54 PM | #23 | |
August 30th, 2012, 05:15 PM | #24 |
ModMy250.com
Have a link?
August 30th, 2012, 05:18 PM | #25 |
sorry, picked it up at a local hardware store in generic packaging. didnt even have a company name on it but it still works well.
August 30th, 2012, 05:24 PM | #26 |
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja 250 Posts: 1
Love the drain valve idea, might have to get one of those.
August 30th, 2012, 05:27 PM | #27 |
ModMy250.com
Stop flaunting cheap reliable parts if you can't tell us where to get them.
September 4th, 2012, 06:33 AM | #28 |
300 air switching valve and purge valve (CAL) removal | joyspring | 2013 - 2017 Ninja 300 Tech Talk | 21 | February 13th, 2017 01:36 PM |
Valve adjustment | ninjaryda | 1986 - 2007 Ninja 250R Tech Talk | 6 | April 6th, 2013 06:02 PM |
Dropped bike off for valve adj. v. New valve stems? | edxmon | 2008 - 2012 Ninja 250R Tech Talk | 14 | July 17th, 2012 04:55 PM |
valve problem | dirtyrottenninja | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 23rd, 2011 02:17 PM |
valve issues | chevykrazy | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 7th, 2010 06:45 AM |
