August 24th, 2011, 05:05 PM | #1 |
$7 Tank grips kinda DIY
I have had this on my bike for a while now, Tri calls it the rash but I've since redone it because it was coming off and this time decided to smooth it out a bit.
Basically, I wanted stomp grips/tank grips so that it made it easier to grip the tank and not slide forward during hard braking or quick maneuvers but I am not willing to spend that much. So I used silicone caulking that you can find at any hardware store. The trick is to use the 100% silicone version, not the blends with latex or any additive. I did not take pictures during the process hence the "kinda DIY" but it's pretty simple. Clean the surface thoroughly of grease and dust. Then just get silicone in the color you want, usually white, clear, or black are the general offerings and slather it onto the surface. I used a paintbrush to smooth it out and coat it. You want the edges to be thin so that it wont rub off as easily. Let it set for 3-5 hours and you're good to go. Thick coats will require more time to set. Do NOT try to recoat it while it's still wet. It will look like crap and get smeared all over. Wear gloves and work in a clean area because silicone doesnt get washed off with soap and water. If you mess up, wait till it's set and just peel it off. Great thing about this is that it comes off completely clean. Fyi, 1 tube covers 4 panels completely with a little bit to spare so if you have a buddy that wants to try it, you can split the cost and it'll only be $3.50 per bike. Hope this helps others as much as it has helped me. Works like a charm. Doesnt fade and stays grippy. P.S. Depending on how it's applied, textures are different. |
August 24th, 2011, 05:49 PM | #2 |
good idea... i wonder how well it would work if you put down a strip of clear vinyl first then layed the silicone on top so that it cleanly removes... or can you just pull the silicone off?
August 24th, 2011, 05:52 PM | #3 | |
August 24th, 2011, 07:17 PM | #5 |
Sexy Beast
Join Date: Mar 2011 Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster Posts: A lot.
why don't you guys just go to any local skate shop and pick up some grip tape?
August 24th, 2011, 07:37 PM | #6 |
August 25th, 2011, 08:33 AM | #7 |
Sexy Beast
August 25th, 2011, 09:06 AM | #8 |
ModMy250.com
So, if you park too close to another bike, will the rash spread?
The www.ModMy250.com guy |
August 25th, 2011, 09:51 AM | #9 |
August 25th, 2011, 10:04 AM | #10 |
ModMy250.com
So you gave your bike crabs. hahaha
August 25th, 2011, 10:31 AM | #11 |
Join Date: Jul 2011 Motorcycle(s): 2008 Ninja 250r Posts: 784
August 25th, 2011, 01:02 PM | #12 | |
Join Date: Apr 2011 Motorcycle(s): 2009 V-Strom 650 ABS Posts: 166
Real men use this stuff though: No slipping around after that. You do have to take your pants off to get off the bike though, so I don't recommend it for around town riding. Last futzed with by NathanF; August 25th, 2011 at 02:32 PM. |
August 25th, 2011, 02:29 PM | #13 |
You can use overpants that zip up the sides of the legs. Kinda like chaps.
August 25th, 2011, 04:02 PM | #14 |
Jigglin' your Jiglets
MOTM - Apr '13
If you don't want it too look like a rash, then you can write in it and make it look even worse!!!
I'm going to redo mine with black and white silicon and put some cool design in it. I <3 the cheap stuff.
DIY: Super-Secure Gas Tank Holder (for when your tank is removed) | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 21 | June 16th, 2014 01:20 AM |
DIY - Hot Grips Heated Grips Install | NathanF | 2008 - 2012 Ninja 250R Farkles | 26 | January 23rd, 2014 03:37 PM |
Tank Grips ... Have You Added Them | Kokosun | Riding Skills | 4 | October 7th, 2012 05:31 AM |
Review: TechSpec C3 tank grips | CThunder-blue | 2008 - 2012 Ninja 250R Farkles | 13 | February 9th, 2012 10:28 AM |
DIY Tank Grips | setasai | 2008 - 2012 Ninja 250R Farkles | 1 | October 25th, 2010 05:31 AM |
