September 15th, 2011, 04:00 PM | #1 |
CVMA/AFM #72
Join Date: Oct 2009 Motorcycle(s): 2009 Ninja 250r (Racebike), 2015 FZ-07(Tourer), 2001 KX65(LOL bike) Posts: A lot.
DIY- Removing Fork Caps/Pistons and Springs
Well, I've managed to do a lot of the DIYs on this site, and due to a combination of being an awkward, bumbling n00b and -despite constant gym efforts- just generally being a wimp, a lot of the "just do this!" things have managed to be a little bit more of an ordeal for me.
So in an effort to help others who might run in to some of the same road blocks, I thought it might be useful to share my now favorite reach *ahem-WORK around I don't know how many of you guys have dealt with your forks at all, and I'm sure most people would laugh at me for this, but the amount of pressure and level of careful prying required to remove the pistons/ fork caps to work on the internals has been disgustingly difficult for me, especially since I can very rarely employ an extra pair of hands. I acknowledge that this isn't the first time anyone's ever thought to use this method, but I suffered a lot of frustration before stumbling upon this, so I thought I'd help make the information more widely available. All that said, let's do this. First and foremost, you'll need to have your front end dangling freely so there's no pressure on the front suspension. I have a pitbull triple tree stand that works swimmingly, but the creative among you can figure something out if you're not so well equipped. Also, I have clip ons so I don't have to remove anything to access the pistons, but there are other DIYs that show how to remove the handlebars if need be. ANYWAYS, I went to harbor freight and found this little number: $17 later, I have a three pack of nifty, different sized claw things- more technically known as gear pullers (For the record, I'm doing this with slingshot preload adjusters, but I'm sure this would work with the stock pistons. Also, you may want to put a piece of cloth or something between the gear puller and the metal if you're anal retentive about potential scratches). So just clamp that around the triple, and crank it down until it's pushed in the piston just enough to access the little C ring. And now you're free to comfortably and leisurely finagle with that little ring with some small flathead screwdrivers to your heart's content: Yay! Didn't even break a sweat <3 Now slowly crank it off, supporting the piston with your hand so it doesn't jump out, and you can now access your springs and spacers. The spacers you can grab no problem, but the fork and washer are a bit too deep for my big girly hands. So, while I'm mentioning ease of life tools, I'm a big fan of those magnetic, claw gripper things for pretty much everything: (Also from harbor freight. It's possible that I single handedly sustain that store -_-) And now we can try out some newer new suspension for the track next week (stock on the left, new .70 springs from Traxxion Dynamics on the right): Now just use the same method of putting them back on and you're good to go: It's nice when something that has consistently taken me an hour of struggling is now doable in <10minutes Oh, and a somewhat related side note, I had changed the fork oil about two months ago, and filled it a bit higher than listed in the manual, so I wasn't TERRIBLY worried about the oil I was going to be losing to the old springs. You may want to remove the entire forks and do a full oil change for a precise measurement though. |
September 15th, 2011, 04:12 PM | #2 |
Wow, looks like some kind of torture device
I've done my fork seals and also the preload adjusters as well. After both occasions, I'd have these weird bruises around my chest that I had no clue where they came from. Sounds kinky and all, but finally realized it was from using my body as leverage as I leaned on a screwdriver to push down the fork cap Can you track-ready my bike for me please |
September 15th, 2011, 04:21 PM | #3 | |
CVMA/AFM #72
That was my first thought when I first clamped it on, too. Can you say "multipurpose tool"
September 15th, 2011, 09:03 PM | #4 |
Nice!
/linked from main DIY sticky
September 16th, 2011, 04:04 AM | #5 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
Excellent DIY!
September 16th, 2011, 05:19 AM | #6 |
Well done!
September 16th, 2011, 07:59 AM | #7 |
ModMy250.com
Nice DIY! I remember having a bit of difficulty removing the C-ring as well until I remembered I had to drain the fork oil first. Once you drain the fork oil, it compresses with almost no effort. Your method would be great for anyone who didn't want to change oil though
The www.ModMy250.com guy |
September 16th, 2011, 08:50 AM | #8 | |
CVMA/AFM #72
September 16th, 2011, 08:58 AM | #9 |
ModMy250.com
Haha. Yeah, the one DIY on replacing oil doesn't mention it and I think even the manual says the first thing to do is to remove the C-clip while it's on the bike. I just find it easier to drain the oil before trying to remove the clip. The first time, I tried it the way the manual says, and like you, couldn't get it to budge without a hammer and screw driver.
I should also mention that you wouldn't want to drain the oil first without pulling the fork or measuring pretty carefully how much you drain out. I pulled my forks before disassembling them. Doing it on a bike, your method would be better because you don't need to worry about oil levels.
September 16th, 2011, 05:58 PM | #10 |
IC2(SW)
Nice thinking on use of the gear puller
September 17th, 2011, 05:50 AM | #11 |
You are sleeping
Coo.
Never went into the forks yet. Probably should eventually! I think mines are bent tho maybe need new ones first How are those preload adjusters working out now that everyone has had a chance to use them for a while?
<Yeah, it's a 250. LMFAO! Weaksauce |
September 17th, 2011, 07:27 AM | #12 | ||
CVMA/AFM #72
September 17th, 2011, 07:58 AM | #13 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
you can drain the oil without removing the forks?
I've been thinking about putting some heavier oil in mine to see if it keeps the front end from diving under hard braking. |
September 19th, 2011, 08:00 AM | #14 |
ModMy250.com
You can drain some oil, but not all of it. It's why you shouldn't do an oil change without removing them.
September 20th, 2011, 01:09 PM | #15 |
Join Date: Nov 2009 Motorcycle(s): 300, WeeStrom Posts: A lot.
Hmmm...that gear puller looks a lot like my faucet handle puller. Real nice DIY
October 7th, 2011, 12:23 AM | #16 |
I'm meeting someone today to get a triple tree/head stand but now I wonder if I should have just tried this to refill the leaked oil and then use some of that fork seal repair stuff to see if it worked.
DIY- Replace fork seals, dust seals and fork oil | shortstuff | 2008 - 2012 Ninja 250R Tech Talk | 212 | November 6th, 2023 10:53 AM |
FS: Pregen : Fork Springs, Fork Clamp, Factory Pro Jet kit | FvnnyL3tt3r1ng | Motorcycle-related | 20 | February 24th, 2016 08:24 AM |
DIY- Removing the Snorkel | kkim | 2008 - 2012 Ninja 250R Tech Talk | 159 | January 15th, 2015 11:39 PM |
sonic fork springs | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 6 | January 8th, 2015 08:22 AM |
Can fork springs be changed without removing the fork tubes? | AlanDog | 1986 - 2007 Ninja 250R Tech Talk | 26 | April 23rd, 2014 05:19 AM |
