Old November 11th, 2008, 10:18 PM   #1
08 Stock Jetting Specs
Make, Type- Keihin, CVK30
Main Jet- #98
Optional mains- #92,95,100,102
Main Air Jet- #100
Jet Needle- left-N9VU right-N9VW
Needle Jet- #6
Pilot Jet- #38
Pilot Air Jet- #100
Starter Jet- #48
Pilot Screws (turns out)- left- (2 1/2) right- (1 3/4)
Throttle Valve- 11degrees 00seconds
Idle Speed- 1300 +/- 50 rpm
Carb Sync Vacuum- less than 2.7 kPa (2 cmHg) difference between two carburetors.
Service Fuel Level- 0.5 +/-1mm (0.02 +/-0.04 in.) above the mating surface of the carburetor float bowl.
Float Height- 17 +/-2mm (0.67 +/-0.08 in.)
Old November 30th, 2008, 02:09 PM   #2
g21-30
g21-30's Avatar
Read this before you modify your carbs
This link possibly will answer all of your questions dealing with the Keihin CVK30 carburetor. Even though the link talks about the CVK40, everything applies to the CVK30. The CVK30 is a 30 mm while the CVK40 is a 40 mm. The "K" just means Kawasaki!! The choke on the Ninja 250R simply opens (enlarges) the starter jet in the carburetor! Check out the diagrams in the attached link.
Enjoy!
http://www.gadgetjq.com/keihin_carb.htm
Old December 3rd, 2008, 11:13 AM   #3
ak_907_ak
Motorcycle(s): 08 Ninja 250R
Should we start a jetting database?
ak_907_ak is offline   Reply With Quote
Old December 3rd, 2008, 11:16 AM   #4
I'll see if I can dig one up and start another thread.
Welcome, Nico.
FS: 08+ Yosh CF Slipon, Stock Headers, Stock Brake Lines, Stock Rearsets Dmitriy Motorcycle-related 16 August 24th, 2011 11:03 AM
Stock tire, airbox, passenger pegs, stock right rearset, cowl shroud ninja250 Motorcycle-related 6 August 17th, 2011 10:33 AM
[superbikeplanet.com] - Back in Stock & Shipping (Ago Prints: Very Few In Stock) Ninjette Newsbot Motorcycling News 0 July 23rd, 2011 10:10 AM
WANTED: 2008+ Stock rear links and stock handlebar bolts WesleyMarz Items Wanted 2 July 14th, 2011 06:36 PM
Dyno Charts with jetting and stock exhaust? KURT 2008 - 2012 Ninja 250R Tech Talk 5 February 27th, 2011 10:03 AM
