February 11th, 2012, 11:37 PM | #1 |
DIY Yamaha tire hugger modification and install
This is my version of the modified hugger from the Yamaha group-buy. It's from a bike that isn’t being sold in the US, hence the group-buy to make importing it cost-effective. Here's a link to that original thread, with several other solutions buried within from other Ninjetters:
http://www.ninjette.org/forums/showthread.php?t=78803 First I had to remove the left passenger peg bracket, and muffler, to gain adequate access to fit the hugger. Next I trimmed down the parts of the hugger that interfered with parts on the Ninjette. This needs to be trimmed to allow clearance for the rear break. The vertical stiffener on the inside was also shaved down to maintain clearance with the rear brake. Some material was trimmed from the side to make room for the stock rear brake line. Those with aftermarket SS brake lines won’t have to worry about this part. This square is trimmed to create clearance for the tab on the left swing arm that holds the inside edge of the stock chain guard. These are cut to cleanup the design and fit a bit. Next I fabricated some brackets out of aluminum sheet metal (I don’t recall the gauge used). This is the bracket for the hugger’s right side mounting bolt. I used a speed-nut clip for ease of use, and to maintain a minimal profile where space is tight. Note: The pictured bracket is actually the first prototype. I remade it with a little different angle so it would reach a little further back. You can’t see it in the picture, but this [first] bracket is held in place by the bold that holds down the brake hose guide. I just loosened the bolt, and slid the bracket under it, and it holds nicely, without the need to tighten it back down. A slot in the bracket, rather than a hole, allows me to do this without removing the bolt all the way. Here is the final bracket design painted, and installed. Right side being bolted up to test fit before the muffler was put back on. Although the hugger’s rear mounting hole fits fine with the original Ninjette design, a bracket was required for the front mounting bolt. Again a speed-nut tab was used. I really like them Brackets being spray painted. And here are the final results. The clearance between the right side and my AREA P isn’t great… in fact it touches, but hopefully this wont cause a problem, as it only rubs on the APEA P mounting bracket. I may trim the hugger down a little more later, if this proves to be a problem. Fortunately the muffler is high enough that I can easily access the right mounting bolt with a box wrench for easy hugger removal. EDIT: I went back and trimmed the right ride a bit. This seemed to help the fitment a bit. If you have done this mod/install, please post your pictures below too. I’m sure pictures of other solutions will be helpful to others who want to do this project.
Honda Interceptor VFR800 DLX (2014, 8th gen) Honda CBR500r (2014) - FOR SALE Kawi Ninja 250r (2008) - Restored and passed-down within family, only to be abandoned Last futzed with by headshrink; February 23rd, 2012 at 06:08 PM. |
February 11th, 2012, 11:41 PM | #2 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR Posts: 721
Awesome write up! That's a ton of work you had to put into that hugger! I hope my Honda CBR250 hugger doesn't require THAT much modding... If it does though, you'll certainly be my inspiration
ATGATT |
February 11th, 2012, 11:45 PM | #3 | |
I've been dying to see how the CBR250 hugger fits.... hurry up! ;p
February 11th, 2012, 11:51 PM | #4 |
Isn't there someone who already has the CBR250 hugger installed? I thought so! I'll see if I can dig that thread out. I'm waiting for it to get shipped here!!! Freaking Ride Now, they're always wrong on their days they tell me my stuff will get in. I deal with them as little as I can now, especially considering my brother works for Cycle Gear Anyway, should be here by like Tuesday.... I hope..... I REALLY hope... And I'll get it installed whatever day I get it I'm sure too. If it requires a lot of work I'll make a DIY like you did if one doesn't exist already
ATGATT |
February 11th, 2012, 11:57 PM | #5 |
Here ya go, a more-or-less DIY, just not quite as easy to follow as yours (though it's still plenty easy to understand) http://www.ninjette.org/forums/showt...cbr250r+hugger
They look pretty similar! At first glance I thought yours was from the CBR
ATGATT |
February 12th, 2012, 12:09 AM | #6 | |
February 12th, 2012, 12:11 AM | #7 |
Any time! Have you tested your undertail clearance? There's some fear stated in that thread about the possibility of the hugger hitting under high suspension compression.
ATGATT |
February 12th, 2012, 12:15 AM | #8 |
It never occured to me. I did one test run, but there weren't any really rough spots. I thought it may vibrate a bit up front/under tail, but it SEEMED fine.
February 12th, 2012, 12:21 AM | #9 |
You can always go out and just bounce on the tail and see how close things get that's how I'm going to test it. I might even set the preload back to 1 just to see (it's on 5 right now... With all my gear and stuff for class I'm probably around 250 pounds so I keep it on the stiffest setting)
ATGATT |
February 12th, 2012, 12:49 AM | #10 |
/linked from main DIY
February 16th, 2012, 08:40 PM | #11 |
So just found out today that my hugger was backordered... No clue when it will be in, I was told last week... Then today... Now whenever. This sucks!
ATGATT |
February 17th, 2012, 12:42 AM | #12 |
Join Date: Aug 2011 Motorcycle(s): RED 2010 Ninja 250r Posts: 304
I can't believe I missed out on this gb... I've always wanted that hugger
Nice write up man! Hopefully I will use this when I buy it (eventually...) |
February 17th, 2012, 01:30 AM | #13 |
Thanks. I'm going to trim down the right side a touch more the next time I have it off the bike.
February 23rd, 2012, 06:10 PM | #14 |
^bump^
I just added an edit at the bottom of the OP. I re-trimmed the right a bit.
February 23rd, 2012, 06:56 PM | #15 |
Gonna work on this this weekend
February 23rd, 2012, 07:35 PM | #16 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
my minion of huggers that i shipped over are being put through their paces and getting installed nicely
great job!
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
February 23rd, 2012, 09:24 PM | #17 |
Couldn't wait for the weekend and started just now...
How does your right side sit so flush like that with the brake hose guide there? I haven't made the bracket to bolt it on yet but mine sticks out way far because the guiding bracket is in the way. This is with the other side bolted on Does it matter if the brake line guiding bracket is removed? Mine sits perfectly flush without the bracket there (it pushes the hose under the assembly though). |
February 23rd, 2012, 10:15 PM | #18 |
Join Date: May 2011 Motorcycle(s): Red 2009 Ninja 250R Posts: 47
I removed the bracket when i did mine. (http://www.ninjette.org/forums/showt...rocket&page=16)
The brake line will still be secure without it. If you make a custom bracket it should straighten out the end of the right side.
DIY Byson rear hugger, DIY flush mounts, replica pazzo shorty brake/clutch lever, MGP growler exhaust, random tank pad, Shogun spool/slider kit, Targa fender eliminator |
February 23rd, 2012, 10:20 PM | #19 |
btw, great idea using the speed-nut clips. what kind of paint did you use? Ive been meaning to paint my brackets but i am not sure what would be the most durable.
February 23rd, 2012, 11:26 PM | #20 |
I used some rustoleum I had sitting around. I origionally got it to spray paint some pipe.
February 23rd, 2012, 11:29 PM | #21 | |
Mine did stick out a little, which is why I trimmed it down this weekend. This helped a lot. When I installed my area P, I hammered the bracket in a little for clearance. This helped a little for this mod too. If I had my pipe off right now, I would probably just remove the break line bracket altogether. I still may do that when my wheel comes off next.
February 24th, 2012, 02:23 PM | #22 |
Ta-daa!!!
Ended up taking the brake line bracket off and now it sits perfectly flush |
February 24th, 2012, 03:40 PM | #23 |
Nicely done.
DIY: koso gauge install | dyeforever | 2008 - 2012 Ninja 250R Tech Talk | 207 | March 30th, 2017 03:50 PM |
Yamaha Byson Tire Hugger for ninja 250 | cuong-nutz | Motorcycle-related | 2 | September 28th, 2013 05:28 PM |
DIY Power Commander Install | Sonofswin | 2008 - 2012 Ninja 250R Tech Talk | 3 | December 13th, 2011 11:04 AM |
Yamaha Byson Tire Hugger install | cuong-nutz | 2008 - 2012 Ninja 250R Farkles | 14 | November 24th, 2011 02:08 PM |
DIY ZG DB install ? | chef | 2008 - 2012 Ninja 250R Farkles | 5 | October 13th, 2011 04:44 AM |
