Old November 26th, 2008, 11:50 AM   #1
DIY- Removing the Kleen Air System Hoses and Plugging the Holes on a 08 250R
Kleen air system... what is it? It's a basic air injection system that draws air into the exhaust system to lean out the exhaust gases at certain throttle settings. It, in conjunction wit the 2 catalytic converters in the stock exhaust system, lowers emissions to acceptable EPA levels so Kawasaki can sell the bikes in the US.
Who should remove this system? With the stock exhaust in place, I have read that it may be a good idea to leave this system alone because if you did not lean out the exhaust with the cats in place you could cause converter clogging problems. No real proof if this is true or not... do so at your own risk if you decide to remove it.
If, however, you have installed an aftermarket full system on your bike and have no catalytic converters to deal with, you may want to consider this mod. I have installed an Area P quiet core system and ever since I have installed it, I was getting popping and backfiring at very small throttle openings around town and on downhill decel throttle settings. When I plugged the hose that ran from the airbox to the cylinder head, which is what the Kleen system uses to inject air into the exhaust, the popping and backfiring disappeared. It made a difference for me, so I decided to pull all the plumbing from airbox to cylinder head and plug the holes left by the hose and associated equipment.
This DIY shows how to remove the hoses and plug the holes left by it's removal.
Hose I removed is the 3/4" looking hose directly beneath the backbone of the bike with the gold colored keeper.
Remove the keeper and pry off the hose.
The hose is being pried off a vacuum controlled valve that needs to be removed. Simply slip it's rubber isolators off the bracket it sits on. From the valve, there is a short length of 3/4" hose that runs to the top of the cylinder head. Remove the hose from the cylinder head.
Remove the the valve and 3/4" hoses from the bike. There will be a vacuum hose that ran to the valve. Follow it back to a T and remove the hose from the T and cap the spigot on the T. I bought some 3/16" vacuum hose plugs that fit the T.
To make some plugs, I used 1/2"ID fuel hose, some old oil drain plugs I had laying around and some tie wraps.
You need to plug the hole at the top of the cylinder head and the hole at the airbox where the 3/4" hose came from.
And that’s it. The result is a lot less clutter under the tank area and hopefully no more backfiring and popping.
If I missed anything, I'm sure I'm going to be hearing about it.
Some pictures of the plumbing that was removed.
More extra pics:
Old January 15th, 2009, 06:18 PM   #2
HKr1
IC2(SW)
HKr1's Avatar
I know for a fact that an over rich condition will melt those honey comb cats and casue flow problems. It's really funny what Kawi is calling a cat on the 250r. That same piece in the muffler, is in the header. So from the Y-pipe juntion, to where it bends to go up to the muffler. Theres one of those so called cats. If you have the muffler off, look down in there with a flash lite. You will just see the end of it. I ran a bore scope thru there, it's open thru that piece to the y-pipe(just as it was in the muff).
I think next time we have the bike apart, we will plug off this AIS system also.
Heres a pic of that piece that came from the muffler. I dont see any real way to remove it from the header, but to cut at the y-pipe.... remove and weld back up. Dont think it would be worth the effort.
So anyway, plugging off this kleen air system (AIS) should be a good mod for those with slip-ons.
Old September 22nd, 2009, 05:37 PM   #3
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
Yours looks way different than my pre-gen. How would I go about doing it on my bike?
And yes I did search, that is how I ended up here after wadding through 3 pages of nothing useful.
ASecretNinja is offline   Reply With Quote
Old September 22nd, 2009, 09:09 PM   #4
Nevrfastenuf
Nevrfastenuf's Avatar
Motorcycle(s): 2009 ER-6n 2009 Ninja 250 sold :(
I don't have a service manual for the pre-gen, but from the looks of the parts diagrams on bikebandit.com there is no kleen air system on the pre-gens...
I don't have a pre-gen so I could be wrong.
http://www.bikebandit.com/houseofmot...s-1995/o/m4025
"Never argue with an idiot, they will just drag you down to their level and beat you with experience" -Unknown
Nevrfastenuf is offline   Reply With Quote
Old September 22nd, 2009, 10:23 PM   #5
ASecretNinja
ATGATT Squid Killer
Wow nice link. The thing I want to remove is the fuel evaporative system (schematic shown in that link). Part # 16165 is loose and flops around. No way to re-secure it and its driving me crazy.
Old September 23rd, 2009, 05:57 AM   #6
Nevrfastenuf
I would maybe consider just buying a new strap pn/92072 on those diagrams and keeping the system intact.
If you are interested in removing it, I would read through the following two pages. From what I can tell the red and blue color coding is similar between pre-gen and new-gen bikes.
http://www.ninjette.org/forums/showt...ight=emissions
http://faq.ninja250.org/wiki/Hose_ro...ine_fuel_tanks
Old September 28th, 2009, 07:32 PM   #7
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
hi Kelly,
need your advice/help.
i went through your DYI one last time after having removed the kleen air from my bike, and noticed a little difference between our bikes:
in your picture you have like a 4 way splitter i think?
did you plug the one end that went to the kleen air valve with the blue bit?
where do the other two tubes go?
on my bike when we took it apart, i had a 3 way splitter, one from the fuel tank, one to the kleen air valve, and one to the carb.
since we took out the end from the kleen air, we were left with just the fuel tank and carb, so we connected that direct:
i haven't had any problems with the bike since i did this mod, so i think its ok, but id still like to know if that's what i was supposed to do, to avoid any problems down the road because i was too lazy to ask
thanks bro~
W.
wayanlam is offline   Reply With Quote
Old September 28th, 2009, 07:38 PM   #8
on my 4 way splitter, one goes to the carb, which is the vacuum source, one is capped, one goes up to the fuel petcock (I think) and the last one is a separate hose I added which runs out to the side panel so I can check the carb sync easily.
you should at least have a hose that goes to the back of the fuel petcock off a 3 way splitter. do you?
Old September 28th, 2009, 08:24 PM   #9
wayanlam
wayanlam's Avatar
yeah, well i have the hose going directly from the vacuum source (the carb) to the fuel tank (petcock) its the smaller hose plug, next to the fuel outlet. i wasn't, and still am not quite sure what it does, nor what the vacuum source does, lol
i removed the 3 way splitter since i didn't have anything to plug the 3rd tip with, and just went direct.
how can u check your carb sync, and whats the use to do so? i think i remember browsing through a thread that looked into that, but was a while back, and i read it before i even had the 250, so i didn't really pay attention to it.
thanks!
Old September 28th, 2009, 08:37 PM   #10
syncing insures the carbs are pulling equally by adjusting a mechanical device/linkage which controls the carb butterflies. I suggest you reread that post on syncing for a better explanation and understanding on how to do it.
A properly synced bike will run/idle smoother and pull harder from the low to midrange.
Old November 7th, 2009, 03:17 PM   #11
Manimal
Manimal's Avatar
Motorcycle(s): 2013 Ninja 300 SE
Hi All,
I have a 2009 CA model.
First, thanks for the insight of correcting the popping / back-firing symptoms.
My plumbing is close to as pictured.
However, my CA model / version has a "T" that splits the hose (long hose pictured above) between the Vacuum Switch (Item 7, p3-6 of owners manual) and the Air Box. The split line / hose connects to the Canaster (Item 2, p3-8 of the owners manual), located on the left side of the motorcycle.
Therefore, I capped / plugged off the "T" end that goes to the Vacuum Switch. The other two hoses I left connected (to Canaster & Air Box).
I did follow the other steps of capping / plugging off the Valve Cover (or cylinder head cover) spout and the small 1/8" dia vacuum hose.
Question for the experts, why cap / plug off the valve cover (cylinder head cover) spout?
Does it blow or suck air (to/from the Vacuum Switch)?
Last futzed with by Manimal; November 7th, 2009 at 07:05 PM.
Manimal is offline   Reply With Quote
Old April 8th, 2010, 04:54 PM   #12
Dmitriy
voda?
Dmitriy's Avatar
Motorcycle(s): .... & a Ninja 250 duh
You can also grab on of these plate's here to make for a cleaner look:
http://www.shop.kyleusa.com/product....categoryId=121
Dmitriy is offline   Reply With Quote
Old April 9th, 2010, 08:07 AM   #13
Perbeils
Motorcycle(s): ninja 250r 09
This mod afect performance or just remove the popping and backfiring decelerating?
Perbeils is offline   Reply With Quote
Old April 9th, 2010, 05:49 PM   #14
wayanlam
wayanlam's Avatar
definitely removes the backfiring/popping sounds, which in turn lets you drive the bike a lot harder (by not feeling like a fool backfiring throughout the whole ride, lol) so yeah, in that case i would consider this a performance mod
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
Old April 16th, 2010, 05:15 AM   #15
Thrak
Motorcycle(s): Lots
Do you guys think there is any negative effect to the extra pressure in the top of the case from this being plugged up?
Thrak is offline   Reply With Quote
Old April 16th, 2010, 06:12 AM   #16
Momaru
Momaru's Avatar
Well, FWIW it's negative pressure (suction) at the top of the cylinder head cover where short big hose of the the Kleen Air attaches. I've plugged it with my hand before, testing the sound of sealed vs unsealed. It's not a whole lot of pressure. Given the thickness of the metal used (even if our engine is mostly aluminum), I'm not concerned in the least.
Proud member of the Blue Army
Old April 16th, 2010, 06:27 AM   #17
Thrak
Motorcycle(s): Lots
Its not a suction at idle, its blowing out a pretty good amount of air...
I'm more concerned about the gaskets, not the metal of the engine.
Old April 23rd, 2010, 07:26 PM   #18
Ninja North
Motorcycle(s): 2008 Ninja 250R (FI)
Anyone had experience on doing this Mod' on an FI bike?
Ninja North is offline   Reply With Quote
Old June 5th, 2010, 01:19 AM   #19
Kitdog
Kitdog's Avatar
Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color
The only thing I could add to this is that when I did mine, I went to the local auto parts store to get the "vacuum plug" for the T joint and right next to where they are located I found random elbow junctions, so rather than buying a cap I got the elbow and replaced the T junction. here is a pic of what I exchanged, on the right is the original, on the left is the replacement. It makes for a cleaner install.
"Well you know, for me, the action IS the juice"
Kitdog is offline   Reply With Quote
Old June 5th, 2010, 06:51 PM   #20
Ninja North
Thanks KKim - based on you DIY I managed to remove the Kleen-Air system from my FI bike. The back-fire was greatly reduced - I haven't had any since! There were a few different things from your carburetted bikes so I guessed a bit - after taking the tank off /re-installing it 4 times to check/correct my mistakes - everything is done! The bike is running great. Thanks again.
Old July 19th, 2010, 12:44 PM   #21
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
For removal on FI 250R.
There is no 3rd hose, only the 2 large ones are there. There is an electric switch which operaters the valve here, instead of vacuum. Thats why there is no 3rd hose, but the switch, needs to stay on the bike for the FI-light not to light up. I wrapped the 2 ends in some electro-tape and placed it back on the bike. No air going through it, so the valve isnt doing much, but it keeps the warning light off.
Guinss is offline   Reply With Quote
Old July 19th, 2010, 01:24 PM   #22
Thank you, Simen, for your contribution. Good stuff!
Old July 19th, 2010, 02:21 PM   #23
Ninja North
Just to add to Guinss's post - our FI bikes here in Thailand has another hose which goes to a "cannister" - same as So Cal bikes.
Old July 19th, 2010, 05:09 PM   #24
randomwalk101
self wrencher
randomwalk101's Avatar
Sling Shot Racing has this nice cap for the 250.
Old August 6th, 2010, 12:28 PM   #25
s2kenny
Lean in
s2kenny's Avatar
Motorcycle(s): Pearl White 250r, Raven R6, Black 600RR, Silver Ninja 250
Hey I was doing this to my CA model 250r.. and I have a question about some extra hoses.
Do I take these hoses off too and plug off that port? (the bundle that I'm holding)
s2kenny is offline   Reply With Quote
Old August 6th, 2010, 12:33 PM   #26
if it's no longer connected to anything, yes.
Old August 6th, 2010, 12:37 PM   #27
s2kenny
Lean in
s2kenny's Avatar
Oh ok great, so I guess for the CA models you need to plug up 3 holes? 1 on the air box, 1 on the carb, 1 on the crankcase
Old August 6th, 2010, 01:09 PM   #28
Crankcase? Sorry, not familiar w/ CA stuff, but a pic of the crank vent would help.
Old August 6th, 2010, 01:13 PM   #29
s2kenny
Lean in
s2kenny's Avatar
Crank vent, I'm sorry. The silver square on top! With the silver tube coming up like a chimney
Old August 6th, 2010, 01:17 PM   #30
picture please. there is a crankcase vent that you do not want to block. I want to make sure exactly what we're talking about.
Old August 6th, 2010, 01:46 PM   #31
s2kenny
Lean in
s2kenny's Avatar
*gets off lazy butt*
Here is the hole on the top of the engine
Here is the hole on the carburetor (brass fitting)
Thanks for all your help
Last futzed with by Alex; August 6th, 2010 at 01:51 PM. Reason: mongo pics fixed
Old August 6th, 2010, 05:56 PM   #32
Well, you do need to cap/plug the airbox hole and "chimney" at the top of the cylinder head.
That brass fitting on the carb is a vacuum source. What was connected to it before? I seem to remember more than one thing was connected to each of the vacuum ports on the carbs. (brass fittings)
Last futzed with by kkim; August 6th, 2010 at 08:31 PM.
Old August 6th, 2010, 06:58 PM   #33
s2kenny
Lean in
s2kenny's Avatar
Oops. It was connected with a T, and I don't quite remember where they hooked to to before. I'm going to have to try to pull up the diagrams for this
Old August 9th, 2010, 01:28 PM   #34
drumm3r9
Motorcycle(s): Kawasaki Ninja 250r
kenny I'm in the same boat.....got everything plugged but not sure what to do with the brass fitting on the carb....hhmmm....
drumm3r9 is offline   Reply With Quote
Old August 9th, 2010, 05:17 PM   #35
s2kenny
Lean in
s2kenny's Avatar
With some help from another member here, I learned that it's goes from the carb, to the bottom of the gas tank. It goes into the petcock. I just blocked off one side of the T and then put it back into the tank.
Old August 9th, 2010, 05:19 PM   #36
drumm3r9
aaahhhh i see....thanks for the help!!!!
Old August 17th, 2010, 06:20 PM   #37
illrational
illrational's Avatar
Motorcycle(s): Black '11 ZX-6R
Thanks KKim
DIY on removing kleen system made it a chinch...not sure if i like result but ill give it a ride or two plus with me about to shim and desnorkle i may be surprised.
My 250 is mine and mine alone, you may see better you'll definitely see worse but mine, she's one of a kind!!!!btw, SHE'S SEXY!!!
illrational is offline   Reply With Quote
Old August 17th, 2010, 11:02 PM   #38
was your bike backfiring/popping after you put the exhaust on it?
Old August 18th, 2010, 07:15 AM   #39
illrational
Talking
All the time especially when i first started up...it kind of seems like its starving for air now...i didnt run it for long but i'll crank it up when i get homme and get back to you.
Sorry i put in wrong section Alex,dont mean to make you work!!
Side note: I should get that green and white smiley face on my bike...
Old August 18th, 2010, 11:27 AM   #40
starving for air means you think the bike is running richer, not leaner. I think with the mods you've done and not doing anything to the jetting (I don't see anything mentioned in your sig) has you ruining lean, not richer. watch out you don't do damage to your engine if you haven't adjusted your jetting to compensate.
I don't think you'll want the smiley face if that should happen.
For Sale: Kleen Air System Jiggles Motorcycle-related 23 February 10th, 2014 07:07 AM
Removing the Kleen Air System on a stock bike oblivion007 2008 - 2012 Ninja 250R Tech Talk 3 January 25th, 2014 04:28 PM
Kleen Air System - Breather Filter DmbShn41 2008 - 2012 Ninja 250R Tech Talk 3 October 20th, 2013 07:51 AM
Who's taken off their Kleen Air System? walty87 2008 - 2012 Ninja 250R Tech Talk 10 January 29th, 2012 10:37 AM
Kleen Air system mxnello 2008 - 2012 Ninja 250R Tech Talk 6 April 13th, 2009 01:32 PM
