June 12th, 2014, 07:50 AM | #1 |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
Aftermarket Master Cylinder
Hey guys. I want to get my friend a new master cylinder for the ninja 250 as a gift.
He always complains about his braking and how his bike doesn't brake well. He is already using the vesrah pads. Has stainless steel lines. Don't want to switch the calipers so I'm going to switch the Master. Anybody using a Master cylinder off another bike? or an Aftermarket? If so which one, and how do you like it? What difference did it make? Thanks in advance!
It doesn't LOOK that steep. But you can go first... |
June 13th, 2014, 07:37 AM | #2 |
Fighting Texas Aggie '05
Brembo RCS 15
Go ahead and get two and send me one
September 13th, 2014, 11:37 AM | #3 |
Join Date: Sep 2014 Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4 Posts: 250
beacoup money!1...
at least braided lines and nice pads.. but this would be nice... http://www.motosport.com/motorcycle/...ASTER-CYLINDER |
October 14th, 2014, 08:38 AM | #4 | |
October 14th, 2014, 08:58 AM | #5 |
I've tried a lot of combos Nd here's what I've experienced.
1. I used a 636 master in the stock caliper. Bad idea.. It's too powerful for to the stock caliper specially since it's made to push 8 Pistons and we have only 2. 2. Used a tokico 4 pot caliper with the 636 master.. Better but the design of the tokico was such that the brakes started fading fast. 3. Used a brembo with the 636. Worked well but fading was still an issue. 4. Got a 2014 10r master and it was like a match made in heaven.. Amazing bite feedback and it's a single finger brake.. Couldn't be any better.. Although u would need to get a motion pro quick throttle in order to fit the master since it's radially placed and the throttle cables will come in the way. |
October 14th, 2014, 09:01 AM | #6 |
what size the the 10R master bore 16mm?
October 14th, 2014, 09:04 AM | #7 |
October 14th, 2014, 09:15 AM | #8 |
Nerd
Which Brake Caliper are you using with your Zx10r Master Cylinder? And what year Is the zx10 lever
October 14th, 2014, 09:17 AM | #9 |
there are alot of variables with pivot distance, piston size in bother master and caliper, along with mounting and lever orientation but I would think a 17/18 would be a little too big for my taste
R6 brembo is 16mm I think. Would be the one I would try.
October 14th, 2014, 09:18 AM | #10 |
I'm using a brembo from a 08 ktm Superduke 990 lc8. But any 100mm brembo caliper will. I uncanny find plenty on eBay from about 100$. And the master is from a 2014 10r
October 14th, 2014, 09:33 AM | #11 |
You need to find some of the posts by old3
He used a few different masters and did loads of brake stuff
October 15th, 2014, 07:12 AM | #12 |
svracing has one on their site as well... The boss man is a member here, not hard to find!
DIY - Installing a ZX-6R Master Cylinder | VeX | 2008 - 2012 Ninja 250R Tech Talk | 33 | August 27th, 2018 11:30 AM |
Which Master Cylinder should i get? | krolinked | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 12th, 2013 01:01 PM |
aftermarket front master cylinder?? | tac12345 | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 25th, 2012 01:03 PM |
front master cylinder wanted | 03slime250 | Items Wanted | 4 | July 14th, 2011 09:56 AM |
Master Cylinder woes.... | Rawr | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 22nd, 2009 07:13 PM |
