March 7th, 2010, 12:54 AM | #1 |
Join Date: Mar 2010 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 4
Gas gauge issues
Has anyone else had a issue with the gas gauge on ninja 250r? The tank is full but the gauge says empty
March 7th, 2010, 07:49 AM | #2 |
It's probably the most common problem with the 08+ 250r
March 7th, 2010, 10:02 AM | #3 |
You are sleeping
My gas gauge says I have less gas than I actually do.
It says 7/8ths tank when I'm full to the brim. I guess that's a good thing. I refuel at 1/8th tank so means I prolly have 1/4 tank left every time I refuel. Would explain the $8 fill-ups. My speedo indicates 5mph faster than I'm really moving too. None of the gauges are ever really perfect on these things.
<Yeah, it's a 250. LMFAO! Weaksauce |
March 8th, 2010, 10:29 PM | #4 |
Join Date: Sep 2009 Motorcycle(s): Blue 2009 Ninja 250R Posts: 103
My gas gauge shows empty with about a gallon left.
March 8th, 2010, 11:24 PM | #5 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
Mines inaccurate too, thats why I judge by the trip meter instead.
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
March 8th, 2010, 11:59 PM | #6 |
guessing there's not a fix for it?
March 9th, 2010, 01:04 AM | #7 |
March 9th, 2010, 01:15 AM | #8 |
March 9th, 2010, 01:16 AM | #9 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
My fuel gage is slightly inaccurate, but its no worse than any of the cars I've owned.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink |
March 9th, 2010, 01:57 AM | #10 |
That sounds like a dead fuel sender issue. make sure the wires are securely connected to the sender under the tank. If the bike is still under warranty, have it checked by the dealer if you would like it replaced.
March 9th, 2010, 03:17 AM | #11 |
March 9th, 2010, 04:46 AM | #12 |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
The only fix for the fuel level issue is a new sender.
The sense coil is wound all funky(sometimes) and the wiper has too much tension and wears out the button (usually) and the wire coil. If your gas gauge isn't indicating at all, as KKIM stated, either the sender is disocnnected (under the tank) or the sender is dead or the gauge is dead. Start with the easy stuff first. Luckily, the replacement is only about 30 minutes worth of work.
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
March 9th, 2010, 09:35 AM | #13 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
I can never understand why motorcycle gauges are always so inaccurate. Its not like the technology isn't there. I remember reading in a magazine one brand of bikes had really accurate guages. I know different tire brands and profile may affect the guage but by over 10%. Also the fuel guage should be a easy one to get right.
March 15th, 2010, 05:01 AM | #14 |
Newb since 10/2009
Join Date: Oct 2009 Motorcycle(s): 2009 SE. Slowly morphing to ADV bike. :D Posts: 182
My tank fills from empty tend to be just shy of 4 gallons. 3.8 or so. I kinda like it actually. It's like setting your clock ten minutes ahead so you're never late.
gas gauge issue | ac9im11 | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 20th, 2014 02:37 PM |
Gas gauge | Bblock | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 7th, 2013 09:05 AM |
Gas Gauge | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 3 | May 16th, 2012 05:36 PM |
Gas Gauge | gilmorec61 | 2008 - 2012 Ninja 250R Tech Talk | 3 | January 19th, 2012 03:19 PM |
Noob and gas gauge | BlackDynamite | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 2nd, 2010 07:40 PM |
