July 1st, 2011, 01:30 AM | #1 |
Indonesian NINJA 250r (Aprilia RS 250 legs swap)
Hi guys,
I would like to share our latest NINJA 250r modif project. Specs: Front Fork Aprilia RS 250 Swing Arm Aprilia RS 250 Rim Set Suzuki GSX-750 Katana (3,5 & 4.5 Inch) Front Tire Michelin Pilot Power 120/70-17 Rear Tire Michelin Pilot Power 160/60-17 Brake System BREMBO Exhaust System TWO-BROS Full System TK Chains Footstep & handle NUI These are the pictures:
STUDIO MOTOR Custom Bike See Our Blog: http://donnyariyanto-studiomotor.blogspot.com |
July 1st, 2011, 01:31 AM | #2 |
Additional Pictures
July 1st, 2011, 01:31 AM | #3 |
Swing arms close up
July 1st, 2011, 02:00 AM | #4 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
fix your blog link, you forgot to put the :
See Our Blog: http//donnyariyanto-studiomotor.blogspot.com it should be See Our Blog: http://donnyariyanto-studiomotor.blogspot.com kira2 berapa bisa habis untuk upside down fork depan? seumpamanya punya RS250 atau GSX, etc?
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
July 1st, 2011, 02:07 AM | #5 | |
The raw material price for upside down fork + dual caliper + triple clam will be around US$ 850-1000, depend on the year & condition.
July 1st, 2011, 07:52 AM | #6 |
Motorcyclist
Join Date: May 2010 Motorcycle(s): 2014 Ninja 300 ABS Posts: A lot.
Wow, great looking bike!!!
July 1st, 2011, 08:14 AM | #7 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
That bike looks awesome! Great job!
July 1st, 2011, 08:44 AM | #8 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R Posts: 190
I'll second what Slolane said... that's a hot looking bike, I would have gotten the white version, but the dealer said they were sold out for the year.... so I went with the black version instead.
ATGATT Quote Wild Hogs - Woody: "May be I don't want to wear a helmet, Maybe I don't want anything between me and the road" Bobby: "You will if your head falls on it" |
July 1st, 2011, 08:51 AM | #9 |
Eternal Noob
Join Date: Feb 2011 Motorcycle(s): "Blanka" 07' Ninja 250 Posts: 247
... drool.. omg this is amazing looking..
July 1st, 2011, 08:54 AM | #10 |
Wartown, USA
Hmmm. Interesting.
I was wondering if a RS125 swingarm would fit on the 250r. The 125 runs with a 150 60/17 on the back stock, so it would be ideal for the 250r. It would be much better than the stock swingarm the 250r comes with...better torsional rigidity, better chain adjusters, easier for track tire changes, wider for more tire options, and probably shave off quite a few lbs too. |
July 1st, 2011, 09:16 AM | #11 |
that looks awesome! I see all these bikes Fromm Indonesia and they look sick. did anyone in Indonesia make a pregen look sick before the current one came out? pictures too possibly?
July 1st, 2011, 09:34 AM | #12 |
There's a limit to s2pdty
Join Date: Apr 2011 Motorcycle(s): 250r ninja (sold) Posts: A lot.
dang... that's hot...
July 1st, 2011, 09:42 AM | #13 |
pregens were/are not availble here in indo, they were not imported/sold due to the high import taxes.
however, it seems like kawasaki have been able to pull some strings to get these new ninja 250s in without the insane taxes that other imported bikes usually still get. thus the big following that it has had over here ps, due to the falling dollar, and the reasonably strong rupees, they cost more now when counting in USD compared to when they first came out. its like over 6 grand for a new bike now, while a couple years ago, it was around 5 grand. mainly due to the changing exchange rates...
July 1st, 2011, 10:37 AM | #14 | |
July 1st, 2011, 10:43 AM | #15 |
In Indonesia, the dealer is very flexible, with additional US$400 we can order any color that we want. And the bike will be registered with the color that we order
July 1st, 2011, 11:10 AM | #16 |
thanks Wayan that makes sense. I was hoping to be able to get some trick parts for my bike. or at least drool at someone else's sick pregen. guess not...
July 1st, 2011, 11:28 AM | #17 |
Join Date: Mar 2011 Motorcycle(s): 09 ninja 250r Posts: 97
What all did it take to make it all work (FAB wise)? Looks amazing man.
July 1st, 2011, 12:12 PM | #18 |
OP, did you make careful measurements about the weight of the motorcycle before and after the modifications to the wheels, shocks, and the swingarm? I think the motorcycle appearance has been enhanced, however the increased tire wheel size and different shocks has me wondering whether there is an increase in weight of the project bike.
July 1st, 2011, 05:38 PM | #20 |
@ducducgooseit:
even though the swing-arm looks bigger, i would not be surprised if it actually weighs less. ive picked up a yamha R6 swing-arm which is even bigger i think, and it it was really light...! as far as the riding geometry goes, it probably changes it by quite a bit, usually more aggressive/lower (yey... back pains, lol) keep in mind, that these mods are usually intended more for the look than the "performance" although quite often i would imagine you would benefit from the higher grade shox and brakes if its assembled properly. oh ya, depending on the wheels, they can also be quite a weight saver. i wouldn't be surprised if the aprillia rims weigh less than the original ninja rims, seeing that the RS250 is really performance oriented.
July 1st, 2011, 05:54 PM | #21 | |
July 1st, 2011, 06:08 PM | #22 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
you guys really drop some serious cash on you're 250s over there...
July 1st, 2011, 06:09 PM | #23 | |
Nothing were changed on the original NINJA frame, no cutting, no grinding. Cut a little bit on the Aprilia swing-arm axis, 3mm (1,5mm on each side) and it will perfectly fit into NINJA frame. Maintain the original NINJA rear-shock but we have to make a new longer links. Use both original Aprilia triple clam but maintain the original NINJA steering hub. Thats all ...
July 1st, 2011, 06:14 PM | #24 |
Aftermarket parts, very easy to find them in our country.
The undertail is made from fibre-glass, price: US$75; The plate mounts is made from powder coated metal, price: US$15
July 1st, 2011, 06:14 PM | #25 |
instead of importing 2nd hand parts from America into Indo, you need to export mechanics that can do this kind of work TO the states, haha... i think maybe you can make more money
they are lacking affordable modders over there, lol well... if only that were possible, huh...
July 1st, 2011, 06:41 PM | #26 | |
July 1st, 2011, 06:44 PM | #27 |
Believe me Sir ... It's not that expensive
July 1st, 2011, 08:29 PM | #28 | |
Is the undertail custom made, or is it mass produced? I have a few friends in Indonesia, and if I can give them the place where they can buy the part, Ill have them ship it to me in the states.
July 1st, 2011, 08:45 PM | #29 |
Mass produced Bro. U can tell your friend to go Kebon Jeruk on Otista - Jakarta, many stores there sold NINJA 250r aftermar
July 1st, 2011, 08:53 PM | #30 | |
One more thing... can you post up a picture of the undertail by itself so I can email it to my friends for reference, or a part number and manufacture? Thanks again for your help.
July 2nd, 2011, 09:51 AM | #31 |
Wow, that bike looks bad a$$.
July 2nd, 2011, 09:58 PM | #32 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
WOW!!! Your bike is freakin' sweet!!! Definitely love what you've done to her... would love to do some of those mods to mine!!! Keep up the good work
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
July 2nd, 2011, 11:24 PM | #33 |
I'll be very happy to help ... if you need any informations or detail photos on the specific part of the bike, just let me know.
July 2nd, 2011, 11:25 PM | #34 |
I'll PM the photos asap Sir
July 3rd, 2011, 01:12 AM | #35 |
Join Date: May 2011 Motorcycle(s): 08 250r Red Posts: 61
beautiful O.O
July 4th, 2011, 01:20 AM | #36 |
Ninja Master
Join Date: Feb 2011 Motorcycle(s): 2010 Ninja 250r Posts: 43
The bike is a keeper!!!
Any engine mods done? Rejet? Air Filter? Etc. |
July 4th, 2011, 01:24 AM | #37 |
Thx Bro! Original air filter & simple rejet. PJ to 40, change the jet needle but keep the original MJ.
July 4th, 2011, 02:11 PM | #38 | |
July 5th, 2011, 01:08 AM | #39 |
I am using the 1997 Aprilia upside-down & swing-arm. Thats the best that i can get here. If u can get the younger year, don't be hesitate to get it!
July 5th, 2011, 08:36 AM | #40 |
Ninjette wanabe :D
Join Date: Apr 2011 Motorcycle(s): white 300 :D Posts: A lot.
is a swing arm easy to get there :S?
VROOOM vrooom >.> |
Indonesian NINJA 250r Modern Cafe Racer II | munandar | Pictures | 25 | February 4th, 2012 11:21 PM |
Indonesian NINJA 250r Flat Track Modif | munandar | Pictures | 22 | August 6th, 2011 03:31 PM |
