August 2nd, 2011, 03:36 PM | #1 |
need help removing sticker glue
I have the blue ninja with white decals and I want to put black decals on. I removed one decal so far and now I cant get the glue off. I've tried boiling hot water, tried wd40-its taken gum off my car a couple times, I've even tried a can of stuff that claims to remove road tar and bug stains. Oh and I also tried alcohol based hand sanitizer and nothing is working. Does anyone know what will work? PLEASE HELP ME, THANK YOU.
August 2nd, 2011, 03:40 PM | #2 |
Hair dryer, heat it up and wipe it right off
August 2nd, 2011, 03:42 PM | #3 |
/moved to General
August 2nd, 2011, 03:56 PM | #5 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
I just used my chain cleaner and the residu came of immediately, no paint damage
I can not be a true player by playing around. |
August 2nd, 2011, 04:03 PM | #6 |
Join Date: Feb 2011 Motorcycle(s): '96 EX250 Posts: A lot.
Works great. Works better. (careful using it on paints / clearcoats though)
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è. |
August 2nd, 2011, 04:07 PM | #7 |
Supplies: Clear cellophane tape and a hair drier.
Preparation: Take about 8" of 2" wide cellophane tape and make a loop with the sticky side out - big enough for two or three of your fingers to fit inside. Use the hair dryer to make the sticky residue warm-to-very-warm to the touch. Technique: Using perhaps 1/2" to 3/4" of the cellophane loop, roll the loop across the now warm residue. Theory: The idea is to use the cellophane tape to adhere to the residue and lift the residue off the bike. It takes a few "touches" and a bit of patience but that technique has removed sticker residue from painted plastic, glass, and painted automobile metal for me without damage of any kind. Tips: Don't overheat the residue, you could muck up plastics. And just "tap-n-go" with the loop. You'll get a feel for the technique rather quickly. |
August 2nd, 2011, 04:13 PM | #8 |
Thanks guys, just ordered a bottle of Goo Gone from Amazon.com and now I'm going to try my chain cleaner. I'll let you know if it works.
August 2nd, 2011, 04:31 PM | #9 |
ok just tried my chain cleaner/lube and its not working so im just gonna wait for the goo gone to come in. thanks again guys.
August 2nd, 2011, 04:39 PM | #10 |
too bad. Well, I have a chain cleaner that's rather agressive, it gets anything off of anything
August 2nd, 2011, 05:03 PM | #11 |
carb cleaner will usually get it off. someone will respond top this by saying it will hurt your paint. Try it in a small spot and see. Ive used it a hundred times on factory paints on bikes and cars and haven't hurt any yet.
August 2nd, 2011, 05:12 PM | #12 |
Why don't you just go get it at walmart, target or any auto parts store?
Removing the carb-without removing airbox? | tuscani451 | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 6th, 2014 05:11 AM |
Glue on Helmet? | Daks | Motorcycle Gear | 7 | November 17th, 2012 06:03 PM |
Removing Mirror Bracket (with removing all the fairings) | killermase | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 21st, 2012 11:16 PM |
type of glue to use | wayanlam | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 30th, 2011 09:33 AM |
glue residue | bash | General Motorcycling Discussion | 17 | January 28th, 2010 02:26 PM |
