September 16th, 2010, 01:35 PM | #1 |
Stealthy Ninjette
Join Date: Aug 2010 Motorcycle(s): 09' Kawi Ninja 250R Posts: 109
Help! New Shift Lever!
So I got my new shift lever today, put it on the bike and it will shift down into first but wont shift up past neutral after that
What is going on?
09' Stealth Ninja 250R Growler Exhaust, Fender Elim, CF LED rear turns, DIY Flush Mounts, & Red Rim Tape My Ninja's Blog! |
September 16th, 2010, 01:37 PM | #2 |
is the bike started and moving or are you playing with it w/ the bike off and stationary?
September 16th, 2010, 01:39 PM | #3 |
Stealthy Ninjette
Does the bike have to be moving in order to throw it into 2nd+? If so I feel like a rahtard... lol
September 16th, 2010, 01:41 PM | #4 |
September 16th, 2010, 01:44 PM | #5 |
Stealthy Ninjette
thanks KKim, if it wasn't rainy and crappy outside i would try it out
September 18th, 2010, 04:04 PM | #6 |
It's funny.... I had the same question once, even though I knew the answer... was under stress, and forgot.
BTW: If your original shift lever can be bend back to be able to function (held in a vise, bend with a pipe), it can be good insurance in the saddlebag on long rides. I once got so distracted by the need to photograph some mountains, that I forgot to put my kickstand down before dismounting.... fortunately I caught it before bending the shifter, but I would have been calling a tow truck had I bent it. This was the second time.... the first time was in my garage, and I couldn't shift anymore, until I bent it back. I now bring the re-bent lever with me on those longer trips as a spare - just in case. More importantly though, I am more conscientious about using the kick-stand. |
September 18th, 2010, 06:13 PM | #7 |
Join Date: Mar 2010 Motorcycle(s): Blue 10 250r Posts: 697
If you have a rear bike stand, you can spin the wheel with your hand and pop up into 2nd. Just finished beating my old one straight, twisted it up at track. Melted the plastic bushing inside it while blowtorching to bend it, so I replaced it with electrical tape. Tested it out and its a little wiggly, but can hit all gears
Bolt to shift lever on too tight | antiant | General Motorcycling Discussion | 12 | July 12th, 2014 09:23 PM |
My shift lever fell! | LR1914 | 2008 - 2012 Ninja 250R Tech Talk | 14 | October 2nd, 2013 09:31 AM |
Shift lever not resetting | Malicious Logic | 2008 - 2012 Ninja 250R Tech Talk | 13 | August 5th, 2012 06:35 PM |
WTB: Left side turn signal/clutch lever/ shift lever/fairing (green/red or black) | daedrick | Items Wanted | 0 | April 3rd, 2012 12:44 PM |
New shift lever? help | clintalmighty | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 13th, 2011 11:33 PM |
