Old May 8th, 2014, 09:15 PM   #1
justinocean
Kawasaki Sith Lord
Name: Alex P. Keaton
Yoshi TRC Slip-On..
Does anyone have the Yoshimura TRC slip-on?
I've seen many a youtube vid on it but was hoping for some first-hand accounts. I'm looking for a loud exhaust, tired of the stainless steel stock silencer.
justinocean is offline   Reply With Quote
Old May 8th, 2014, 11:48 PM   #2
ninja250r81
ninja250r81's Avatar
I have a Yoshimura TRS slip-on exhaust
Same but different end.
Shimmed the carbs with 3 washers, Kn filter, restrictor until i brought a jet kit. little lean
Yoshi stage 2 jetkit, Kn filter, restrictor with recommended 98 jet and 2.5 turns out. rich
Removed exhaust restrictor, snorkel removed, picked up mid range throttle response. Close to perfect.
A little loud. BUT i LIKE IT
Annoyed that i didn't go with Yoshi TRS full exhaust right from the start, due to pulling most of the fairings off to remove the carbs for the jet kit install.
Old May 19th, 2014, 08:25 PM   #3
C-Bass
C-Bass's Avatar
Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE
I have the TRC full system with carbon fiber canister installed on my 2012 Ninja 250. Huge improvement in sound quality! A little on the loud side. A dB killer insert is provided to reduce the sound level if so desired -
C-Bass is offline   Reply With Quote
Old May 19th, 2014, 08:50 PM   #4
verboten1
verboten1's Avatar
MOTM - June '15
My bike came with the yoshimura CF slip on,I like the way it sounds
Ride more, worry less.
Old May 22nd, 2014, 03:45 PM   #5
justinocean
Kawasaki Sith Lord
I wonder does the full exhaust sound any better than the slip on exhaust?
Old May 22nd, 2014, 05:56 PM   #6
misfitsailor
Ninjette Jockey
misfitsailor's Avatar
Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP
I bought the Yoshi slip-on, then soon after bought the Yoshi full system. I can't tell the difference in sound between them. Yoshi mufflers have a noise reducer that slips in. Without it, you can wake the dead. With the insert in place, it sounds louder than stock, but not annoying. The slip-on gives you more noise, the full system gives you more power!
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?.
misfitsailor is offline   Reply With Quote
Old May 24th, 2014, 07:05 PM   #7
justinocean
Kawasaki Sith Lord
did u rejett or get anything done in addition with the full yoshi exhaust? or does the full exhaust just by itself give more power?
Old May 24th, 2014, 08:09 PM   #8
ninja250r81
Slip-on,
depends on what altitude you live at you "COULD" get away without.
May get away with shimming the needles with 2 washers.
Full system, you have too the bike will go lean and destroy a head or engine.
Jet kit definitely needed.
dyno-jet stage 2 2193 and stage 3 2393
http://www.dynojet.com/jetkits/motorcycle/kawasaki.aspx
Old May 25th, 2014, 09:45 PM   #9
Bob2010
Bob2010's Avatar
I have both. One bike with a full system and one with just a slip on.
Most people would say they can't tell. I can tell/ hear a difference. Trying to explain it online isn't soo easy.
2010 Red Ninja 250
2009 Black Ninja 250
Old May 27th, 2014, 02:40 PM   #10
justinocean
Kawasaki Sith Lord
Well you would be the person to ask the next question.. Id like to do a full system but by the time I add up the exhaust, the jet kit, and pay someone to tune it right I don't know if its worth the price for the hp gain. I can just put a slip on for minimal cost and at least have a good sound.
Old May 27th, 2014, 03:31 PM   #11
Bob2010
Bob2010's Avatar
I will say I absolutely love the sound of my full system. Just like what you stated above , that's why the other bike got the exact kind of slip-on.
Wether or not you need to shim needles or etc... That's up to you
As far as sound goes , yes , it's great. Performance , I don't know. My full system "feels" stronger
2010 Red Ninja 250
Old May 28th, 2014, 08:28 PM   #12
kennetht
kennetht's Avatar
how can you tell if you have the full system or just the slip on?
when i purchased my bike it had the TRC on it already, but I never thought until now if I had the full or just slip on...
image of my bike below for visual help
kennetht is offline   Reply With Quote
Old May 28th, 2014, 08:37 PM   #13
Bob2010
Bob2010's Avatar
Look at your header. Is it chrome?
2010 Red Ninja 250
Old May 28th, 2014, 09:04 PM   #14
kennetht
kennetht's Avatar
just to confirm, the header is the pipes leading from the engine to the beginning of the exhaust?
here is an image that you should be able to tell. looks like it was possibly chrome at one point, but has a bit of dirt/rust on it now... hard to tell
File Type: jpg 1173841_10202109752648773_1660088888_n.jpg (122.0 KB, 15 views)
Old May 29th, 2014, 05:32 PM   #15
justinocean
Kawasaki Sith Lord
Correct me if I'm wrong but I believe the pipes (they curve along the bottom from the front) on a FULL exhaust are larger than the stock. Of course how can you know if you have nothing to compare it to.
Old May 31st, 2014, 10:17 AM   #16
kennetht
kennetht's Avatar
exactly lol. i have no idea if mine are the stock pipes or part of the set. not a clue
Old May 31st, 2014, 05:42 PM   #17
C-Bass
C-Bass's Avatar
I just installed the dB killer insert. It reduces the sound level considerably.
Restrictive but easier on the ears.
Still sounds awesome!
Old May 31st, 2014, 08:18 PM   #18
Bob2010
Bob2010's Avatar
Nice !
Sooo where did ya get it and how do you install it?
2010 Red Ninja 250
Old May 31st, 2014, 08:40 PM   #19
C-Bass
C-Bass's Avatar
The dB killer insert is included with the Yoshimura TRC full system exhaust. It took a bit of persuading to get it in the end of the canister and lined up with the hole for the 6mm hex head screw that's provided to hold it in place.
I used a 6mm bolt instead.
Old May 31st, 2014, 08:51 PM   #20
Bob2010
Bob2010's Avatar
Ahh ok. Yup. Don't have that part lol
2010 Red Ninja 250
Old May 31st, 2014, 08:55 PM   #21
C-Bass
C-Bass's Avatar
I thought it should be included with just the TRC canister also.
Maybe it's available from Yoshimura??
The sound is quite subdued with it installed. I like it!
Old May 31st, 2014, 09:04 PM   #22
Bob2010
Bob2010's Avatar
Hmm Maybe I should make a WTB thread in the market section. Hopefully somone has an extra one laying around they would like to sell
Thanks!
2010 Red Ninja 250
Old June 2nd, 2014, 07:36 AM   #23
kennetht
kennetht's Avatar
Any way you can make a video with the new sound? This may be something I am interested in getting. At times, I dont like the loudness of my exhaust. Especially when I am on the back country roads where it is nice and quite.
Old June 2nd, 2014, 05:56 PM   #24
C-Bass
C-Bass's Avatar
The cool exhaust note is the same with the insert, but the sound intensity is way less.
Inserts are available from Yoshimura -
http://www.yoshimura-rd.com/prodcat/...nt-inserts.asp
Old June 2nd, 2014, 08:19 PM   #25
Bob2010
Bob2010's Avatar
Sweet. Thanks for the link
In for sound clips
2010 Red Ninja 250
Old June 4th, 2014, 08:56 PM   #26
justinocean
Kawasaki Sith Lord
Yeah I'd love to get a full system but between that, the re-jett, and the install price I'd be at like $600-$700..
FS/FT: 08+ Yoshimura TRC Carbon Fiber Slip-On radi4fun Motorcycle-related 7 July 5th, 2013 02:30 PM
Yoshi TRC slip on IconChris 2008 - 2012 Ninja 250R Tech Talk 7 April 17th, 2013 06:02 PM
Yoshimura TRC Slip-On for Ninja 250 Bones85 Motorcycle-related 2 February 9th, 2013 12:21 AM
Yoshi TRC Cf full exhaust ninja 250 08 wellcraft 2008 - 2012 Ninja 250R Tech Talk 8 August 3rd, 2010 09:10 PM
Yoshi TRC Cf full exhaust ninja 250R wellcraft General Motorcycling Discussion 7 January 23rd, 2010 06:40 AM
