Old December 20th, 2023, 08:53 PM   #1
Hogges
Motorcycle(s): R1200GS, DR200SE, Ninja EX300
How to remove sprocket carrier (rear wheel) bearing?
The unsealed ball bearing in the sprocket carrier of my 2014 300 broke. The center ring is of the bearing is in pieces. This makes it impossible to use a bearing puller. There is no lip on the inside to remove the bearing with a punch.
Any other ideas rather than a dremel with cutoff wheel?
Hogges is offline   Reply With Quote
Old December 21st, 2023, 05:56 AM   #2
I haven't had mess with that bearing, but usually you can use a punch at somewhat of an angle to whack on the race around its circumference and get it to come out. Heat helps, since aluminum expands with heat more than steel.
If there's really no race available to seat the punch on, I've seen cases when you have to use something like a Dremel tool to make a couple notches in the aluminum to allow access.
Old December 21st, 2023, 06:26 AM   #3
Hogges
There is no protrusion or gap whatsoever. I did get a little bit of traction with a sharp chisel but because of the width of the chisel only the edges would grip and then slip when hit with a hammer. I was thinking of going out and getting a very narrow (1/4”) chisel. I do like the idea of the two notches in the soft aluminum carrier. Thank you.
Old December 21st, 2023, 02:12 PM   #4
Hogges
Success! 450F in the oven, then tried the chisel again which got it started. The punch did the rest.
Old December 21st, 2023, 03:02 PM   #5
Good! I'm glad the heat worked.
Sprocket carrier bearing replacement The_big_dill 1986 - 2007 Ninja 250R Tech Talk 6 May 27th, 2014 10:08 AM
