October 11th, 2013, 03:34 AM | #1 |
Join Date: Mar 2013 Motorcycle(s): '08 Ninja 250R Posts: 69
Applying decals - clearcoat?
Heya,
it's not a problem applying decals or vinyls, I just use the same process as on a model car. However, I've noticed the ninja / kawasaki decals are coming off my fairings. The bike's 5 years old and the PO put cheap fairings on it. I have no idea what quality the decals are or how he applied them. I'm about to order OEM left-side fairings, and want to match it up to the 2011 special edition "ebay" fairings on the right. I wash my bike regularly (full clean 3 times a month, including wax). Will the decals need a very light clearcoat to prevent peeling / scratches? The side fairing has a huge portion of black on it - I don't know if it's painted on or not (mine is...and it looks horrible!) A professional quoted me 250 dollars to just prep, paint and coat the black areas. Black vinyl sheet off Amazon costs me 14 dollars...I'm guessing that'll need coating? As it's not as resistant as paint / coat. I'm a perfectionist when it comes to the little Ninja turtle, so I wouldn't want any of the vinyl to develop scratches or peel prematurely. What do you guys recommend? |
October 11th, 2013, 04:15 AM | #2 |
Blind 250 Loving Whore
I'm a little confused to what you're going to do. The new OEM fairings you're going to buy aren't coming with decals?
If not it shouldn't be much to have a shop match the decal in vinyl, it's not that complicated. Vinyl is always soft and it will swirl but shouldn't scratch if you're careful with it. I still wouldn't clear over the new vinyl though. If you're washing carefully you shouldn't have any problems with a quality decal. |
October 11th, 2013, 06:33 AM | #3 |
The oem plastics don't come with anything as far as I'm aware. Id be purchasing the Kawasaki and ninja decals off the web, and a sheet of black vinyl to match the paint job. Shops around here will gladly rip me off, and the cheapest I've found for recreating the paint job in vinyl was charging 90.
Good to know I won't need the clear coat though. Thanks! |
October 11th, 2013, 06:54 AM | #4 |
The proper vinyl will be exceptionally durable.
In order to clear coat over decals or vinyl you would have to clear the entire panel. If it's been repainted there's a good chance you could have big problems. Much easier to just replace the stickers or vinyl if they start to look shabby. You said you wax your bike frequently - and that's a problem if you are applying decals. All of the wax must be removed in order for the decals to adhere properly. A "wax and grease remover" is the best bet, but there may be other chemicals that will do it - just be careful they don't soften the paint. The last wipedown before applying the decals should be alcohol, and don't touch the adhesive on the sticker or the area where it's going on the paint. If you haven't done it before you may want to order a couple extra stickers in case you have problems. It's not super difficult, but there are techniques that you need to use to keep from getting air bubbles under the sticker as you go. Using soap and water also helps if the sticker is large and needs to be positioned precisely, but you need to use the correct soap (Johnson's Baby Shampoo is often recommended) and the correct amount to avoid problems later. |
October 11th, 2013, 03:20 PM | #5 |
Thanks for the advice Jay
The issue isn't actually applying them. Just questioning their longevity. With all the gravel on these roads I was worried about pebbles and the like leaving scratch marks on the vinyl. I suppose it would be easier just re-applying them if and when they start to peel. |
Cleaning solvent before applying chain lube | nickjpass | General Motorcycling Discussion | 17 | August 21st, 2014 01:07 PM |
How successful is applying touch up paint? | THE BIG SITT | 2008 - 2012 Ninja 250R Farkles | 11 | April 11th, 2014 12:12 PM |
stalls sometimes when applying throttle | ninja12345 | 2008 - 2012 Ninja 250R Tech Talk | 11 | November 3rd, 2013 07:41 PM |
DIY- Applying Vinyl Graphics | kkim | 2008 - 2012 Ninja 250R Tech Talk | 25 | March 3rd, 2012 05:35 PM |
applying brake before releasing throttle? | alex.s | Riding Skills | 29 | January 29th, 2012 12:45 AM |
