Go Back   ninjette.org > Marketplace > Gear-related
Old July 25th, 2009, 02:24 AM   #1
Rafalski
Motorcycle(s): Ninja 250R 08
XL Shark Helmet 10/10 Not a single scratch
I have a XL shark helmet i bought and used twice (during my rti course) It is immaculate and has not even a single scratch.
During said course i found out the fit was too lose (first helmet purchase)
So i went out and purchased a size LARGE. Trying to recoupe some cost.
250 shipped, o.b.o
I will get more pictures of the helmet later.
Here is some info about the helmet.
RSX excels in any circumstances. Its aerodynamic qualities mean it is equally at home for sports or GT use. The clean design and advanced technology will bring your senses to life and make this helmet your essential companion
BRA- Black/Red/Anthracite
Shell made form Carbon-fiber/Kevlar multi-directional fibers.
Two Shell sizes.
Multi-element interior shock-absorber (6) with air differential density
Airflow directed by integrated ducts.
Dual treaded (anti-scratch/anti-fog) “Total Vision” 3 mm visor.
“Push One” visor quick release system using 4 anchorage points.
"Touch One" fluch rapid-opening ventilation.
Optimized demisting thanks to “Venturi” side extractors.
Fully adjustable, removable & washable interior using 100% Coolmax® & Sanitized fabrics.
Ergonomic 3D foam cheek pads.
Breath guard and chin cover.
Double-D ring “Racing” chin strap.
Anti-fog mask & chin for visor.
Weight: 1350g
DOT and ECE 22-05 Approved
Last futzed with by Rafalski; July 30th, 2009 at 01:30 AM.
Rafalski is offline   Reply With Quote
Old July 30th, 2009, 01:27 AM   #2
Rafalski
Bump.
Common no one has a XL head who needs a helmet. IT does not get any better then this baby.
Old July 30th, 2009, 01:28 AM   #3
I think a picture might help.
Old July 30th, 2009, 01:30 AM   #4
Rafalski
Picture added. Will add My own pictures of the Helmet about tomorrow or so.
Old July 30th, 2009, 08:47 AM   #5
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
What is the sizing like? (I'm large in some Medium in others...might be XL in Shark)
Using Pedal Power
divingtigger is offline   Reply With Quote
Old July 30th, 2009, 09:12 AM   #6
AnarchoMoltov
AnarchoMoltov's Avatar
Motorcycle(s): 2007 Suzuki GSX-R750
too bad its XL and red
AnarchoMoltov is offline   Reply With Quote
Old July 30th, 2009, 01:31 PM   #7
Rafalski
If your a medium in some and large in some theres probably no chance your a XL.
But so you know its a 61-62cm fit around the head, you should measure about 1inch from the eyebrow.
this has more info
http://sportbiketrackgear2.homestead...ize_chart.html
IF it was L I would have been using it. Had to buy a Large rsr2 when i found out that the fit was bad.
Last futzed with by Rafalski; July 30th, 2009 at 01:32 PM. Reason: Addition
Old August 11th, 2009, 12:07 AM   #8
Rafalski
Bump plus pictures
Front view
Side View
My new top and old helmet size. Showing that I didnt **** it up and am making up bs. I actually couldnt wear the XL.
Old August 15th, 2009, 02:23 PM   #9
Imthebriman
Imthebriman's Avatar
Motorcycle(s): 07 Kawi 250R
I know you are trying to recoupe funds but is that the lowest you will go?
Imthebriman is offline   Reply With Quote
Old August 16th, 2009, 03:11 PM   #10
Rafalski
Im open to offers.
Old August 22nd, 2009, 10:38 PM   #11
Rafalski
Originally Posted by Rafalski View Post
Im open to offers.
bumping for openness.
Old December 16th, 2009, 09:42 PM   #12
Rafalski
200 SHipped o.b.o
Have it and want it gone. Im losing out as I cant really Use it.
Old June 5th, 2010, 11:31 PM   #13
Rafalski
200 SHipped o.b.o
Bringing it back up.
Old June 8th, 2010, 01:53 PM   #14
addy126
Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt
Hmmm can't you put a Shark Large inner liner into it thereby making it more useful to you. If the shell size of the XL is the same as a Large... its doable to pull the XL liners and shove the L in (including cheek liner)
addy126 is offline   Reply With Quote
Old June 8th, 2010, 03:11 PM   #15
Rafalski
Yeah except the top part of the head doesnt fix the issue. I tried that course of action when it first happened. put in smaller linear and small cheek pads but the crown of the head moved.
Arai helmet VS new shark s900 C jack_bm Motorcycle Gear 8 February 10th, 2012 09:34 AM
Dazzling Daft Punk Helmet Made From Scratch FerociousNINJA Off-Topic 3 July 23rd, 2010 10:08 PM
[motorcyclistonline] - Shark RSR2 Helmet Ninjette Newsbot Motorcycling News 0 July 9th, 2010 07:30 PM
Shark s650 Helmet Medium - $90 00v_Lucky Gear-related 0 May 25th, 2010 11:42 AM
Shark Helmet tinng321 Motorcycle Gear 15 May 20th, 2009 09:35 PM
