Old September 7th, 2009, 09:48 AM   #1
250grunt
250grunt's Avatar
Motorcycle(s): 07 ninja 250
having alot of problems :(
the other day i got on my bike and it would only run with full choke if i moved the choke lever it would die almost instantly. Today i tried starting it and it wont start unless its on full choke. it instantly goes to 5k rpms and if i give it throttle it dies. sometimes it will start without choke but if it does it will fail to idle and just die after a few mins unless i am constantly feathering the throttle. When it dies also i notice there is a weird sound like air being released from the front end if that makes any sense. so as of now i cant ride it i dont know whats going on. I didnt ride it for 11 days before this because i went out of state. But yea any help is appreciated.
250grunt is offline   Reply With Quote
Old September 7th, 2009, 09:54 AM   #2
how long was it between the time the engine was actually started between your trip out of state? was it 11 days between the times you started the bike or was your trip 11 days?
sounds like your pilot jets are clogged. flush your gas, refill with fresh gas and try adding some seafoam to the tank.
Old September 7th, 2009, 09:56 AM   #3
250grunt
250grunt's Avatar
yea i was out of state for 11 days and it wasnt started at all. Ill try that where can i get seafoam auto parts store?
Old September 7th, 2009, 10:00 AM   #4
yes, most autoparts stores have Seafoam. call them first, though. I've also seen it at Walmart recently.
could you have gotten a bad batch of gas?
Old September 7th, 2009, 10:03 AM   #5
250grunt
250grunt's Avatar
alrite ill check it out kkim thanks and i dont know my bro in law thinks its either bad gas or water in the fuel
Old September 7th, 2009, 11:04 AM   #6
250grunt
250grunt's Avatar
well its started raining, and unfortunately dont have a garage so gonna hold off til it stops raining which will hopefully be soon. weather isnt looking good all week
Old September 10th, 2009, 06:40 PM   #7
Purspeed
Purspeed's Avatar
KKim is right...get 'yer SeaFoam in there.
That's step one.
Then come back and report.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008)
Purspeed is offline   Reply With Quote
Old September 10th, 2009, 06:57 PM   #8
250grunt
250grunt's Avatar
started it up today and it ran fine no problems at all
Old September 10th, 2009, 07:12 PM   #9
lavid2002
lavid2002's Avatar
Motorcycle(s): None yet
Preventative action that was your warning put some cleaner in there
-Dave
lavid2002 is offline   Reply With Quote
Old September 12th, 2009, 10:57 AM   #10
randomwalk101
self wrencher
randomwalk101's Avatar
Instead of 2 zipties and messy superglue, you can use 3M double layered sticky tape and put it under the zip-tie. It'll adheres to the throttle tube (thus no glue). Apply the second layer of tape to the middle portion of the zip-tie instead of the entire length like the first layer creating the tappering effects.
riding to work alot lately....question max-r95 General Motorcycling Discussion 19 July 1st, 2012 07:46 PM
So, I haven't posted alot here, but thought I'd share. Strange The Ex-Ninjetters Lair 24 April 11th, 2012 01:35 PM
FS: 2011 SE pearl/ebony 250r .. Delaware .. alot of aftermarket! greatwhiteninja Motorcycle-related 11 September 30th, 2011 07:20 AM
Started My Mods.. Alot More to come.. Tims250R 2008 - 2012 Ninja 250R Farkles 44 June 4th, 2009 02:27 PM
